TI论坛
直播中
刘东
7年用户 165经验值
私信 关注
请问AM335x Linux移植中的设备树其中的 reg = <0 0 4>; /* CS0, offset 0, IO size 4 */这句话中的 “ IO size 4”是什么意思?
各位好,公司有款产品用到了 ti的am335x系列处理器,在移植Linux时,查看了官方的SDK里的这个文件:
  1. arch/ARM/boot/dts/am335x-evm.dts,其中关于nandflash的一段如下(时序部分更改过):
  2. &gpmc [        status = "okay";        pinctrl-names = "default";        pinctrl-0 = <&nandflash_pins_s0>;        ranges = <0 0 0x08000000 0x10000000>;   /* CS0: 256MB for NAND */        nand@0,0 [                compatible = "ti,omap2-nand";                reg = <0 0 4>; /* CS0, offset 0, IO size 4 */                interrupt-parent = <&gpmc>;                interrupts = <0 IRQ_TYPE_NONE>, /* fifoevent */                             <1 IRQ_TYPE_NONE>; /* termcount */                rb-gpios = <&gpmc 1 GPIO_ACTIVE_HIGH>; /* gpmc_wait0 */                ti,nand-ecc-opt = "bch8";                ti,elm-id = <&elm>;                nand-bus-width = <16>;                gpmc,device-width = <1>;                gpmc,sync-clk-ps = <0>;                gpmc,cs-on-ns = <0>;                gpmc,cs-rd-off-ns = <6>;                gpmc,cs-wr-off-ns = <6>;                gpmc,adv-on-ns = <0>;                gpmc,adv-rd-off-ns = <8>;                gpmc,adv-wr-off-ns = <8>;                gpmc,we-on-ns = <1>;                gpmc,we-off-ns = <3>;                gpmc,oe-on-ns = <1>;                gpmc,oe-off-ns = <3>;                gpmc,access-ns = <5>;                gpmc,rd-cycle-ns = <6>;                gpmc,wr-cycle-ns = <5>;                gpmc,bus-turnaround-ns = <0>;                gpmc,cycle2cycle-delay-ns = <4>;                gpmc,clk-activation-ns = <0>;                gpmc,wr-access-ns = <5>;                gpmc,wr-data-mux-bus-ns = <0>;                /* MTD partition table */                /* All SPL-* partitions are sized to minimal length                 * which can be independently programmable. For               * which can be independently programmable. For                 * NAND flash this is equal to size of erase-block */                #address-cells = <1>;                #size-cells = <1>;                partition@0 [                        label = "NAND.SPL";                        reg = <0x00000000 0x000020000>;                ];                partition@1 [                        label = "NAND.SPL.backup1";                        reg = <0x00020000 0x00020000>;                ];                partition@2 [                        label = "NAND.SPL.backup2";                        reg = <0x00040000 0x00020000>;                ];                partition@3 [                        label = "NAND.SPL.backup3";                        reg = <0x00060000 0x00020000>;                ];                partition@4 [                        label = "NAND.u-boot-spl-os";                        reg = <0x00080000 0x00040000>;                ];                partition@5 [                        label = "NAND.u-boot";                        reg = <0x000C0000 0x00100000>;                ];                partition@6 [                        label = "NAND.u-boot-env";                        reg = <0x001C0000 0x00020000>;                ];                partition@7 [                        label = "NAND.u-boot-env.backup1";                        reg = <0x001E0000 0x00020000>;                ];                partition@8 [                      label = "NAND.kernel";                        reg = <0x00200000 0x00800000>;                ];                partition@9 [                        label = "NAND.file-system";                        reg = <0x00A00000 0x0F600000>;                ];        ];];
  3. 请问,其中的  reg = <0 0 4>; /* CS0, offset 0, IO size 4 */,
这句话中的 “ IO size 4”是什么意思?百思不得其解。。。。
望各位赐教 !!!
回帖(1)
罗兰君
2018-6-21 02:36:15
应该是指每个寄存器地址偏移4个字节。
举报
更多回帖
