TI论坛
直播中
李捷
8年用户 195经验值
私信 关注
想用TI的QDID为CC2540做BQB认证,请问能不能用SimpleProfile?
CC2540做BQB认证,想用ti的QDID,能不能用SimpleProfile?用TI已经写好的Profile的时候,能不能改特性的属性,比如说UUID,Read、Wite,还有字节之类的?
有没有相关文档说明?
回帖(1)
凌云志
2018-6-6 07:53:36
http://processors.wiki.ti.com/index.php/How_to_Certify_your_Bluetooth_product
In order to release a Bluetooth product to market, the solution need to be qualified.
  • If a TI reference designs (CC2540EM, CC2541EM) is strictly followed and the profiles are not changed, the customers do not need to do certification again. They can do the End Product Listing (EPL) on SIG website for free.
  • If you create your own proprietary profiles, it is optional for you to do certification.
  • There is not a fine line to tell whether or not a additional certification is needed (For example RF test cases, which are strictly dependent on RF circuitry). Normally, it Should be up to a Bluetooth Qualification Expert (BQE) to tell. The BQE is normally from an authorized testing houses (such as 7Layers or AT4wireless).
举报
更多回帖
