有的,为啥咱们的.h不一样
* @brief Write data to an NVS block.
* @param handle A handle returned from NVS_open()
* @param offset The byte offset into the NVS block to start
* writing. offset must be 4-byte aligned.
* @param buffer A buffer conntaining data to write to
* the NVS block. If buffer is NULL, the block
* will be erased. A non-NULL buffer must be
* aligned on a 4-byte boundary.
* @param bufferSize The size of the buffer (number of bytes to write).
* bufferSize must be a multiple of 4 bytes.
* @param flags Write flags (NVS_WRITE_EXCLUSIVE, NVS_WRITE_ERASE,
* NVS_WRITE_VALIDATE).
* @return NVS_SOK Success.
* @return NVS_EOFFSET The location and size to write to does not
* lie completely within the NVS block.
* @return NVS_EALIGN The offset or bufferSize is not 4-byte aligned.
* @return NVS_ALREADYWRITTEN
* The region to write to (the bufferSize region
* starting at offset into the block) has already
* been written to since the last erase, and
* NVS_WRITE_EXCLUSIVE is set in the flags parameter.
* @remark This call may block to ensure atomic access to the block.
extern int NVS_write(NVS_Handle handle, size_t offset, void *buffer,
size_t bufferSize, unsigned int flags);
有的,为啥咱们的.h不一样
举报
