不建议输入输出同时使用,请看TRM上的说明。
Caution must be used when implementing the nRESETIN_OUT as an bi-directional reset signal. Because
of the short maximum time allowed using RSTTIME1, it does not supply an adequate debounce time for
an external push button circuit. The processor could potentially start running while external components
are still in reset. It is recommended that this signal be used as input only (do not connect to other devices
as a reset) to implement a push button reset circuit to the AM335x, or an output only to be able to reset
other devices after an AM335x reset completes.
http://www.ti.com/lit/ug/spruh73p/spruh73p.pdf
举报
