TI论坛
直播中
朱晓妤
7年用户 209经验值
私信 关注
dm8148 u-boot突然不能正常启动了,请问怎么解决这个问题?
首先是使用相应的SD卡制作的系统启动程序u-boot.bin和ML0以及Linux操作系统的内核uImage文件,放在SD卡的p1分区,同样的讲Linux的根文件系统放在了SD卡的p2分区当中,制作完成的SD卡是完全可以使用的,但是今天拿出来就突然不能用了,在另一块相同的办卡上SD卡时可以正常运行的,串口打印的相关信息如下:
U-Boot 2010.06 (Jun 02 2015 - 04:54:06)ti8148-GP rev 3.0ARM clk: 600MHzDDR clk: 400MHzDRAM:  2 GiBMMC:   OMAP SD/MMC: 0Using default environmentThe 2nd stage U-Boot will now be auto-loadedPlease do not interrupt the countdown till TI8148_EVM prompt if 2nd stage is already flashedHit any key to stop autoboot:  0 reading u-boot.bin186836 bytes read## Starting application at 0x80800000 ...U-Boot 2010.06 (Jun 02 2015 - 05:51:17)TI8148-GP rev 3.0ARM clk: 600MHzDDR clk: 400MHzI2C:   readyDRAM:  2 GiBNAND:  HW ECC BCH8 SelectedNAND device: Manufacturer ID: 0x2c, Chip ID: 0xc3 (Micron NAND 1GiB 3,3V 16-bit)NAND bus width 8 instead 16 bitNo NAND device found!!!0 MiBMMC:   OMAP SD/MMC: 0*** Warning - bad CRC or MMC, using default environment                          .:;rrr;;.                                       ,5#@@@@#####@@@@@@#2,                              ,A@@@hi;;;r5;;;;r;rrSG@@@A,                         r@@#i;:;s222hG;rrsrrrrrr;ri#@@r                     :@@hr:r;SG3ssrr2r;rrsrsrsrsrr;rh@@:                  B@H;;rr;3Hs;rrr;sr;;rrsrsrsrsrsr;;H@B                @@s:rrs;5#;;rrrr;r#@H:;;rrsrsrsrsrr:s@@              @@;;srs&X#9;r;r;;,2@@@rrr:;;rrsrsrsrr;;@@            @@;;rrsrrs@MB#@@@@@###@@@@@@#rsrsrsrsrr;;@@          G@r;rrsrsr;#X;SX25Ss#@@#M@#9H9rrsrsrsrsrs;r@G         @9:srsrsrs;2@;:;;:.X@@@@@H::;rrsrsrsrsrsrr:3@        X@;rrsrsrsrr;XAi;;:&@@#@Bs:rrsrsrsrsrsrsrsrr;@X       @#;rsrsrsrsrr;r2ir@@@###::rrsrU-Boot 2010.06 (Jun 02 2015 - 04:54:06)TI8148-GP rev 3.0ARM clk: 600MHzDDR clk: 400MHzDRAM:  2 GiBMMC:   OMAP SD/MMC: 0Using default environmentThe 2nd stage U-Boot will now be auto-loadedPlease do not interrupt the countdown till TI8148_EVM prompt if 2nd stage is already flashedHit any key to stop autoboot:  0 reading u-boot.bin186836 bytes read## Starting application at 0x80800000 ...U-Boot 2010.06 (Jun 02 2015 - 05:51:17)TI8148-GP rev 3.0ARM clk: 600MHzDDR clk: 400MHzI2C:   readyDRAM:  2 GiBNAND:  HW ECC BCH8 SelectedNAND device: Manufacturer ID: 0x2c, Chip ID: 0xc3 (Micron NAND 1GiB 3,3V 16-bit)NAND bus width 8 instead 16 bitNo NAND device found!!!0 MiBMMC:   OMAP SD/MMC: 0*** Warning - bad CRC or MMC, using default environment                          .:;rrr;;.                                       ,5#@@@@#####@@@@@@#2,                              ,A@@@hi;;;r5;;;;r;rrSG@@@A,                         r@@#i;:;s222hG;rrsrrrrrr;ri#@@r                     :@@hr:r;SG3ssrr2r;rrsrsrsrsrr;rh@@:                  B@H;;rr;3Hs;rrr;sr;;rrsrsrsrsrsr;;H@B                @@s:rrs;5#;;rrrr;r#@H:;;rrsrsrsrsrr:s@@              @@;;srs&X#9;r;r;;,2@@@rrr:;;rrsrsrsrr;;@@            @@;;rrsrrs@MB#@@@@@###@@@@@@#rsrsrsrsrr;;@@          G@r;rrsrsr;#X;SX25Ss#@@#M@#9H9rrsrsrsrsrs;r@G         @9:srsrsrs;2@;:;;:.X@@@@@H::;rrsrsrsrsrsrr:3@        X@;rrsrsrsrr;XAi;;:&@@#@Bs:rrsrsrsrsrsrsrsrr;@X       @#;rsrsrsrsrr;r2i这里会一直反复打印上面的信息,能看到在打印字符串的过程中系统突然中断了,并重新看是运行,这是为什么呢?这里也看到成功读取了SD卡上的uboot.bin的文件!!这该如何解释呀,下面的时正常启动的相关信息:
U-Boot 2010.06 (Jun 02 2015 - 04:54:06)TI8148-GP rev 3.0ARM clk: 600MHzDDR clk: 400MHzDRAM:  2 GiBMMC:   OMAP SD/MMC: 0Using default environmentThe 2nd stage U-Boot will now be auto-loadedPlease do not interrupt the countdown till TI8148_EVM prompt if 2nd stage is already flashedHit any key to stop autoboot:  0 reading u-boot.bin186836 bytes read## Starting application at 0x80800000 ...U-Boot 2010.06 (Jun 02 2015 - 05:51:17)TI8148-GP rev 3.0ARM clk: 600MHzDDR clk: 400MHzI2C:   readyDRAM:  2 GiBNAND:  HW ECC BCH8 SelectedNAND device: Manufacturer ID: 0x2c, Chip ID: 0xc3 (Micron NAND 1GiB 3,3V 16-bit)NAND bus width 8 instead 16 bitNo NAND device found!!!0 MiBMMC:   OMAP SD/MMC: 0*** Warning - bad CRC or MMC, using default environment                          .:;rrr;;.                                       ,5#@@@@#####@@@@@@#2,                              ,A@@@hi;;;r5;;;;r;rrSG@@@A,                         r@@#i;:;s222hG;rrsrrrrrr;ri#@@r                     :@@hr:r;SG3ssrr2r;rrsrsrsrsrr;rh@@:                  B@H;;rr;3Hs;rrr;sr;;rrsrsrsrsrsr;;H@B                @@s:rrs;5#;;rrrr;r#@H:;;rrsrsrsrsrr:s@@              @@;;srs&X#9;r;r;;,2@@@rrr:;;rrsrsrsrr;;@@            @@;;rrsrrs@MB#@@@@@###@@@@@@#rsrsrsrsrr;;@@          G@r;rrsrsr;#X;SX25Ss#@@#M@#9H9rrsrsrsrsrs;r@G         @9:srsrsrs;2@;:;;:.X@@@@@H::;rrsrsrsrsrsrr:3@        X@;rrsrsrsrr;XAi;;:&@@#@Bs:rrsrsrsrsrsrsrsrr;@X       @#;rsrsrsrsrr;r2ir@@@###::rrsrsrsrsrsrsrsrsr:@@       @A:rrsrsrsrr;:2@29@@M@@@;:;rrrrsrsrsrsrsrsrs;H@       @&;rsrsrsrr;A@@@@@@###@@@s::;:;;rrsrsrsrsrsr;G@       @#:rrsrsrsr;G@5Hr25@@@#@@@#9XG9s:rrrrsrsrsrs:#@       M@;rsrsrsrs;r@&#;::S@@@@@@@M@@@@Grr:;rsrsrsr;@#       :@s;rsrsrsrr:M#Msrr;;&#@@@@@@@@@@H@@5;rsrsr;s@,        @@:rrsrsrsr;S@rrrsr;:;r3MH@@#@M5,S@@irrsrr:@@          @A:rrsrsrsrrrrrsrsrrr;::;@##@r:;rH@h;srr:H@           ;@9:rrsrsrsrrrsrsrsrsr;,S@Hi@i:;s;MX;rr:h@;            r@B:rrrrsrsrsrsrsrr;;sA@#i,i@h;r;S5;r:H@r              ,@@r;rrrsrsrsrsrr;2BM3r:;r:G@:rrr;;r@@,                 B@Mr;rrrrsrsrsr@@S;;;rrr:5M;rr;rM@H                    .@@@i;;rrrrsrs2i;rrrrr;r@M:;i@@@.                       .A@@#5r;;;r;;;rrr;r:r#AsM@@H.                            ;&@@@@MhXS5i5SX9B@@@@G;                                   :ihM#@@@@@##hs,                Net:   ->cpsw_pad_config() not set. Reading from E-fuseDetected MACID:84:7e:40:d2:df:dcmiiphy_register: added 'cpsw', read=0x80721c10, write=0x80721c7ccpswHit any key to stop autoboot:  0 reading boot.scr308 bytes readRunning bootscript from MMC/SD to set the ENV...## Executing script at 80900000reading uImage3105852 bytes read## Booting kernel from Legacy Image at 81000000 ...   Image Name:   Linux-2.6.37   Image Type:   ARM Linux Kernel Image (uncompressed)   Data Size:    3105788 Bytes = 3 MiB   Load Address: 80008000   Entry Point:  80008000   Verifying Checksum ... OK   Loading Kernel Image ... OKOKStarting kernel ...
回帖(3)
葛睿洁
2018-5-28 11:45:21
  如果SD卡可以工作,说明SD卡数据是没有问题的,可以查查另外一个板卡是否接触有问题?可以用仪器测一下。
举报
朱晓妤
2018-5-28 12:03:42
引用: Greatwayer 发表于 2018-5-28 11:45
<blockquote class="quote"/>  如果SD卡可以工作,说明SD卡数据是没有问题的,可以查查另外一个板卡是否接触有问题?可以用仪器测一下。
是的,在一块板子上能正常工作,在另一块板子上工作就出现了问题,SD卡的数据是没有问题的。
您说检查板卡的接触问题,是电源接触的问题吗?SD卡槽应该没有接触的问题吧,能麻烦您教一下如何排查具体的问题呢,用什么仪器测试呢,我还是个小白,不是很懂硬件检查的步骤和详细方法,我也更换过板卡的电源,还是一样的结果,能否从uboot打印出来的信息状况来判断板卡的相关问题,每次输出打印到这里就会中断可能的原因是什么,而且每次打印的内容长度也有所不同,这个能说明点什么吗?
举报
朱晓妤
2018-5-28 12:15:48
今天重新拿出板子测试了一下,板子居然又正常运行了,具体的原因也不太清楚,固化在SD卡中的uboot程序没有更新过,板子的其他跳线帽以及微动开关也没有动过,就是简单的擦了擦灰尘,放了几天,电源开关是一直开着的,让电容充分的放电了,也就是上面的操作了,使用的这张SD卡在另外一块板卡上一直使用着,不知道是不是这个原因,目前板子终于正常运行了!Cheers~
1、怀疑是有静电导致的,没事可以拔掉电源打开电源开关放放电啥)
2、将板卡上面的灰尘等污渍清理一下,细心点可能那个元件的位置残留物导致短路了
举报
更多回帖
