TI论坛
直播中
张建华
7年用户 193经验值
私信 关注
TMS320C6678 MAC address error出错,请问是不是因为两个核的NDK所使用的EMAC channel 相同造成的呢?
您好,
  首先非常感谢您的回答。我所碰到的问题是MAC address 出错,是不是因为两个核的NDK所使用的EMAC channel 相同造成的呢?另外,我在NDK USER'S GUIDE 和 NDK software programmer's reference guide 两篇文档中好像没发现有设置EMAC channel 的API 呀。我把我的代码和错误信息贴在下面,还想麻烦您看一下,指出问题所在。
使用的核为 CORE_0  和 CORE_1 ,两个核单独启动 即: Ipc.procSync = Ipc.ProcSync_NONE; // in file.cfg
错误信息如下:
[C66xx_0] EVM in StaticIP mode at 192.168.0.218
[C66xx_0] QMSS successfully initialized
[C66xx_0] CPPI successfully initialized
[C66xx_0] PASS successfully initialized
[C66xx_0] Ethernet subsystem successfully initialized
[C66xx_0] eventId : 48 and vectId : 7
[C66xx_0] Registration of the EMAC Successful, waiting for link up ..
[C66xx_0] run in daemon
[C66xx_0] receive :
[C66xx_1] QMSS successfully initialized
[C66xx_1] CPPI successfully initialized
[C66xx_1] PASS successfully initialized
[C66xx_1] Ethernet subsystem successfully initialized
[C66xx_1] eventId : 48 and vectId : 7
[C66xx_1] Timeout waiting for reply from PA to Pa_addMac command
[C66xx_1] Add_MACAddress failed
[C66xx_1] Error: Unable to register the EMAC
CORE_0 网络配置代码:
int RunUDP_sever()
   HANDLE hCfg;
   CI_IPNET NA;
   IPN      IPTmp;
   int nStatus, nRecv;
   char *HostName    = "UDP_SEVER_0";
   char *DomainName  = "demo0.net";         /* Not used when using DHCP */
   char *DNSServer   = "0.0.0.0";          /* Used when set to anything but zero */
   nStatus = NC_SystemOpen( NC_PRIORITY_LOW, NC_OPMODE_INTERRUPT );
    if(nStatus != NC_OPEN_SUCCESS)
#ifdef UDP_SEVER_DEBUG
     printf("NC_SystemOpen Failed (%d)n",nStatus);
#endif
    goto close_n_exit;
hCfg = CfgNew();
if( !hCfg )
     printf("Unable to create configurationn");
#endif
    goto close_n_exit;
/* Validate the length of the supplied names */
   if( strlen( DomainName ) >= CFG_DOMAIN_MAX ||
       strlen( HostName ) >= CFG_HOSTNAME_MAX )
       printf("Domain or Host Name too longn");
#endif
       goto close_n_exit;
   /* Add our global hostname to hCfg (to be claimed in all connected domains) */
   CfgAddEntry( hCfg, CFGTAG_SYSINFO, CFGITEM_DHCP_HOSTNAME, 0, strlen(HostName), (UINT8 *)HostName, 0 );
/* Setup an IP address to this EVM */
     bzero( &NA, sizeof(NA) );
     NA.IPAddr  = inet_addr("192.168.0.218");
     NA.IPMask  = inet_addr("255.255.255.0");
     strcpy( NA.Domain, DomainName );
     /* Add the address to interface 1 */
     CfgAddEntry( hCfg, CFGTAG_IPNET, 1, 0, sizeof(CI_IPNET), (UINT8 *)&NA, 0 );
     /* Manually add the DNS server when specified */
    IPTmp = inet_addr(DNSServer);
    if( IPTmp )
    CfgAddEntry( hCfg, CFGTAG_SYSINFO, CFGITEM_DHCP_DOMAINNAMESERVER, 0, sizeof(IPTmp), (UINT8 *)&IPTmp, 0 );
    /* Set debug message level */
    nStatus = DBG_WARN;
    CfgAddEntry( hCfg, CFGTAG_OS, CFGITEM_OS_DBGPRINTLEVEL, CFG_ADDMODE_UNIQUE, sizeof(uint), (UINT8 *)&nStatus, 0 );
    // UDP Receive limit
    nRecv = 8192;
    CfgAddEntry( hCfg, CFGTAG_IP, CFGITEM_IP_SOCKUDPRXLIMIT,
    CFG_ADDMODE_UNIQUE, sizeof(uint), (UINT8 *)&nRecv, 0 );
   do
    nStatus = NC_NetStart( hCfg, NetworkOpen, NetworkClose, NetworkIPAddr );
] while( nStatus > 0 );
   platform_write ("Shutting things downn");
#endif
close_n_exit:
  CfgFree( hCfg );
  NC_SystemClose();
return 0;
static HANDLE hDaemon=0;
static void NetworkOpen()
     hDaemon = DaemonNew( SOCK_DGRAM, 0, 1062, RecvImg, OS_TASKPRIHIGH, OS_TASKSTKNORM, 0, 1 );//7//OS_TASKPRINORM
CORE_1网络配置代码:
int UDP_Sever()
    HANDLE hCfg;
    CI_IPNET NA;
    IPN      IPTmp;
    int nStatus, nRecv;
    char *HostName    = "UDP_SEVER";
    char *DomainName  = "demo.net";         /* Not used when using DHCP */
#endif
        goto close_n_exit;
    hCfg = CfgNew();
    if( !hCfg )
#endif
       goto close_n_exit;
#endif
       goto close_n_exit;
  NA.IPAddr  = inet_addr("192.168.0.217");
  if( IPTmp )
  nStatus = DBG_WARN;
  nRecv = 8192;
  do
#endif
close_n_exit:
      CfgFree( hCfg );
      NC_SystemClose();
  return 0;
    // Create our local server
    hHello = DaemonNew( SOCK_DGRAM, 0, 7, dtask_udp_hello,  OS_TASKPRINORM, OS_TASKSTKNORM, 0, 1 );
回帖(3)
高欢
2018-5-22 03:27:11
你好
请单步跟踪nimu_eth.c中
Add_MACAddress函数和paReturn_t Pa_addMac 获取具体失败的信息
谢谢!
举报
张建华
2018-5-22 03:41:27
引用: liuqin123 发表于 2018-5-22 03:27
你好
请单步跟踪nimu_eth.c中
非常感谢Thomas Yang 的解答。
举报
李宇昂
2018-5-22 03:48:12
将EVM板上的switch开关调到“ No boot” 模式,就可以了,我在6670EVM上面试过了,具体查看下面两个URL :http://e2e.ti.com/support/development_tools/code_composer_studio/f/81/t/132177.aspx
http://processors.wiki.ti.com/index.php/TMDXEVM6670L_EVM_Hardware_Setup
举报
更多回帖
