单片机/MCU论坛
直播中
小明同学
7年用户 33经验值
擅长:770529
私信 关注
[问答]
又是tm1629B的LED显示问题
使用SH79F166A做上位机控制TM1629B显示LED,数码管计数显示。但是该板写入0X00,或者使用关显示0x80都无法使之熄灭。同时,LED是乱显示的。一个个地址地试也无法得到想要的结果,做不到单个LED单独亮灭,代码如下(请自动忽略其中的触摸按键函数):
#define.h
#ifndef        _DEFINE_H
#define        _DEFINE_H
#include
#include
typedef        unsigned char uint8;
typedef        signed char  int8;
typedef        unsigned int uint16;
typedef        signed int        int16;
#define        NOP        _nop_()
#define        Mode_Auto        0x40
#define        Mode_Manual        0x44
#define        Mode_Disp        0x8F
#define        Read_Key        0x42
#define        Disp_Off        0x80
#define        Start_Addr        0xC0
#define        Power_heart        0xC1
#define        Set_fan                0xC3
#define        UP_SW_time        0xC5
#define        Warm_DOWN        0xC7
#define        HUICHA_Time        0xC8
#define        Temp_AddrH        0xCF
#define        Temp_AddrL        0xCD
#define        Time_HourH        0xC5
#define        Time_HourL        0xC6
#define        Time_MinuH        0xCA
#define        Time_MinuL        0xCB
#define        zero                0x3F
#define        S_F_LED_OFF        0x08
#define        P_H_LED_OFF        0x40
#define        Key_ON                0x10
#define        Heart_ON        0x02
#define        All                        0x02
#define        ttt                        0x10
***it        DIO=P3^2;
***it        CLK=P4^2;
***it        STB=P1^6;
//***it        TDI=P1^5;
//***it        TCK=P1^4;
void        LedInit();
uint8         KeyScan();
//void        I2CInit();
void        I2CStop();
void        I2CStart();
void        Timer2Init();
uint8        I2CReadData();
void         DisplayTemp();
void        DisplayTime();
uint8        LedReadData();
void        ReadUartInit();
void        Delay(uint8 t);
void        WriteUartInit();
void        delayus(uint8 t);
void         Display(uint8 Data);
void        DisplayKey(uint8 Key);
void        I2CWriteData(uint8 Data);
void        LedWriteData(uint8 Data);
void        DisplayFunction(uint8 Function);
#endif
#main.c
#include"define.h"
extern uint8 FlagTime;
void        main()
//        uint8 i;
        P3CR=0xff;
    P3PCR=0x0;
    P3=0x00;
        P4CR=0xff;
    P4PCR=0x0;
    P4=0x00;
        P1CR=0xff;
        P1PCR=0x0;
        P1=0x00;
        Timer2Init();
        LedInit();
        Display(Disp_Off);
        while(1)
                        Display(All);
                //        DisplayTemp();
                //        DisplayTime();
                //        Delay(1);
void        Timer2Init()
         T2CON=0x00;
         T2MOD=0x00;
         RCAP2H=(65536-50000)/256;
         RCAP2L=(65536-50000)%256;
         TH2=(65536-50000)/256;
         TL2=(65536-50000)%256;
         IEN0|=0xa0;
         EA=1;
         ET2=1;
         TR2=1;
         TF2=0;
void timer2()        interrupt        5        //5ms自动重载定时器
          static uint8 t;
          t++;
          TF2=0;
          if(t>=10)
                  FlagTime=1;
                t=0;
//          KeyScan();
void        Delay(uint8 t)
        uint8 i,j;
        for(;t>0;t--)
                for(i=0;i<255;i++)
                        for(j=0;j<255;j++);
#led.c
#include"define.h"
uint8 code digit[]={
0x3F,0x30,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F
uint8 FlagTime=0;
uint8 time=0;
void        LedInit()
        CLK=1;
        DIO=1;
        STB=1;
        uint8        i;
        STB=0;
        for(i=0;i<8;i++)
          CLK=0;
          if((Data&0x01)==0x01)
                  DIO=1;
          }else
                  DIO=0;
        CLK=1;
        NOP;NOP;NOP;NOP;NOP;
        Data=Data>>1;
        NOP;NOP;NOP;
uint8        LedReadData()
         uint8 i;
         uint8 ReadData;
         CLK=0;
         DIO=1;
         for(i=0;i<8;i++)
                 CLK=1;                         //上升沿读数据
                ReadData=ReadData>>1;
                 if(DIO==0x01)
                        ReadData|=0x80;
                else{
                        ReadData&=0x7F;
                CLK=0;
                NOP;NOP;NOP;
         DIO=1;
         return ReadData;
        uint8        i;
        LedWriteData(Mode_Manual);
        STB=1;
        LedWriteData(Start_Addr);
//        for(i=0;i<1;i++)
                LedWriteData(Data);
        STB=1;
        LedWriteData(Mode_Disp);
        STB=1;
void        DisplayTime()
                   if(FlagTime==1)
                        time++;
                        FlagTime=0;
                if(time>=0)
                        STB=1;
                        LedWriteData(Time_HourH);
                        LedWriteData(digit[time/60/10]);
                        STB=1;
                        LedWriteData(Time_HourL);
                        LedWriteData(digit[time/60%10]);
                        STB=1;
                        LedWriteData(Time_MinuH);
                        LedWriteData(digit[time%60/10]);
                        STB=1;
                        LedWriteData(Time_MinuL);
                        LedWriteData(digit[time%60%10]);
                        STB=1;
                        STB=1;
                if(time==1440)
                        time=0;
void DisplayTemp()
        uint8        i;
        for(i=0;i<60;i++)
                STB=1;
                LedWriteData(Temp_AddrH);
                LedWriteData(digit[i/10]);
                STB=1;
                LedWriteData(Temp_AddrL);
                LedWriteData(digit[i%10]);
                STB=1;
                STB=1;
                Delay(1);
回帖(3)
lee_st
2018-4-10 09:49:45
最佳答案
配置有问题哦
举报
小明同学
2018-4-10 16:34:45
整了一天,问题终于解决了,原来在采用自动地址加一的方式循环中,不知道什么时候把16的6给删了,导致,地址一直处于起始地址。此外,由于换了块板,新板的LED屏引脚有错误,数码管的段码不是处于同一个地址中,每个8中的一横都在上一个地址中,就很蛋疼,找了半天才找出来,同时导致原来的数字编码失效,需要重新推出新的数字编码。在一个个地尝试之后,终于实现了LED的计时显示和温度度数显示。。。接下来就等着触摸IC供应商上门指导触摸编程啦~~
代码如下(请自动忽略触摸部分)
#define.h
#ifndef        _DEFINE_H
#define        _DEFINE_H
#include
#include
#define        NOP        _nop_()
#define        Temp_Hevel        0xCC
#define        Temp_Level        0xCE
#define        Temp_AddrH        0xCD
#define        Temp_AddrL        0xCF
#define        Time_HourL        0xC7
#define        Time_MinuH        0xC9
#define        Time_HHevel        0xC4
#define        Time_HLevel        0xC6
#define        Time_LHevel        0xC8
#define        Time_LLevel        0xCA
#define        All                        0x00
#define        ttt                        0x01
***it        DIO=P3^2;
***it        CLK=P4^2;
***it        STB=P1^6;
//***it        TDI=P1^5;
//***it        TCK=P1^4;
void        LedInit();
uint8         KeyScan();
//void        I2CInit();
void        I2CStop();
void        I2CStart();
void        Timer2Init();
void         DisplayTemp();
void        DisplayTime();
#endif
main.c
#include"define.h"
void        main()
//        uint8 i;
        P3CR=0xff;
    P3PCR=0x0;
    P3=0x00;
        P4CR=0xff;
    P4PCR=0x0;
    P4=0x00;
        P1CR=0xff;
        P1PCR=0x0;
        P1=0x00;
        Timer2Init();
        LedInit();
        Display(All);
        while(1)
                //        DisplayTemp();
                        DisplayTime();
                //        Delay(1);
void        Timer2Init()
         T2CON=0x00;
         T2MOD=0x00;
         IEN0|=0xa0;
         EA=1;
         ET2=1;
         TR2=1;
         TF2=0;
          static uint8 t;
          t++;
          TF2=0;
          if(t>=10)
                  FlagTime=1;
                t=0;
//          KeyScan();
void        Delay(uint8 t)
        uint8 i,j;
        for(;t>0;t--)
                for(i=0;i<255;i++)
                        for(j=0;j<255;j++);
led.c
#include"define.h"
0x3F,0x03,0xB6,0xBC,0x99,0xAD,0xAF,0x38,0xBF,0xBD
uint8 FlagTime=0;
uint8 time=0;
void        LedInit()
        CLK=1;
        DIO=1;
        STB=1;
        uint8        i;
        STB=0;
        for(i=0;i<8;i++)
          CLK=0;
                  DIO=1;
          }else
                  DIO=0;
        CLK=1;
        Data=Data>>1;
        NOP;NOP;NOP;
uint8        LedReadData()
         uint8 i;
         uint8 ReadData;
         CLK=0;
         DIO=1;
         for(i=0;i<8;i++)
                 CLK=1;                         //上升沿读数据
                 if(DIO==0x01)
                        ReadData|=0x80;
                else{
                        ReadData&=0x7F;
                CLK=0;
                NOP;NOP;NOP;
         DIO=1;
         return ReadData;
        uint8        i;
        LedWriteData(Mode_Auto);
        STB=1;
        for(i=0;i<16;i++)
                LedWriteData(Data);
        STB=1;
        STB=1;
void        DisplayTime()
                   if(FlagTime==1)
                        time++;
                        FlagTime=0;
                if(time>=0)
                                if(((time/60/10)==0)||((time/60/10)==1)||((time/60/10)==7))
                                        STB=1;
                                        LedWriteData(Time_HHevel);
                                        LedWriteData(0x00);
                                else
                                        STB=1;
                                        LedWriteData(0x80);
                                if(((time/60%10)==0)||((time/60%10)==1)||((time/60%10)==7))
                                        STB=1;
                                        LedWriteData(Time_HLevel);
                                        LedWriteData(0x00);
                                else
                                        STB=1;
                                        LedWriteData(0x80);
                                if(((time%60/10)==0)||((time%60/10)==1)||((time%60/10)==7))
                                        STB=1;
                                        LedWriteData(Time_LHevel);
                                        LedWriteData(0x00);
                                else
                                        STB=1;
                                        LedWriteData(0x80);
                                if(((time%60%10)==0)||((time%60%10)==1)||((time%60%10)==7))
                                        STB=1;
                                        LedWriteData(Time_LLevel);
                                        LedWriteData(0x00);
                                else
                                        STB=1;
                                        LedWriteData(0x80);
                                STB=1;
                                STB=1;
                                STB=1;
                                STB=1;
                                STB=1;
                                STB=1;
                if(time==1440)
                        time=0;
void DisplayTemp()
        uint8        i;
        for(i=0;i<60;i++)
                if(((i/10)==0)||((i/10)==1)||((i/10)==7))
                        STB=1;
                        LedWriteData(Temp_Hevel);
                        LedWriteData(0x00);
                }else
                        STB=1;
                        LedWriteData(0x80);
                if(((i%10)==0)||((i%10)==1)||((i%10)==7))
                        STB=1;
                        LedWriteData(Temp_Level);
                        LedWriteData(0x00);
                }else
                        STB=1;
                        LedWriteData(0x80);
                STB=1;
                STB=1;
                STB=1;
                STB=1;
                Delay(1);
举报
唐宽
2019-1-29 16:25:47
受到警告
提示: 作者被禁止或删除 内容自动屏蔽
举报
更多回帖
