STM32/STM8技术论坛
直播中
慧心的眼眸
7年用户 631经验值
私信 关注
[经验]
STM32之中断与事件---一个使用GPIO作为外部中断的示例
1.GPIO 的正确设置
[cpp] view plain copy
  • GPIO_InitTypeDef GPIO_InitStructure;
  • /* Enable GPIOD clock */
  • RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD, ENABLE);
  • /* Configure PD.03, PC.04, as input floating */
  • GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3 | GPIO_Pin_4 ;
  • GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  • GPIO_Init(GPIOD, &GPIO_InitStructure);
  • GPIO_EXTILineConfig(GPIO_PortSourceGPIOD, GPIO_PinSource3); //PD3作为外部中断引脚
其中GPIO_EXITLineConfig函数的声明如下:
  • * @Brief Selects the GPIO pin used as EXTI Line.
  • * @param GPIO_PortSource: selects the GPIO port to be used as source for EXTI lines.
  • * This parameter can be GPIO_PortSourceGPIOx where x can be (A..G).
  • * @param GPIO_PinSource: specifies the EXTI line to be configured.
  • * This parameter can be GPIO_PinSourcex where x can be (0..15).
  • * @retval None
  • void GPIO_EXTILineConfig(uint8_t GPIO_PortSource, uint8_t GPIO_PinSource)
2.中断初始化
  • EXTI_InitTypeDef EXTI_InitStructure;
  • // Configure EXTI Line3 to generate an interrupt on falling edge
  • EXTI_InitStructure.EXTI_Line = EXTI_Line3;
  • EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
  • EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling;
  • EXTI_InitStructure.EXTI_LineCmd = ENABLE;
  • EXTI_Init(&EXTI_InitStructure);
  • GPIO_EXTILineConfig(GPIO_PortSourceGPIOD, GPIO_PinSource4);
  • // Configure EXTI Line4 to generate an interrupt on falling edge
  • EXTI_InitStructure.EXTI_Line = EXTI_Line4;
3.在NVIC_Configuration 中Configures the NVIC and Vector Table base address.
  • /* Configure the Priority Group to 2 bits */
  • NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
  • /* enabling interrupt */
  • NVIC_InitStructure.NVIC_IRQChannel=TIM2_IRQChannel;
  • NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
  • NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
  • NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  • NVIC_Init(&NVIC_InitStructure);
  • /* Enable the EXTI3 Interrupt on PD.3 */
  • NVIC_InitStructure.NVIC_IRQChannel = EXTI3_IRQChannel;
  • NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 2;
  • /* Enable the EXTI4 Interrupt on PD.4 */
  • NVIC_InitStructure.NVIC_IRQChannel = EXTI4_IRQChannel;
  • NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
4.在STM32f0x_it.c 中写入 中断处理函数
  • * Function Name : EXTI3_IRQHandler
  • * Description : This function handles External interrupt Line 3 request.
  • * Input : None
  • * Output : None
  • * Return : None
  • void EXTI3_IRQHandler(void)
  •     if(EXTI_GetITStatus(EXTI_Line3) != RESET)
  •         // Led_RW_ON();
  •         GPIO_SetBits(GPIOC, GPIO_Pin_4| GPIO_Pin_5 );
  •         /* Clear the EXTI line 9 pending bit */
  •         EXTI_ClearITPendingBit(EXTI_Line3);
  • * Function Name : EXTI4_IRQHandler
  • * Description : This function handles External interrupt Line 4 request.
  • * Input : None
  • * Output : None
  • * Return : None
  • void EXTI4_IRQHandler(void)
  •     if(EXTI_GetITStatus(EXTI_Line4) != RESET)
  •         //Led_RW_OFF();
  •         GPIO_ResetBits(GPIOC, GPIO_Pin_4 | GPIO_Pin_5);
  •         EXTI_ClearITPendingBit(EXTI_Line4);
另一个示例:
配置如下:
  • void vcm_airbag_exti_set(void)
  •     NVIC_InitTypeDef NVIC_InitStructure;
  •     /* Enable key GPIO clock */
  •     RCC_AHB1PeriphClockCmd(AIRBAG_GPIO_RCC, ENABLE);
  •     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN;
  •     GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
  •     GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
  •     GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
  •     /* Configure  pin(PD_15): airbag gpio */
  •     GPIO_InitStructure.GPIO_Pin = AIRBAG_GPIO_PIN;
  •     GPIO_Init(AIRBAG_GPIO_PORT, &GPIO_InitStructure);
  •     RCC_APB2PeriphClockCmd(RCC_APB2Periph_SYSCFG, ENABLE);          //´ò¿ªEXTIʱÖÓ
  •     SYSCFG_EXTILineConfig(AIRBAG_EXTI_PORT, AIRBAG_EXTI_PIN);       //ÉèÖÃPD15ΪEXTI
  •     /* Configure  EXTI  */
  • //  EXTI_DeInit();
  •     EXTI_InitStructure.EXTI_Line = AIRBAG_EXTI_LINE;    //ÉèÖÃÒý½Å
  •     EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt; //ÉèÖÃΪÍⲿÖжÏģʽ
  •     EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Rising_Falling;  // ÉèÖÃÉÏÉýºÍϽµÑض¼¼ì²â
  •     EXTI_InitStructure.EXTI_LineCmd = ENABLE;                //ʹÄÜÍⲿÖжÏÐÂ״̬
  •     EXTI_Init(&EXTI_InitStructure);                          //¸ù¾ÝEXTI_InitStructÖÐÖ¸¶¨µÄ²ÎÊý³õʼ»¯ÍâÉèEXTI¼Ä´æÆ÷
  •     NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;                //ʹÄÜÍⲿÖжÏͨµÀ
  •     NVIC_InitStructure.NVIC_IRQChannel = EXTI15_10_IRQn;
  •     NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x0F;         //ÏÈÕ¼ÓÅÏȼ¶4λ,¹²16¼¶
  •     NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x0F;  //ÏÈÕ¼ÓÅÏȼ¶0λ,´ÓÓÅÏȼ¶4λ
  •     NVIC_Init(&NVIC_InitStructure);                               //¸ù¾ÝNVIC_InitStructÖÐÖ¸¶¨µÄ²ÎÊý³õʼ»¯ÍâÉèNVIC¼Ä´æÆ÷
中断例程:
  • void EXTI15_10_IRQHandler(void)
  •     rt_interrupt_enter();
  •     /* °²È«ÆøÄÒÓ²Ïß¼ì²â´¦Àí¡¡*/
  •     vcm_airbag_exti_check();
  •     /* GPSÌìÏß¿ªÂ·¼ì²â´¦Àí¡¡*/
  •     gps_exti_check();
  •     rt_interrupt_leave();
  • void vcm_airbag_exti_check(void)
  •     //¼ì²éµ±Ç°ÖжϵÄ״̬ÊÇ·ñºÏ·¨
  •     if(EXTI_GetITStatus(AIRBAG_EXTI_LINE) != RESET)
  •         //¶ÁÈ¡¹Ü½ÅµÄ״̬,ÕâÀï·µ»Ø0±íʾ°²È«ÆøÄÒ±¬¿ª
  •         if(0 ==GPIO_ReadInputDataBit(AIRBAG_GPIO_PORT,AIRBAG_GPIO_PIN))
  •             recv_frame.bus_type = BTYPE_HS_CAN;
  •             recv_frame.id = 0x545;
  •             recv_frame.data_buff[0] = 0x00;
  •             recv_frame.data_buff[1] = 0x01;
  •             recv_frame.data_buff[2] = 0x00;
  •             recv_frame.data_buff[3] = 0x00;
  •             recv_frame.data_buff[4] = 0x00;
  •             recv_frame.data_buff[5] = 0x00;
  •             recv_frame.data_buff[6] = 0x00;
  •             recv_frame.data_buff[7] = 0x00;
  •             VCM_DEBUG("[vcm] warning: airbag gpio interrupt rising.rn");
  •         else
  •             recv_frame.data_buff[1] = 0x00;
  •             VCM_DEBUG("[vcm] warning: airbag gpio interrupt falling.rn");
  •         rt_mq_send(&recv_frame_mq,&recv_frame,sizeof(can_bus_frame));
  •         //ÇåÖжϱê־λ
  •         EXTI_ClearITPendingBit(AIRBAG_EXTI_LINE);
  • 嵌入式学习交流群:561213221
回帖(1)
嘉o0o嘉
2018-3-27 08:49:43
是龟速诉讼费是否法阿发法阿发法法法阿发法
举报
更多回帖
