u*** 1-1.3: new high-speed USB device number 3 using ci_hdrc
option 1-1.3:1.0: GSM modem (1-port) converter detected
u*** 1-1.3: GSM modem (1-port) converter now attached to ttyUSB0
option 1-1.3:1.1: GSM modem (1-port) converter detected
u*** 1-1.3: GSM modem (1-port) converter now attached to ttyUSB1
option 1-1.3:1.2: GSM modem (1-port) converter detected
u*** 1-1.3: GSM modem (1-port) converter now attached to ttyUSB2
option 1-1.3:1.3: GSM modem (1-port) converter detected
u*** 1-1.3: GSM modem (1-port) converter now attached to ttyUSB3
option 1-1.3:1.4: GSM modem (1-port) converter detected
u*** 1-1.3: GSM modem (1-port) converter now attached to ttyUSB4
root@myd-y6ull14x14:~# lsu***
Bus 001 Device 003: ID 2c7c:0125
Bus 001 Device 002: ID 0424:2514
Bus 001 Device 001: ID 1d6b:0002
root@myd-y6ull14x14:~# ifconfig
eth0 Link encap:Ethernet HWaddr 5a:e8:4c:28:85:18
inet addr:192.168.220.8 Bcast:192.168.220.255 Mask:255.255.255.0
inet6 addr: fe80::58e8:4cff:fe28:8518/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:246 errors:0 dropped:6 overruns:0 frame:0
TX packets:69 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:23063 (22.5 KiB) TX bytes:11177 (10.9 KiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
root@myd-y6ull14x14:~# ifup ppp0
RX packets:5301 errors:0 dropped:146 overruns:0 frame:0
TX packets:369 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:479966 (468.7 KiB) TX bytes:44459 (43.4 KiB)
ppp0 Link encap:Point-to-Point Protocol
inet addr:10.122.190.168 P-t-P:10.64.64.64 Mask:255.255.255.255
UP POINTOPOINT RUNNING NOARP MULTICAST MTU:1500 Metric:1
RX packets:20 errors:0 dropped:0 overruns:0 frame:0
TX packets:20 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:3
RX bytes:1322 (1.2 KiB) TX bytes:1346 (1.3 KiB)
root@myd-y6ull14x14:~# ping -c 8 -I ppp0 118.178.213.186
PING 118.178.213.186 (118.178.213.186) from 10.122.190.168 ppp0: 56(84) bytes of data.
64 bytes from 118.178.213.186: icmp_seq=1 ttl=37 time=164 ms
64 bytes from 118.178.213.186: icmp_seq=2 ttl=37 time=82.3 ms
64 bytes from 118.178.213.186: icmp_seq=3 ttl=37 time=79.6 ms
64 bytes from 118.178.213.186: icmp_seq=4 ttl=37 time=87.0 ms
64 bytes from 118.178.213.186: icmp_seq=5 ttl=37 time=76.3 ms
64 bytes from 118.178.213.186: icmp_seq=6 ttl=37 time=76.1 ms
64 bytes from 118.178.213.186: icmp_seq=7 ttl=37 time=73.0 ms
64 bytes from 118.178.213.186: icmp_seq=8 ttl=37 time=72.4 ms
--- 118.178.213.186 ping statistics ---
8 packets transmitted, 8 received, 0% packet loss, time 7011ms
rtt min/avg/max/mdev = 72.494/88.979/164.773/29.004 ms
更多回帖
