使配置文件生效(validate configured file)execute source command
$ source ~/my-imx6/03_tools/myimx6_3035_build_env
![](https://file.elecfans.com/web2/M00/66/0C/poYBAGMOFFOAO6L7AAAaFHDd84w035.jpg)
view compiler configuration
$ echo $ARCH
$ echo $CROSS_COMPILE
提示:可看到ARCH和CROSS_COMPILE被设置
tips:you can see that ARCH和CROSS_COMPILE is configured
![](https://file.elecfans.com/web2/M00/66/A6/pYYBAGMOFFOAOH5QAABA6evz2q0116.jpg)
verify cross compiler tool configuration
$${CROSS_COMPILE}gcc –v
提示:执行命令后可以看到终端显示出交叉编译工具的版本信息。如下图:
tips:you can see version information of cross compiler tool shown on terminal after execution of command.as below:
![](https://file.elecfans.com/web2/M00/66/A6/pYYBAGMOFFSAUkpZAAI2OWwF92Y026.jpg)
清除u-boot配置(remove u-boot configuration)$ make distclean
![](https://file.elecfans.com/web2/M00/66/0C/poYBAGMOFFSAQR_gAAANe91PH4c186.jpg)
u-boot配置(u-boot configuration)evaluation board and its corresponding u-boot compiler configuration:
评估板主型号
(evaluation board main model) | CPU类型-内存容量
(CPU type-memory capacity) | 对应的u-boot配置
(corresponding u-boot configuration) |
MY-IMX6-EK200 | 6Q(四核)- 1G
(6Q(quad. core)- 1G) | myimx6ek200_6q_config |
6Q(四核)- 2G
(6Q(quad core)- 2G) | myimx6ek200_6q_2g_config |
6U(双核简化)- 1G
(6U(dual core tile)- 1G) | myimx6ek200_6u_config |
6S(单核)- 512M
(6S(single core)- 512M) | myimx6ek200_6s_config |
MY-IMX6-EK314 | 6Q(四核)- 1G
(6Q(quad.core)- 1G) | myimx6ek314_6q_config |
6Q(四核)- 2G
(6Q(quad.core)- 2G) | myimx6ek314_6q_2g_config |
6U(双核简化)- 1G
(6U(dual core tile)- 1G) | myimx6ek314_6u_config |
6S(单核)- 512M
(6S(single core)- 512M) | myimx6ek314_6s_config |
MYIMX6EK200-6Qxx-1G configuration example:
$ make myimx6ek200_6q_config
![](https://file.elecfans.com/web2/M00/66/A6/pYYBAGMOFFSAE1kwAAAdzWKQCeU801.jpg)
编译(compilation)execute compilation
$ make
提示:这里为了提高编译速度,在make后面加了“-j4”。这里编译的Linux主机是双核4线程的,所以“-j”后面用了4,也就是采用4线程编译。“-j”后面的数字可以根据系统资源分配,但是不应该超过编译主机最大支持的线程数。
Tips:To speed up the compilation,add "-j4" after make.The Linux host used to compile is dual-core ,4 threads .So "-j" is followed by 4, which takes 4 threads to compile. The number behind "-j" is allocated based on system resources,but It should not exceed the maximum threads the host support。
![](https://file.elecfans.com/web2/M00/66/0C/poYBAGMOFFeALA0RAACAT_LsFDw296.jpg)
complete compilation
提示:u-boot编译过程大概需要几分钟时间。
tips:u-boot compilation process will take a few minustes or so。
![](https://file.elecfans.com/web2/M00/66/0C/poYBAGMOFFeAbOP-AACVTDWILNQ485.jpg)
目标文件(target file)编译完成后通过ls命令即可看到编译得到的目标文件u-boot.bin
you can get the compiled file u-boot.bin with ls command after compilation
$ ls
![](https://file.elecfans.com/web2/M00/66/A6/pYYBAGMOFFeATo8FAAB3NtvCZmM640.jpg)
编译内核(compile kernel)
进入内核源码目录(enter kernel source directory)$ cd ~/my-imx6/02_source/imx_3.0.35_4.1.0/linux-3.0.35/
![](https://file.elecfans.com/web2/M00/66/0C/poYBAGMOFFeAShuSAAAh6DzHWjY457.jpg)
$ echo $ARCH
$ ${CROSS_COMPILE}gcc –v
准备配置内核(prepare for kernel configuration)remove kernel configuration
$ make distclean
![](https://file.elecfans.com/web2/M00/66/A6/pYYBAGMOFFuAXQbwAAAN3asmClg799.jpg)
generated.config file
说明:MY-IMX6-EK200系列评估板及MY-IMX6-EK314系列评估板使用的配置文件是myimx6_defconfig
instructions:configuration files used for MY-IMX6-EK200 seires of evaluation board and MY-IMX6-EK314 series of evaluation board is myimx6_defconfig
$ make myimx6_defconfig
![](https://file.elecfans.com/web2/M00/66/A6/pYYBAGMOFFyAEsFxAABotJPel9A825.jpg)
编译内核(compile kernel)compile uImage
$ make uImage
说明:截图中使用了4线程编译。
instruction:4 threads compilation is used in the screenshots。
![](https://file.elecfans.com/web2/M00/66/0C/poYBAGMOFFyARZ1xAABJgn_rZnM659.jpg)
![](https://file.elecfans.com/web2/M00/66/0C/poYBAGMOFF-AamYdAACN6Yj03WY943.jpg)
target file
arch/arm/boot/uImage即为编译得到的目标文件,使用ls命令可查看文件信息。
arch/arm/boot/uImage is the target file through compilation,you can view the file information with ls command。
$ ls arch/arm/boot/uImage –la
![](https://file.elecfans.com/web2/M00/66/A6/pYYBAGMOFF-AAPQBAAAkf_wuaqQ699.jpg)
编译模块(compile module)compile
$ make
说明:截图中使用了4线程编译。
![](https://file.elecfans.com/web2/M00/66/0C/poYBAGMOFF-APNOmAABNvmutKoU016.jpg)
![](https://file.elecfans.com/web2/M00/66/0C/poYBAGMOFF-ARwjUAAAt4XOl6vM039.jpg)
target file
编译完成后各模块的.ko文件位于代码所在的目录,通过find命令可以找出编译完成的模块,参考命令如下:
.ko file of each module is in the directory where code is located after compilation ,you can find the module compiled with find command after compilation,refering command as below:
$ find -name *.ko
![](https://file.elecfans.com/web2/M00/66/A6/pYYBAGMOFGCAeIhvAABGJ9m5hGY649.jpg)
Linux应用程序编译(Linux application compilation)
编写应用程序(write application)1) 创建应用程序目录
create application directory
$ mkdir ~/my-imx6/02_source/application/ -p
$ cd ~/my-imx6/02_source/application/
![](https://file.elecfans.com/web2/M00/66/0C/poYBAGMOFGOACO-FAAAi7dKUxSc281.jpg)
2) 编写应用程序(这里以hello.c为例)
write application(here take hello.c as example
创建 hello.c 文件写入以下代码并保存:
create hello.c and write following code and save:
int main(int argc, char **argv)
printf("Hello, MYZR!n");
return;
3) 查看代码
view code
$ cat hello.c
![](https://file.elecfans.com/web2/M00/66/A6/pYYBAGMOFGOAMCEdAAAsvLAsacY463.jpg)
使编译配置文件生效(validate compiler configured file)execute source command
$ echo $ARCH
编译应用程序 (compile application)2) 编译
compile
$ ${CROSS_COMPILE}gcc hello.c -o hello.out
注意:上面的命令有包含“$”号,即“${CROSS_COMPILE}gcc”,是引用我们source时产生的环境变量。
note:the above commands contain charater“$”,e.g“${CROSS_COMPILE}gcc”,which is the environment variable generated when referring to our source。
![](https://file.elecfans.com/web2/M00/66/0C/poYBAGMOFGeARKOBAAAXB2RwBWg662.jpg)
3) 查看目标文件类型
view type of target file
$ file hello.out
可以看到目标文件 hello.out 的属性。
you can get the property of target file hello.out。
![](https://file.elecfans.com/web2/M00/66/A6/pYYBAGMOFGeAXCXRAAA2S7l8Rqg703.jpg)
文件系统(file system)
文件系统说明(file system instruction)文件系统包位于网盘对应的镜像文件夹中。支持的文件系统类型及下载方式可参照《MY-IMX6 烧录指导》。
file system package is located in image file folder in the network disk。as to type of file system supported and way of download please refer to《MY-IMX6 buring guide》。
解压文件系统到编译主机(decompress file system to compiler host)1)创建文件系统的目录并进入
create directory of file system and enter
$ mkdir ~/my-imx6/04_rootfs/ -p
$ cd ~/my-imx6/04_rootfs/
![](https://file.elecfans.com/web2/M00/66/A6/pYYBAGMOFGeAbzVhAAAa8ZAaB58057.jpg)
2)将文件系统复制到~/my-imx6/04_rootfs/目录
copy file system to ~/my-imx6/04_rootfs/directory
这一步骤自己采取相应的方式进行
this step ***ould be done in your own way
3)解压文件系统到指定目录
decompress file system to specified directory
$ mkdir rootfs
$ sudo tar jxf rootfs-linux.tar.bz2 -C rootfs
![](https://file.elecfans.com/web2/M00/66/0C/poYBAGMOFGeAHYd2AAAZ3rc4M2w189.jpg)
添加应用到文件系统(add application to file system)$ cp ~/my-imx6/02_source/application/hello.out rootfs/app_test/
![](https://file.elecfans.com/web2/M00/66/0C/poYBAGMOFGiAHC8WAAAexebmRxI159.jpg)
5)重新打包文件系统
re-pakcage file system
$ rm -rf rootfs-linux.tar.bz2
$ cd rootfs/
$ sudo tar cjf ../rootfs-linux.tar.bz2 *
![](https://file.elecfans.com/web2/M00/66/A6/pYYBAGMOFHOARqPoAAAnBOA12-Y375.jpg)
添加模块到文件系统(add module to file system)准备需要模块的.ko文件,其它请参照“添加应用到文件系统”。
prepare .ko file of module needed,as to other operations please refer to“add application to file system”。
