python学习小组
直播中
lee_st
13年用户 45163经验值
擅长:841961
私信 关注
python实战串口助手---5实现过程中的困惑
天终于有时间继续调试,可是在调试过程中添加运行代码时出现问题,希望哪位高人指点一下,谢谢。先上代码。
#! /usr/bin/env python
# -*- coding: utf-8 -*-
import time
import datetime
import threading
import binascii
import platform
import logging
import SerialDeal
import serialMainUI
if platform.system() == "Windows":
    from  serial.tools import list_ports
elif platform.system() == "Linux":
    import glob, os, re
import wx
import wx.xrc
logging.basicConfig(level=logging.DEBUG,
                    format='%(asctime)s %(filename)s[line:%(lineno)d] %(levelname)s %(message)s',
                    datefmt='%a, %d %b %Y %H:%M:%S')
class MainSerialUI(serialMainUI.serialFrame):
    def __init__(self, master=None):
        super(MainSerialUI, self).__init__()
        self.ser = None
        self.receive_count = 0
        self.receive_data = ""
        self.list_box_serial = None
    def __del__(self):
            try:
                self.ser.SetStopEvent()
            except:
                pass
    def m_openserOnButtonClick( self, event ):
        try:
            self.port = self.m_comset.GetValue()
            self.baudrate = self.m_comboBox2.GetValue()
            self.parity = self.m_comboBox3.GetValue()
            self.databit = self.m_comboBox4.GetValue()
            self.stopbit = self.m_comboBox5.GetValue()
            self.ser = SerialDeal.serDeal(Port=self.port,
                                           BaudRate=self.baudrate,
                                           ByteSize=self.databit,
                                           Parity=self.parity,
                                           Stopbits=self.stopbit)
            self.ser.open()
            if self.ser.alive:
                self.thread_read = threading.Thread(target=self.SerRead)
                self.thread_read.setDaemon(True)
                self.thread_read.start()
        except Exception as e:
            logging.error(e)
        event.Skip()
    def SerialRead(self):
        try:
            n = self.ser.inWaiting()
            if n:
                self.receive_data += self.ser.read(n).replace(binascii.unhexlify("00"), "")
            if self.thresholdValue <= len(self.receive_data):
                self.receive_count += 1
                    # 接收显示是否为Hex
                if self.m_rcvBox.get() == 1:
                    self.receive_data = self.space_b2a_hex(self.receive_data)
                self.m_rcvtext.insert("end", "[" + str(datetime.datetime.now()) + " - "
                                               + str(self.receive_count) + "]:n", "green")
                self.m_rcvtext.insert("end", self.receive_data + "n")
                self.m_rcvtext.see("end")
            logging.error(e)
            self.ser.stop()
            self.ser = None
    def m_clrRcvTextOnButtonClick( self, event ):
        self.m_rcvtext.Clear()
        event.Skip()
    def space_b2a_hex(self, data):
        格式化接收到的数据字符串
        示例:123 --> 31 32 33
        new_data_list = list()
        new_data = ""
        hex_data = binascii.b2a_hex(data)
        temp_data = ""
        for index,value in enumerate(hex_data):
            temp_data += value
            if len(temp_data) == 2:
                new_data_list.append(temp_data)
                temp_data = ""
        for index,value in enumerate(new_data_list):
            if index%25 == 0 and index != 0:
                new_data += "n"
            new_data += value
            new_data += " "
        return new_data
def main():
    App = wx.PySimpleApp()
    MainSerialUI().Show(True)
    App.MainLoop()
if __name__ == '__main__':
    main()
总是提示错误见下图
编译不能通过,所以编写的代码不能时时check,很是郁闷,百度查了,也是无果,求助于各位大神,谢谢!
        发稿与2018年1月23日
更多回帖
