Android论坛
直播中
小辉夜
8年用户 3经验值
私信 关注
[问答]
【求教】新人求问arduinolcd1602如何实现按键功能
#include
LiquidCrystal lcd(3, 2, 7, 6, 5, 4);
#define SensorPin 0            //pH meter Analog output to Arduino Analog Input 0
#define Offset 0.00            //deviation compensate
unsigned long int avgValue;     //Store the average value of the sensor feedback
int S1;
int S2;
int S3;
int S4;
int S5;
int S6;
void setup()
  pinMode(8, INPUT);
  pinMode(9, INPUT);
  pinMode(10, INPUT);
  pinMode(11, INPUT);
  pinMode(12, INPUT);
  pinMode(13, INPUT);
  Serial.begin(9600);
  Serial.prinOUTPUTtln("Ready");    //Test the serial monitor
void loop()
  int buf[10];                //buffer for read analog
  for (int i = 0; i < 10; i++) //Get 10 sample value from the sensor for smooth the value
    buf = analogRead(SensorPin);
    delay(10);
  for (int i = 0; i < 9; i++) //sort the analog from small to large
    for (int j = i + 1; j < 10; j++)
      if (buf > buf[j])
        int temp = buf;
        buf = buf[j];
        buf[j] = temp;
  avgValue = 0;
  for (int i = 2; i < 8; i++)               //take the average value of 6 center sample
    avgValue += buf;
  float phValue = (float)avgValue * 5.0 / 1024 / 6; //convert the analog into millivolt
  phValue = 3.5 * phValue + Offset;                //convert the millivolt into pH value
  Serial.print("    pH:");
  Serial.print(phValue, 2);
  Serial.println(" ");
  digitalWrite(13, HIGH);
  delay(800);
  digitalWrite(13, LOW);
  lcd.setCursor(0, 1);
  lcd.print("PH:");
  lcd.print(phValue, 2);
  if(digitalRead(9) == LOW)
    lcd.setCursor(10, 1);
    lcd.print("text");
  else
    lcd.print("meian");
一共6个按键,我该如何用  state将测得的值实现按按键1,进入text(校准界面)并且对当前数据调整
按键23对当前光标位变大变小。 按键45让光标左右移并且使按键23可以调整其他位置大小。6确定(退出调整)
回帖(1)
李志潘
2018-1-20 14:51:17
疯狂打call
举报
更多回帖
