CDB Cluster | Writes a cluster of complex, double-precision floating-point data to the specified channel. Modulation Toolkit VIs use the complex, double-precision floating-point cluster data type. Use this VI in applications that use Modulation Toolkit VIs. |
CDB WDT | Writes complex, double-precision floating-point data in a waveform data type to the specified channel. | 将复数,双精度浮点数据以波形数据类型写入指定的通道。 |
CDB | Writes complex, double-precision floating-point data to the specified channel. | 将复数,双精度浮点数据写入指定的通道。 |
更多回帖
