序号 | 产品规格 | 阻值 | 尺寸 | 精度 | 温度系数 | 功率 | 规格书 SPEC | |
1 | AR03ATC51R1 | 51.1Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
2 | AR03ATC52R3 | 52.3Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
3 | AR03ATC53R6 | 53.6Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
4 | AR03ATC54R9 | 54.9Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
5 | AR03ATC0560 | 56Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
6 | AR03ATC56R2 | 56.2Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
7 | AR03ATC57R6 | 57.6Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
8 | AR03ATC0590 | 59Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
9 | AR03ATC60R4 | 60.4Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
10 | AR03ATC61R9 | 61.9Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
11 | AR03ATC0620 | 62Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
12 | AR03ATC63R4 | 63.4Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
13 | AR03ATC64R9 | 64.9Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
14 | AR03ATC66R5 | 66.5Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
15 | AR03ATC0680 | 68Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
16 | AR03ATC68R1 | 68.1Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
17 | AR03ATC69R8 | 69.8Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
18 | AR03ATC71R5 | 71.5Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
19 | AR03ATC73R2 | 73.2Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
20 | AR03ATC0750 | 75Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
21 | AR03ATC75R5 | 75.5Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
22 | AR03ATC76R8 | 76.8Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
23 | AR03ATC78R7 | 78.7Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
24 | AR03ATC80R6 | 80.6Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
25 | AR03ATC0820 | 82Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
26 | AR03ATC82R5 | 82.5Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
27 | AR03ATC84R5 | 84.5Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
28 | AR03ATC86R6 | 86.6Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
29 | AR03ATC88R7 | 88.7Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 | |
30 | AR03ATC90R9 | 90.9Ω | 0603 | ±0.05% | ±25 ppm/℃ | 1/16W | 询价 |
更多回帖
