嵌入式技术论坛
直播中
冰冻的蝴蝶
8年用户 61经验值
擅长:嵌入式技术
私信 关注
PHP学员信息管理系统(分享)
  1. index.php        获取用户信息的表单
  2.
  3.                 <title>学生管理系统
  4.
  5.
  6.
  7.
  8.
    学生管理系统
  9.                 添加信息 |
  10.                 查看信息
  11.
  12.
    添加信息表单
  13.
  14.                         姓名:
  15.                         性别:
  16.
  17.                         年龄:
  18.                         手机
  19.                         邮箱:
  20.                         婚否: 已婚
  21.                                   未婚
  22.                         Q  Q:
  23.                         小组
  24.
  25.
  26.
  27.
  28.
  29. doAction.php        将用户信息存储到数据库中
  30.
  31.         //根据用户的动作,执行相应的操作
  32.         //1. 连接服务器,并判断是否成功
  33.                 $link = mysqli_connect("localhost","root","") or die("连接数据库失败!");
  34.
  35.         //2. 设置字符集
  36.                 mysqli_set_charset($link,"utf8");
  37.
  38.         //3. 选择数据库
  39.                 mysqli_select_db($link,"lamp165");
  40.
  41.         switch($_GET['a']){
  42.                 case "insert":        //用户添加操作
  43.
  44.                         //4. 定义sql语句,并发送执行
  45.
  46.                                 //获取用户提交的信息
  47.                                 $uname = $_POST['uname'];
  48.                                 $usex = $_POST['usex'];
  49.                                 $uage = $_POST['uage'];
  50.                                 $uphone = $_POST['uphone'];
  51.                                 $uemail = $_POST['uemail'];
  52.                                 $uhunfou = $_POST['uhunfou'];
  53.                                 $uqq = $_POST['uqq'];
  54.                                 $uteam = $_POST['uteam'];
  55.
  56.                                 $sql = "insert into stu (name,sex,age,phone,email,hunfou,qq,team) values
  57.                                 ('{$uname}','{$usex}',{$uage},'{$uphone}','{$uemail}','{$uhunfou}','{$uqq}','{$uteam}')";
  58.                                 $boolean = mysqli_query($link,$sql);
  59.
  60.                         //5. 判断是否执行成功
  61.                                 if($boolean!=false && mysqli_affected_rows($link)>0){
  62.
  63.                                         //告诉用户添加成功
  64.                                         echo "";
  65.
  66.                                 }else{
  67.
  68.                                         //告诉用户添加失败
  69.                                         echo "";
  70.                                         die;
  71.                                 }
  72.
  73.                         //6. 关闭数据库
  74.                                 mysqli_close($link);
  75.                 break;
  76.
  77.                 case "update":        //执行学生信息修改
  78.
  79.                         //获取要修改信息的学生的id号
  80.                         $id = $_GET['id'];
  81.
  82.                         //获取用户修改后的数据
  83.                         $uname = $_POST['uname'];
  84.                         $usex = $_POST['usex'];
  85.                         $uage = $_POST['uage'];
  86.                         $uphone = $_POST['uphone'];
  87.                         $uemail = $_POST['uemail'];
  88.                         $uhunfou = $_POST['uhunfou'];
  89.                         $uqq = $_POST['uqq'];
  90.                         $uteam = $_POST['uteam'];
  91.
  92.                         //定义sql语句,并发送执行
  93.                         $sql = "update stu set name='{$uname}',sex='{$usex}',age={$uage},phone='{$uphone}',email='{$uemail}',hunfou='{$uhunfou}',qq='{$uqq}',team='{$uteam}' where id={$id}";
  94.                         $boolean = mysqli_query($link,$sql);
  95.
  96.                         //判断是否修改成功
  97.                         if($boolean!=false && mysqli_affected_rows($link)>0){
  98.
  99.                                 //告知用户,修改成功
  100.                                 echo "";
  101.
  102.                         }else{
  103.
  104.                                 //告知用户,修改失败!
  105.                                 echo "";
  106.
  107.                         }
  108.
  109.                 break;
  110.
  111.                 case "delete":        //执行用户删除的动作
  112.
  113.                         //获取要删除的用户的id
  114.                         $id = $_GET['id'];
  115.
  116.                         //定义sql语句,并发送执行
  117.                         $sql = "delete from stu where id={$id}";
  118.                         $boolean = mysqli_query($link,$sql);
  119.
  120.                         //判断是否删除成功
  121.                         if($boolean!=false && mysqli_affected_rows($link)>0){
  122.
  123.                                 //告知用户,删除成功
  124.                                 echo "";
  125.
  126.                         }else{
  127.
  128.                                 //告知用户,删除失败
  129.                                 echo "";
  130.
  131.                         }
  132.
  133.                 break;
  134.         }
  135. ?>
  136. show.php        用于显示用户信息页面
  137.
  138.
  139.                 学生管理系统
  140.
  141.
  142.
  143.
  144.
    学生管理系统
  145.                 添加信息 |
  146.                 查看信息
  147.
  148.
    查看学生信息
  149.
  150.
  151.
  152.
  153.
  154.
  155.
  156.
  157.
  158.
  159.
  160.
  161.
  162.
  163.
  164.                                 //1. 连接服务器并判断是否成功
  165.                                         $link = mysqli_connect("localhost","root","") or die("连接数据库失败!");
  166.
  167.                                 //2. 设置字符集
  168.                                         mysqli_set_charset($link,"utf8");
  169.
  170.                                 //3. 选择数据库
  171.                                         mysqli_select_db($link,"lamp165");
  172.
  173.                                 //4. 定义sql语句,并发送执行
  174.                                         $sql = "select * from stu";
  175.                                         $result = mysqli_query($link,$sql);
  176.
  177.                                 //5. 解析结果集
  178.                                         if($result!=false && mysqli_num_rows($result)>0){
  179.
  180.                                                 //四种解析方式
  181.                                                 while($rows = mysqli_fetch_assoc($result)){
  182.
  183.                                                         echo "
  184. ";
  185.        echo "
  186. ";
  187.        echo "
  188. ";
  189.        echo "
  190. ";
  191.        echo "
  192. ";
  193.        echo "
  194. ";
  195.        echo "
  196. ";
  197.        echo "
  198. ";
  199.        echo "
  200. ";
  201.        echo "
  202. ";
  203.        echo "
  204. ";
  205.                                                         echo "
  206. ";
  207.
  208.                                                 }
  209.
  210.                                         }
  211.
  212.                                 //6. 释放结果集,关闭数据库
  213.                                         mysqli_free_result($result);
  214.                                         mysqli_close($link);
  215.                         ?>
  216.
  217. ID 姓名 性别 年龄 手机 邮箱 婚否 QQ 小组 操作
    {$rows['id']} {$rows['name']} ".($rows['sex']=='w'?'女':'男')." {$rows['age']} {$rows['phone']} {$rows['email']} ".($rows['hunfou']=='y'?'已婚':'未婚')." {$rows['qq']} {$rows['team']}
  218.        编辑
  219.        删除
  220.
  221.
  222.
  223. edit.php        用于修改用户信息的页面
  224.
  225.
  226.                 学生管理系统
  227.
  228.
  229.
  230.
  231.
    学生管理系统
  232.                 添加信息 |
  233.                 查看信息
  234.
  235.
    编辑学生信息
  236.
  237.                         //接收要修改学生的id号
  238.                         $id = $_GET['id'];
  239.
  240.                         //1. 连接数据库,并判断
  241.                         $link = mysqli_connect("localhost","root","") or die("数据库连接失败!");
  242.
  243.                         //2. 设置字符集
  244.                         mysqli_set_charset($link,"utf8");
  245.
  246.                         //3. 选择数据库
  247.                         mysqli_select_db($link,"lamp165");
  248.
  249.                         //4. 定义sql语句,并发送执行
  250.                         $sql = "select * from stu where id={$id}";
  251.                         $result = mysqli_query($link,$sql);
  252.
  253.                         //5. 解析结果集
  254.                         if($result!=false && mysqli_num_rows($result)>0){
  255.
  256.                                 //解析学生数据
  257.                                 $row = mysqli_fetch_assoc($result);
  258.                         }
  259.                 ?>
  260.
  261.                         姓名:
  262.                         性别: /> 女
  263.                                   /> 男
  264.                         年龄:
  265.                         手机:
  266.                         邮箱:
  267.                         婚否:/> 已婚
  268.                                   /> 未婚
  269.                         Q  Q:
  270.                         小组:
  271.
  272.
  273.
  274.
  275.                 //6. 关闭数据库,释放结果集
  276.                         mysqli_free_result($result);
  277.                         mysqli_close($link);
  278.                 ?>
  279.
  280.
如有疑问 欢迎探讨 QQ 2326308699
更多回帖
