FPGA|CPLD|ASIC论坛
直播中
wangkai1048
9年用户 6经验值
擅长:可编程逻辑 MEMS/传感技术 测量仪表 嵌入式技术
私信 关注
[问答]
你好,我想问一下如何把数字解调后的数据读到PC端,这是部分VHDL程序
-- Company:
-- Engineer:
-- Create Date:    11:13:45 03/09/2017
-- Design Name:
-- Module Name:    top - Behavioral
-- Project Name:
-- Target Devices:
-- Tool versions:
-- Description:
-- Dependencies:
-- Revision:
-- Revision 0.01 - File Created
-- Additional Comments:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_arith.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if instantiating
-- any Xilinx primitives in this code.
library UNISIM;
use UNISIM.VComponents.all;
entity top is
    Port (
               clk  : in   STD_LOGIC;
--                                        data_in : in  STD_LOGIC_VECTOR (13 downto 0);
--                                        clk8k: out STD_LOGIC;--AD时钟
--                                   dds_rdy  : OUT STD_LOGIC;
--                                        accumulate1_SCLR:IN STD_LOGIC;
--                                        accumulate1_S:OUT STD_LOGIC_VECTOR(31 downto 0);
--                                        accumulate2_SCLR:IN STD_LOGIC;
--                                        accumulate2_S:OUT STD_LOGIC_VECTOR(31 downto 0);
                                        pdb  : inout std_logic_vector(7 downto 0);
                                        astb : in std_logic;
                                        dstb : in std_logic;
                                        pwr  : in std_logic;
                                        pwait: out std_logic;
                                        Q: out  STD_LOGIC_VECTOR (31 downto 0)
end top;
architecture Behavioral of top is
COMPONENT dds
PORT (
    clk  : IN STD_LOGIC;
         ce        : IN STD_LOGIC;
    we   : IN STD_LOGIC;
         sclr : IN STD_LOGIC;
    data : IN STD_LOGIC_VECTOR(24 DOWNTO 0);
    cosine : OUT STD_LOGIC_VECTOR(13 DOWNTO 0);
         phase_out : OUT  std_logic_vector(24 downto 0)
END COMPONENT;
component accumulate1
port(
    CLK:In STD_LOGIC;
    A:IN STD_LOGIC_VECTOR(13 downto 0);
    B:IN STD_LOGIC_VECTOR(13 downto 0);
    CE:IN STD_LOGIC;
    SCLR:IN STD_LOGIC;
END component;
component accumulate2
port(
    CLK:In STD_LOGIC;
    CE:IN STD_LOGIC;
    SCLR:IN STD_LOGIC;
END component;
constant stEppReady        :        std_logic_vector(7 downto 0)        := "0000" & "0000" ;
constant stEppAwrA        :        std_logic_vector(7 downto 0)        := "0001" & "0100" ;
constant stEppAwrB        :        std_logic_vector(7 downto 0)        := "0010" & "0001" ;
constant stEppArdA        :        std_logic_vector(7 downto 0)        := "0011" & "0010" ;
constant stEppArdB        :        std_logic_vector(7 downto 0)        := "0100" & "0011" ;
constant stEppDwrA        :        std_logic_vector(7 downto 0)        := "0101" & "1000" ;
constant stEppDwrB        :        std_logic_vector(7 downto 0)        := "0110" & "0001" ;
constant stEppDrdA        :        std_logic_vector(7 downto 0)        := "0111" & "0010" ;
constant stEppDrdB        :        std_logic_vector(7 downto 0)        := "1000" & "0011" ;
        signal stEppCur        :        std_logic_vector(7 downto 0)        :=        stEppReady;
        signal stEppNext        :        std_logic_vector(7 downto 0)        ;
        signal clkMain                :        std_logic;    --u***时钟
        signal ctlEppWait        :        std_logic;
        signal ctlEppAstb        :        std_logic;
        signal ctlEppDstb        :        std_logic;
        signal ctlEppDir        :        std_logic;
        signal ctlEppWr        :        std_logic;
        signal ctlEppAwr        :        std_logic;
        signal ctlEppDwr        :        std_logic;
        signal busEppOut        :        std_logic_vector(7 downto 0);
        signal busEppIn        :        std_logic_vector(7 downto 0);
        signal busEppData        :        std_logic_vector(7 downto 0);
        signal regEppAdr        :        std_logic_vector(3 downto 0);
        -- Registers
        signal regData0 : std_logic_vector(7 downto 0);
        signal regData1 : std_logic_vector(7 downto 0);
         signal regData2 : std_logic_vector(7 downto 0);
         signal regData3 : std_logic_vector(7 downto 0);
         signal regData4 : std_logic_vector(7 downto 0);
        signal regData5 : std_logic_vector(7 downto 0);
        signal regData6 : std_logic_vector(7 downto 0);
        signal regData7 : std_logic_vector(7 downto 0);
        signal regLed : std_logic_vector(7 downto 0);
signal dout1,dout2,data_out,sine,cosine  : std_logic_vector(13 downto 0);--dout1是参考sine dout2是参考cosine  data_out是AD转换后序列
----signal cntr: std_logic_vector(23 downto 0);
signal dds_we,dds_sclr,dds_ce,clk_8k : std_logic;
signal accumulate1_ce,accumulate2_ce,rdy: std_logic;
signal flag: std_logic:='1';
signal dds_data,phase_out: std_logic_vector(24 downto 0);
signal dataout1,dataout2  : std_logic_vector(31 downto 0);
begin
        ctlEppAstb <= astb;
        ctlEppDstb <= dstb;
        ctlEPPWr          <= pwr;
        pwait      <= ctlEppWait;
        busEppIn   <= pdb;
        pdb        <= busEppOut When ctlEppWr = '1' and ctlEppDir = '1' else "ZZZZZZZZ";
        busEppOut  <= "0000" & regEppAdr When ctlEppAstb = '0' else busEppData;   --选择地址或数据xuantong
--        rgLed      <= choose_freq(3 downto 0);
--        ldg        <= '1';
   ctlEppWait <= stEppCur(0);
        ctlEppDir  <= stEppCur(1);
        ctlEppAwr  <= stEppCur(2);
        ctlEppDwr  <= stEppCur(3);
        busEppData <= regData0 when regEppAdr = "0000" else
        regData1 when regEppAdr = "0001" else
        regData2 when regEppAdr = "0010" else
        regData3 when regEppAdr = "0011" else
        regData4 when regEppAdr = "0100" else
        regData5 when regEppAdr = "0101" else
        regData6 when regEppAdr = "0110" else
        regData7 when regEppAdr = "0111" else
        "00000000";
Inst_dds : dds
  PORT MAP (
     clk => clk_8k,
          sclr=>flag,
          ce=>not flag,
     we =>not flag,
     data => dds_data,
          rdy=>rdy,
    cosine => cosine,
    sine => sine,
         phase_out => phase_out
Inst_accumulate1 : accumulate1
port map (
CLK=>clk_8k,    --成累加一次周期
A=>dout1,
B=>dout2,
CE=>rdy,
SCLR=> flag,
S=>dataout1
--Inst_accumulate2 : accumulate2
--port map (
--CLK=>clk_8k,    --成累加一次周期
--A=>dout2,
--B=>data_out,
--CE=>rdy,
--SCLR=> reset,
--S=>dataout2
dout1(13) <= not sine(13);
dout1(12 downto 0) <= sine(12 downto 0);
dout2(13) <= not cosine(13);
dout2(12 downto 0) <= cosine(12 downto 0);
process
variable count: integer :=0 ;
begin
wait until  clk'Event and clk='1';                                        --设置周期采样点个数
                if (count<500)
                        then  count:=count+1;
      else
                   clk_8k<=not clk_8k;
                          count:=0;
      end if;
end process;
process
begin
        --设置解调周期
                if (count<=8000)
                        then  flag<='1';
                        count:=count+1;
      elsif (80000                   then flag<='0';        --结束标志
                          count:=count+1;
                else count:=0;
end if;
end process;
process (clk)
                begin
                        if clk = '1' and clk'Event then
                                stEppCur <= stEppNext;
                        end if;
                end process;
        process (stEppCur, stEppNext, ctlEppAstb, ctlEppDstb, ctlEppWr)
                begin
                        case stEppCur is
                                When stEppReady =>
                                        if ctlEppAstb = '0' then
                                                if ctlEppWr = '0' then
                                                        stEppNext <= stEppAwrA;   --ctlEppNext=1读
                                                else
                                                        stEppNext <= stEppArdA;
                                                end if;
                                        elsif ctlEppDstb = '0' then
                                                        stEppNext <= stEppDwrA;
                                                else
                                                        stEppNext <= stEppDrdA;
                                                end if;
                                        else
                                                stEppNext <= stEppReady;
                                        end if;
                When stEppAwrA =>
                        stEppNext <= stEppAwrB;
                When stEppAwrB =>                                -- xie地址线
                        else
                        end if;
                When stEppArdA =>
                        stEppNext <= stEppArdB;
                When stEppArdB =>
                        if ctlEppAstb = '0' then                         --读地址线
                        else
                        end if;
                When stEppDwrA =>
                        stEppNext <= stEppDwrB;
                When stEppDwrB =>                                                        --写数据线
                        else
                        end if;
                When stEppDrdA =>
                        stEppNext <= stEppDrdB;
                When stEppDrdB =>
                        if ctlEppDstb = '0' then                         --写地址线
                        else
                        end if;
                When others =>
        end case;
        end process;
        process (clk, ctlEppAwr)                        --?
                begin
                                if ctlEppAwr = '1' then
                                        regEppAdr <= busEppIn (3 downto 0);
                                end if;
                        end if;
        end process;
        process (clk, regEppAdr, ctlEppDwr, busEppIn)
                begin
                                if ctlEppDwr = '1' and regEppAdr = "0001" then  --地址为1时,写入控制第一个dds
                                        regData1 <= dataout1(7 downto 0);   --这里怎么写?
                                end if;
                        end if;
                end process;
                begin
                                if ctlEppDwr = '1' and regEppAdr = "0010" then --地址为2
                                        regData2 <= dataout1(15 downto 8);
                                end if;
                        end if;
                end process;
                begin
                        if clk= '1' and clk'Event then
                                if ctlEppDwr = '1' and regEppAdr = "0011" then --地址为3
                                        regData3 <= dataout1(23 downto 16);
                                end if;
                        end if;
                end process;
                begin
                                if ctlEppDwr = '1' and regEppAdr = "0100" then --地址为4
                                        regData4 <= dataout1(31 downto 24);
                                end if;
                        end if;
                end process;
Q <= dataout1;
--R <= dataout2;
dds_data <= "0000000000001000001100010"; --1k
--ad9240clk<=clk_8k;
--dds_ce<='1';
--dds_we <= '1';
--ce<='1';
--clk8k<=clk_8k;
--dds_rdy<=rdy;
--dds_sclr<=flag;
--dds_we<=not flag;
--dds_ce<=not flag;
--accumulate1_ce<=not flag;
--accumulate2_ce<=not flag;
end Behavioral;
已退回2积分
更多回帖
