电脑综合技术区
400万+工程师在用
华为|鸿蒙开发者日
直播报名
400万+工程师在用
华为|鸿蒙开发者日
直播报名
电子发烧友网工程师
17年用户 16436经验值
擅长:可编程逻辑 MEMS/传感技术 测量仪表 模拟技术 控制/MCU RF/无线
私信 关注
FORMAT中的提示信息,FDISK中的提示信息
2008-10-25 11:18
<p><strong>FORMAT中的提示信息<br/></strong>&nbsp;Unable to write BOOT.&nbsp;&nbsp; 不能写引导扇区&nbsp;&nbsp; <br/>&nbsp;Invalid media type&nbsp;&nbsp; 无效的磁盘类型&nbsp;&nbsp; <br/>&nbsp;Parameters not supported&nbsp;&nbsp; 参数不支持&nbsp;&nbsp; <br/>&nbsp;Cannot format a network drive&nbsp;&nbsp; 不能格式化网络驱动器&nbsp;&nbsp; <br/>&nbsp;Invalid media or Track 0 bad - disk unusable&nbsp;&nbsp; <br/>&nbsp;无效的磁盘或0磁道损坏,磁盘不可用&nbsp;&nbsp; <br/>&nbsp;Format terminated&nbsp;&nbsp; 格式化终止&nbsp;&nbsp; <br/>&nbsp;Disk Boot failure&nbsp;&nbsp; 磁盘BOOT区错误&nbsp;&nbsp; <br/>&nbsp;Invalid system disk&nbsp;&nbsp; 无效的系统磁盘&nbsp;&nbsp; <br/>&nbsp;Disk I/O error,Replace the disk, and then <br/>&nbsp;press any key&nbsp;&nbsp;&nbsp;&nbsp; 磁盘I/O错误,请换盘后按任意键。通常在读写软盘时出现此类错误&nbsp;&nbsp; <br/>&nbsp;Non-System disk or disk error,Replace and strike any key when <br/>&nbsp;ready&nbsp;&nbsp; 无系统的磁盘或磁盘错误,请替换后按任意键&nbsp;&nbsp; <br/>&nbsp;Too many open files&nbsp;&nbsp; 打开的文件太多&nbsp;&nbsp; <br/>&nbsp;Access denied Insufficient memory&nbsp;&nbsp; 没有足够的内存访问被拒绝&nbsp;&nbsp; <br/>&nbsp;Invalid drive specification&nbsp;&nbsp; 无效的盘符说明&nbsp;&nbsp; <br/>&nbsp;Parse Error&nbsp;&nbsp; XX 分析错误 XX&nbsp;&nbsp; <br/>&nbsp;Incorrect MS-DOS version&nbsp;&nbsp; 不正确的MS-DOS版本&nbsp;&nbsp; <br/>&nbsp;X% percent completed&nbsp;&nbsp; 格式化正在进行,已经完成X%&nbsp;&nbsp; <br/>&nbsp;Format complete.&nbsp;&nbsp; 格式化完成&nbsp;&nbsp; <br/>&nbsp;XX bytes in bad sectors&nbsp;&nbsp; XX字节的坏扇区&nbsp;&nbsp; <br/>&nbsp;XX bytes total disk space&nbsp;&nbsp; 磁盘的全睰占湮猉X字节&nbsp;&nbsp; <br/>&nbsp;XX bytes available on disk&nbsp;&nbsp;&nbsp;&nbsp; 磁盘的可使用空间为XX字&nbsp;&nbsp; <br/>&nbsp;Volume label (11 characters, ENTER for none)?&nbsp;&nbsp; <br/>&nbsp;请输入磁盘卷标(总共11个字符,按回车为空)&nbsp;&nbsp; <br/>&nbsp;Format not supported on drive X Format&nbsp;&nbsp; 命令不支持驱动器X&nbsp;&nbsp; <br/>&nbsp;Invalid device parameters from device driver&nbsp;&nbsp; 无效的设备驱动参数&nbsp;&nbsp; <br/>&nbsp;Error writing FAT&nbsp;&nbsp; 写FAT表错误&nbsp;&nbsp; <br/>&nbsp;Error writing directory&nbsp;&nbsp; 写DIR目录表错误&nbsp;&nbsp; <br/>&nbsp;Cannot format an ASSIGN or SUBST drive&nbsp;&nbsp; <br/>&nbsp;不能格式化ASSIGN和SUBST指定的驱动器&nbsp;&nbsp; <br/>&nbsp;Cannot find System Files&nbsp;&nbsp; 没有找到系统文件&nbsp;&nbsp; <br/>&nbsp;Cannot format a network drive&nbsp;&nbsp;&nbsp;&nbsp; 不能格式化网络驱动器&nbsp;&nbsp; <br/>&nbsp;Invalid characters in volume labe&nbsp;&nbsp; l 磁盘卷标中存在非法字符&nbsp;&nbsp; <br/>&nbsp;Parameters not supported&nbsp;&nbsp; 参数不支持&nbsp;&nbsp; <br/>&nbsp;Format terminated&nbsp;&nbsp;&nbsp;&nbsp; 格式化意外终止&nbsp;&nbsp; <br/>&nbsp;Disk unsuitable for system disk&nbsp;&nbsp; 这个磁盘不适合作为系统盘&nbsp;&nbsp; <br/>&nbsp;Unable to write BOOT&nbsp;&nbsp; 不能写BOOT区&nbsp;&nbsp; <br/>&nbsp;Error reading directory&nbsp;&nbsp; 读DIR目录区错误&nbsp;&nbsp; <br/>&nbsp;No target drive specified&nbsp;&nbsp; 目的驱动器没有说明&nbsp;&nbsp; <br/>&nbsp;and press ENTER when ready&nbsp;&nbsp; 准备好后按回车键&nbsp;&nbsp; <br/>&nbsp;System transferred&nbsp;&nbsp; 系统传送完毕&nbsp;&nbsp; <br/>&nbsp;Enter current volume label for drive X&nbsp;&nbsp;&nbsp;&nbsp; 请为驱动器X输入磁盘的卷标&nbsp;&nbsp; <br/>&nbsp;Parameters not compatible with fixed disk&nbsp;&nbsp; 参数与硬盘不兼容&nbsp;&nbsp; <br/>&nbsp;Volume Serial Number is XXXX&nbsp;&nbsp;&nbsp;&nbsp; 分区格式化时随机产生的序列号是:XXXX&nbsp;&nbsp; <br/>&nbsp;Format broken&nbsp;&nbsp;&nbsp;&nbsp; 格式化被强行终止&nbsp;&nbsp; <br/>&nbsp;Format not available on drive XX&nbsp;&nbsp;&nbsp;&nbsp; 不能在驱动器XX上使用格式化命令&nbsp;&nbsp; <br/>&nbsp;on-System disk or disk error&nbsp;&nbsp; 没有系统盘或磁盘错误&nbsp;&nbsp; <br/>&nbsp;Bad Partition Table&nbsp;&nbsp;&nbsp;&nbsp; 错误的硬盘分区表&nbsp;&nbsp; <br/>&nbsp;Parameters not supported by drive&nbsp;&nbsp; 该驱动器不支持这些参数&nbsp;&nbsp; <br/>&nbsp;Insert DOS disk in drive A&nbsp;&nbsp; 请在驱动器A中插入DOS系统盘&nbsp;&nbsp; <br/>&nbsp;WARNING, ALL DATA ON NON-REMOVABLE DISK DRIVE %1: WILL BE <br/>&nbsp;LOST! Proceed with&nbsp;&nbsp; 警告:硬盘分区X中的所有数据都将丢失,确定执行格式化命令吗?<br/>Format another (Y/N)?!&nbsp;&nbsp;&nbsp;&nbsp; 还格式化其他盘吗&nbsp;&nbsp; <br/>&nbsp;Error reading partition table&nbsp;&nbsp; 读硬盘分区表错误&nbsp;&nbsp; <br/>&nbsp;Error writing partition table&nbsp;&nbsp;&nbsp;&nbsp; 写硬盘分区表错误&nbsp;&nbsp; <br/>&nbsp;Parameters not compatible&nbsp;&nbsp;&nbsp;&nbsp; 参数不匹配&nbsp;&nbsp; <br/>&nbsp;XX allocation units available on disk&nbsp;&nbsp; 磁盘上有XX可用簇&nbsp;&nbsp; <br/>&nbsp;XX bytes in each allocation unit&nbsp;&nbsp;&nbsp;&nbsp; 每个簇有大小为XX字节&nbsp;&nbsp; <br/>&nbsp;Same parameter entered twice&nbsp;&nbsp;&nbsp;&nbsp; 相同的参数被输入两次&nbsp;&nbsp; <br/>&nbsp;Must enter both /T and /N parameters&nbsp;&nbsp;&nbsp;&nbsp; /T和/N参数必须同时使用&nbsp;&nbsp; <br/>&nbsp;There is not enough room to create a restore file&nbsp;&nbsp;&nbsp;&nbsp; <br/>&nbsp;没有足够的空间来建立恢复文件&nbsp;&nbsp; <br/>&nbsp;You will not be able to use the UNFORMAT utility&nbsp;&nbsp;&nbsp;&nbsp; <br/>&nbsp;你将不能使用UNFORMAT工具来恢复你的硬盘数据&nbsp;&nbsp; <br/>&nbsp;There is not enough disk space for system files&nbsp;&nbsp;&nbsp;&nbsp; <br/>&nbsp;没有足够的空间来存储系统文件&nbsp;&nbsp; <br/>&nbsp;This disk cannot be unformatted&nbsp;&nbsp;&nbsp;&nbsp; 这个磁盘不能被反格式化&nbsp;&nbsp; <br/>&nbsp;There was an error creating the format recovery file&nbsp;&nbsp; <br/>&nbsp;在建立恢复文件时产生了一个错误&nbsp;&nbsp; <br/>&nbsp;Volume label is not supported with /8 parameter&nbsp;&nbsp; 该驱动器不支持/8参数&nbsp; <br/>&nbsp;Insufficient memory to load system files&nbsp;&nbsp; 没有足够的内存装入系统文件&nbsp;&nbsp; <br/>&nbsp;Insufficient memory.&nbsp;&nbsp; 内存不足&nbsp;&nbsp; <br/>&nbsp;Calculating free space (this may take several minutes)...&nbsp;&nbsp;&nbsp;&nbsp; <br/>&nbsp;正在统计磁盘空间(可能要花上几分钟时间) <br/><font face="Verdana"><strong><br/></p>
<p>FDISK中的提示信息<br/></strong>&nbsp;Delete Primary DOS Partition&nbsp;&nbsp; 删除主DOS分区&nbsp;&nbsp; <br/>&nbsp;Delete Extended DOS Partition&nbsp;&nbsp;&nbsp;&nbsp; 删除扩展DOS分区&nbsp;&nbsp; <br/>&nbsp;Delete Logical DOS Drive(s) in the Extended DOS Partition&nbsp;&nbsp; <br/>&nbsp;删除逻辑DOS分区&nbsp;&nbsp; <br/>&nbsp;WARNING! Data in the deleted Primary DOS Partition will be <br/>&nbsp;lost&nbsp;&nbsp; 警告:主DOS分区的数据将全部丢失&nbsp;&nbsp; <br/>&nbsp;WARNING! Data in the deleted Extended DOS Partition will be <br/>&nbsp;lost. Do you wish to continue (Y/N)?&nbsp;&nbsp;&nbsp;&nbsp; <br/>&nbsp;警告:扩展分区中的数据将全部丢失,你真的继续吗&nbsp;&nbsp; <br/>&nbsp;Delete Logical DOS Drive(s) in the Extended DOS Partition&nbsp;&nbsp;&nbsp;&nbsp; <br/>&nbsp;删除扩展分区下的逻辑分区&nbsp;&nbsp; <br/>&nbsp;WARNING! Data in a deleted Logical DOS Drive will be lost What <br/>&nbsp;drive do you want to delete? Are you sure (Y/N)?&nbsp;&nbsp;&nbsp;&nbsp; <br/>&nbsp;警告:逻辑分区中的所有数据都将丢失,你删除哪个驱动器?你真的确定吗&nbsp;&nbsp; <br/>&nbsp;display Partition Information&nbsp;&nbsp;&nbsp;&nbsp; 显示分区内容信息&nbsp;&nbsp; <br/>&nbsp;The Extended DOS Partition contains Logical DOS Drives.&nbsp;&nbsp;&nbsp;&nbsp; <br/>&nbsp;扩展DOS分区中包含DOS逻辑分区&nbsp;&nbsp; <br/>&nbsp;Do you want to display the logical drive information (Y/N)?&nbsp;&nbsp; <br/>&nbsp;你想显示逻辑分区的信息吗&nbsp;&nbsp; <br/>&nbsp;Display Logical DOS Drive Information&nbsp;&nbsp;&nbsp;&nbsp; 显示逻辑分区信息&nbsp;&nbsp; <br/>&nbsp;Enter partition size in Mbytes or percent of disk space (%) to <br/>&nbsp;create a Primary DOS Partition...&nbsp;&nbsp;&nbsp;&nbsp; 输入所建立主DOS分区的容量,单位是百分比&nbsp;&nbsp; <br/>&nbsp;Enter logical drive size in Mbytes or percent of disk space <br/>&nbsp;(%)...&nbsp;&nbsp;&nbsp;&nbsp; 请输入逻辑分区容量大小或磁盘空间的百分比&nbsp;&nbsp; <br/>&nbsp;Enter Volume Label?&nbsp;&nbsp;&nbsp;&nbsp; 请输入卷标&nbsp;&nbsp; <br/>&nbsp;Enter partition size in Mbytes or percent of disk space (%)to <br/>&nbsp;create an Extended DOS Partition....&nbsp;&nbsp;&nbsp;&nbsp; <br/>&nbsp;请输入扩展DOS分区的容量大小或磁盘空间的百分比&nbsp;&nbsp; <br/>&nbsp;Do you wish to use the maximum available size for a Primary <br/>&nbsp;DOS Partition&nbsp;&nbsp; 你想使用全部磁盘空间作为主DOS分区吗&nbsp;&nbsp; <br/>&nbsp;Change Current Fixed Disk Drive . Enter Fixed Disk Drive <br/>&nbsp;Number (X)&nbsp;&nbsp;&nbsp;&nbsp; <br/>&nbsp;当你挂接两个以上硬盘时,在FDISK的系统菜单中将多一个第5项,选择第5项时,将提示:请输入硬盘的序号&nbsp;&nbsp; <br/>&nbsp;Fixed Disk Drive Status&nbsp;&nbsp;&nbsp;&nbsp; 硬盘状态 <br/>&nbsp;Data in the deleted Primary DOS Partition will be lost.What <br/>&nbsp;primary partition do you want to delete?Do you wish to <br/>&nbsp;continue (Y/N)?&nbsp;&nbsp;&nbsp;&nbsp; DOS主分区中的数据将全部丢失。你准备删除哪个主分区?你想继续吗&nbsp;&nbsp; <br/>&nbsp;Data in the deleted Non-DOS Partition will be lost.What <br/>&nbsp;Non-DOS partition do you want to delete?Do you wish to <br/>&nbsp;continue (Y/N)?&nbsp;&nbsp;&nbsp;&nbsp; 非DOS分区的数据将全部丢失。你准备删除哪一个非DOS分区?你要继续吗&nbsp;&nbsp; <br/>&nbsp;You MUST restart your system for your changes to take effect&nbsp;&nbsp; <br/>&nbsp;&nbsp; 你必须重新启动你的计算机你所做的所有改变才有效&nbsp;&nbsp; <br/>&nbsp;Any drives you have created or changed must be formatted&nbsp;&nbsp; <br/>&nbsp;你新建的分区或改变的分区必须被格式化后才可用&nbsp;&nbsp; <br/>&nbsp;Shut down Windows before restarting&nbsp;&nbsp;&nbsp;&nbsp; 在重启之前请关闭Windows&nbsp;&nbsp; <br/>&nbsp;Your computer has a disk larger than 512 MB. This version of <br/>&nbsp;Windows includes improved support for large disks, resulting <br/>&nbsp;in more efficient use of disk space on large drives, and <br/>&nbsp;allowing disks over 2 GB to be formatted as a single drive&nbsp;&nbsp;&nbsp;&nbsp; <br/>&nbsp;你的计算机挂接了一个大于512M的硬盘。该版本的Windows支持大硬盘,能够更有效的使用大硬盘上的磁盘空间,并充许单个分区大于2GB <br/>&nbsp;Press Esc to exit FDISK 按Esc退出FDISK&nbsp;&nbsp; <br/>&nbsp;This drive is FAT16 by default, switch to fat32 (Y/N)?&nbsp;&nbsp;&nbsp;&nbsp; <br/>&nbsp;这个驱动器默认是FAT16模式,真的转换为FAT32模式吗&nbsp;&nbsp; <br/>&nbsp;This drive must be FAT32 because its size is &gt; 2048 MB&nbsp;&nbsp;&nbsp;&nbsp; <br/>&nbsp;当分区的空间大于2048MB时,这个分区必须使用FAT32磁盘数据格式&nbsp;&nbsp; <br/>&nbsp;This drive must be FAT16 because its size is too small to be <br/>&nbsp;FAT32&nbsp;&nbsp;&nbsp;&nbsp; 因为这个分区对于FAT32格式来说太小,所以这个分区只能使用FAT16格式&nbsp;&nbsp; <br/>&nbsp;Verifying drive integrity, complete&nbsp;&nbsp;&nbsp;&nbsp; 正在校验分区的完整性,完成&nbsp;&nbsp; <br/>&nbsp;Your computer has NTFS partitions which may require large <br/>&nbsp;drive support. If you are using another operating system, such <br/>&nbsp;as Windows NT, which supports large drives you should enable <br/>&nbsp;treating these partitions as large&nbsp;&nbsp;&nbsp;&nbsp; <br/>&nbsp;你的计算机有一个NTFS分区可能需要大分区支持,如果你正在使用其他操作系统,如Windows NT,你应该把这些分区分大一些 <br/>&nbsp;NOTE: If you answer Y and the partition display looks <br/>&nbsp;incorrect or a hang or crash occurs do nothing, run FDISK <br/>&nbsp;again, and answer N to this question&nbsp;&nbsp;&nbsp;&nbsp; <br/>&nbsp;注意:如果你回答Y,可能显示的分区信息看上去不正确或系统挂起或什么动作也没有,这时你可再次运行FDISK,对这个问题用N回答 <br/>&nbsp;Should NTFS partitions on all drives be treated as large <br/>&nbsp;(Y/N)?&nbsp;&nbsp;&nbsp;&nbsp; 对所有的NTFS分区使用大分区模式&nbsp;&nbsp; <br/>&nbsp;Drive deleted&nbsp;&nbsp;&nbsp;&nbsp; 驱动器被删除&nbsp;&nbsp; <br/>&nbsp;Partition made active&nbsp;&nbsp;&nbsp;&nbsp; 分区X被设置为活动&nbsp;&nbsp; <br/>&nbsp;Primary DOS Partition created&nbsp;&nbsp;&nbsp;&nbsp; 主DOS分区被建立&nbsp;&nbsp; <br/>&nbsp;Extended DOS Partition created&nbsp;&nbsp; 扩展DOS分区被建立&nbsp;&nbsp; <br/>&nbsp;Logical DOS Drive created, drive letters changed or added&nbsp;&nbsp;&nbsp;&nbsp; <br/>&nbsp;逻辑分区被建立,驱动器的盘符可能被改变或有新的增加&nbsp;&nbsp; <br/>&nbsp;No partitions defined&nbsp;&nbsp;&nbsp;&nbsp; 没有分区被定义&nbsp;&nbsp; <br/>&nbsp;No logical drives defined&nbsp;&nbsp;&nbsp;&nbsp; 没有逻辑驱动器被说明&nbsp;&nbsp; <br/>&nbsp;Drive letters have been changed or deleted&nbsp;&nbsp; 驱动器盘符已经被改变或删除&nbsp;&nbsp; <br/>&nbsp;No active partitions&nbsp;&nbsp; 没有设置活动分区,该硬盘不能被启动&nbsp;&nbsp; <br/>&nbsp;No fixed disks present&nbsp;&nbsp; 没有硬盘&nbsp;&nbsp; <br/>&nbsp;Error reading fixed disk&nbsp;&nbsp; 读硬盘错误&nbsp;&nbsp; <br/>&nbsp;Error writing fixed disk&nbsp;&nbsp; 写硬盘错误&nbsp;&nbsp; <br/>&nbsp;Write protect error writing fixed disk&nbsp;&nbsp; 写硬盘写保护错误&nbsp;&nbsp; <br/>&nbsp;Incorrect DOS version&nbsp;&nbsp; 不正确的DOS版本&nbsp;&nbsp; <br/>&nbsp;Cannot FDISK with network loaded&nbsp;&nbsp; 不能对网络驱动器使用FDISK&nbsp;&nbsp; <br/>&nbsp;No space to create a DOS partition&nbsp;&nbsp; 没有足够的空间建立DOS分区&nbsp;&nbsp; <br/>&nbsp;Requested logical drive size exceeds the maximum available <br/>&nbsp;space&nbsp;&nbsp; 输入的逻辑驱动器的容量超过了最大可用的磁盘空间容量&nbsp;&nbsp; <br/>&nbsp;Requested partition size exceeds the maximum available space&nbsp;&nbsp; <br/>&nbsp;&nbsp; 输入的分区的容量超过了最大可用的磁盘空间容量&nbsp;&nbsp; <br/>&nbsp;No partitions to delete&nbsp;&nbsp;&nbsp;&nbsp; 已经没有分区可以被删除&nbsp;&nbsp; <br/>&nbsp;The only startable partition on Drive is already set active&nbsp;&nbsp;&nbsp; <br/>&nbsp; 硬盘X上的惟一的可启动分区已经被标记为活动(扩展分区不能被设置为活动)&nbsp;&nbsp; <br/>&nbsp;No partitions to make active&nbsp;&nbsp;&nbsp;&nbsp; 没有分区可以被标记为活动分区&nbsp;&nbsp; <br/>&nbsp;Partition selected is not startable, active partition not <br/>&nbsp;changed&nbsp;&nbsp;&nbsp;&nbsp; 输入的分区X不可启动,当前的活动分区没有被改变&nbsp;&nbsp; <br/>&nbsp;Cannot create Extended DOS Partition without Primary DOS <br/>&nbsp;Partition on disk X&nbsp;&nbsp;&nbsp;&nbsp; 在硬盘X上没有主DOS分区时不能建立扩展DOS 分区&nbsp;&nbsp; <br/>&nbsp;All available space in the Extended DOS Partition is assigned <br/>&nbsp;to logical drives&nbsp;&nbsp;&nbsp;&nbsp; 扩展分区的全部有效空间都分配给逻辑驱动器吗?还可以再分为主分区或其他分区&nbsp;&nbsp; <br/>&nbsp;Cannot delete Extended DOS Partition while logical drives <br/>&nbsp;exist&nbsp;&nbsp;&nbsp;&nbsp; 因为扩展分区下有逻辑分区存在,所以扩展分区不能被删除&nbsp;&nbsp; <br/>&nbsp;All logical drives deleted in the Extended DOS Partition is <br/>&nbsp;not a choice. Please enter X&nbsp;&nbsp;&nbsp;&nbsp; 确定删除哪一个逻辑分区,请输入X&nbsp;&nbsp; <br/>&nbsp;WARNING! The partition set active is not startable&nbsp;&nbsp;&nbsp;&nbsp; <br/>&nbsp;警告:被设置为活动的分区是不可启动的&nbsp;&nbsp; <br/>&nbsp;Only non-startable partitions exist&nbsp;&nbsp;&nbsp;&nbsp; 只有不可启动的分区存在&nbsp;&nbsp; <br/>&nbsp;Only partitions on Drive 1 can be made active&nbsp;&nbsp;&nbsp;&nbsp; <br/>&nbsp;只有硬盘1上的分区可被设置为活动。当你挂接两个以上硬盘时,使用FDISK命令时只能设置硬盘1中的某个主分区为活动,其他硬盘上的主分区都不能设置为活动 <br/>&nbsp;Maximum number of Logical DOS Drives instalLED&nbsp;&nbsp;&nbsp;&nbsp; <br/>&nbsp;逻辑驱动器的所有盘符都使用,意思是你在分区时驱动器的盘符超过了Z&nbsp;&nbsp; <br/>&nbsp;Cannot create a zero size partition&nbsp;&nbsp;&nbsp;&nbsp; 不能建立大小空间为0的分区&nbsp;&nbsp; <br/>&nbsp;Unable to access Drive X&nbsp;&nbsp;&nbsp;&nbsp; 不能访问驱动器X&nbsp;&nbsp; <br/>&nbsp;Cannot delete Primary DOS Partition on drive 1 when an <br/>&nbsp;Extended DOS Partition exists&nbsp;&nbsp;&nbsp;&nbsp; 当扩展分区存在时不能删除硬盘1上的主DOS分区&nbsp;&nbsp; <br/>&nbsp;Invalid entry&nbsp;&nbsp;&nbsp;&nbsp; 无效的输入&nbsp;&nbsp; <br/>&nbsp;Volume label does not match&nbsp;&nbsp;&nbsp;&nbsp; <br/>&nbsp;标不匹配,当你删除分区时,系统会提示输入该分区的卷标,如果输入的巻标和你要删除的分区的卷标不一致时,操作将不能进行&nbsp;&nbsp; <br/>&nbsp;Cannot create Logical DOS Drive without an Extended DOS <br/>&nbsp;Partition on the current drive&nbsp;&nbsp;&nbsp;&nbsp; 没有扩展分区时不能在当前硬盘上建立逻辑驱动器&nbsp;&nbsp; <br/>&nbsp;Could not change partitions, because the disk could not be <br/>&nbsp;locked&nbsp;&nbsp; 不能改变分区,因为该硬盘不能被锁定&nbsp;&nbsp; <br/>&nbsp;Internal error&nbsp;&nbsp; 内部错误&nbsp;&nbsp; <br/>&nbsp;Incorrect MS-DOS version&nbsp;&nbsp; 不正确的MS-DOS版本&nbsp;&nbsp; <br/>&nbsp;Invalid parameter&nbsp;&nbsp; 无效的参数&nbsp;&nbsp; <br/>&nbsp;Cannot FDISK with network loaded&nbsp;&nbsp; 不能对网络驱动器进行FDISK&nbsp;&nbsp; <br/>&nbsp;The master boot code has NOT been updated<br/>&nbsp;/STATUS Displays partition information&nbsp;&nbsp; 主引导区代码没有被更新。显示分区信息&nbsp;&nbsp; <br/>&nbsp;/X Ignores extended disk-access support. Use this switch&nbsp;&nbsp; <br/>&nbsp;不使用扩展磁盘访问指令支持。当你使用&nbsp;&nbsp; <br/>&nbsp;if you receive disk access or stack oveRFlow messages&nbsp;&nbsp; <br/>&nbsp;这个参数时你将看到堆栈溢出的信息&nbsp;&nbsp; <br/>&nbsp;/MBR and /CMBR cannot both be specified&nbsp;&nbsp;&nbsp;&nbsp; <br/>&nbsp;/MBR和/CMBR这两个参数不能同时使用&nbsp;&nbsp; <br/>&nbsp;/MBR only operates on drive 1,use /CMBR for other drives&nbsp;&nbsp; <br/>&nbsp;只能对硬盘1使用,/CMBR对其他硬盘使用/MBR&nbsp;&nbsp; <br/>&nbsp;You must specify a drive number with /CMBR<br/>&nbsp;Invalid partition table&nbsp;&nbsp;&nbsp;&nbsp; 在使用/CMBR参数时必须说明硬盘的序号。无效的硬盘分区表&nbsp;&nbsp; <br/>&nbsp;Error loading operating system&nbsp;&nbsp; 在装入操作系统时错误&nbsp;&nbsp; <br/>&nbsp;Missing operating system&nbsp;&nbsp; 操作系统文件丢失&nbsp;&nbsp; <br/>&nbsp;stack overflow&nbsp;&nbsp; 堆栈溢出&nbsp;&nbsp; <br/>&nbsp;integer divide by 0&nbsp;&nbsp; 整数被0除&nbsp;&nbsp; <br/>&nbsp;run-time error&nbsp;&nbsp; 运行错误&nbsp;&nbsp; <br/>&nbsp;not enough space for environment&nbsp;&nbsp; 没有足够的空间</font></p><font face="Verdana"><strong>
<p>&nbsp;</p></strong></font>
更多回帖
打开APP
