我想通过24c02,led1602实现按K1键写一个数(数的大小要求在0到9999,这个程序是自己基于之前能正常实现功能但只能读写0到255的数的一段代码改的),按K2键屏幕显示之前写的数的数值。但是实际操作后每次读出来的数不是255就是511,不知道哪里出了问题,希望大家耐心帮帮忙看看哪边出了问题,谢谢!!!
unsigned char wordCode0[6] = "write:";
unsigned char wordCode1[6] = " read:";
void At24c02Write(unsigned char ,unsigned short int dat );
unsigned short int At24c02Read(unsigned char );
void Delay10ms(unsigned int c);
void main()
unsigned short int num0,num1 = 0,n;
LcdInit();
LcdWriteCom(0x80);
for(n=0; n<6; n++)
LcdWriteData(wordCode0[n]);
LcdWriteCom(0x80 + 0x40);
for(n=0; n<6; n++)
LcdWriteData(wordCode1[n]);
while(1)
if(K1 == 0)
Delay10ms(1);
if(K1 == 0)
At24c02Write(2,num0);
while((n < 50)&&(K3==0))
n++;
Delay10ms(1);
n=0;
if(K2 == 0)
Delay10ms(1);
if(K2 == 0)
num1 = At24c02Read(2);
while((n < 50)&&(K2 == 0))
n++;
Delay10ms(1);
n=0;
if(K3 == 0)
Delay10ms(1);
if(K3 == 0)
num0++;
if(K4 == 0)
Delay10ms(1);
if(K4 == 0)
num0--;
LcdWriteCom(0x87);
LcdWriteData('0' + (num0/1000));
LcdWriteData('0' + (num0%1000/100));
LcdWriteData('0' + (num0%1000%100/10));
LcdWriteData('0' + (num0%1000%100%10));
LcdWriteCom(0x87 + 0x40);
LcdWriteData('0' + (num1/1000));
LcdWriteData('0' + (num1%1000/100));
LcdWriteData('0' + (num1%1000%100/10));
LcdWriteData('0' + (num1%1000%100%10));
unsigned char a, b;
for (;c>0;c--)
for (b=38;b>0;b--)
for (a=130;a>0;a--);
void At24c02Write(unsigned char addr,unsigned short int dat)
unsigned short int a,b;
uchar c,d;
a=a|dat;
a=a>>8;
c=(uchar)a;
b=b|dat;
d=(uchar)b;
I2C_Start();
I2C_Sendbyte(0xa0);
ack();
I2C_Sendbyte(addr);
ack();
I2C_Sendbyte(c);
ack();
I2C_Sendbyte(d);
ack();
I2C_Stop();
unsigned short int At24c02Read(unsigned char addr)
unsigned short int num;
uchar e,f;
I2C_Start();
I2C_Sendbyte(0xa0);
ack();
I2C_Sendbyte(addr);
ack();
I2C_Start();
I2C_Sendbyte(0xa1);
ack();
e=I2C_Readbyte();
ack();
f=I2C_Readbyte();
I2C_Stop();
num=e;
num=num<<8;
num=num|f;
return num;
已退回4积分
2017-3-10 14:11:47
你写和读的时候要有延时,写到那个寄存处地址 就读哪个 这个还是很简单的 网上例子也多 不行可以换个驱动程序试一试,应该是时序的问题
举报
2017-3-10 17:10:18
at24C在读写一个byte的时候是byte操作,但是超过一个字节就是页操作了,对照规格书的页操作时序好好检查一下,估计是页操作的页地址和时序有问题。你自己翻书吧,总不能叫别人还翻书帮你查程序,那学到的经验是别人的又不是你的。
举报
