电子发烧友论坛|
有没有好心人帮忙把下面这个程序改一下,改成msp430f5529的,谢谢了#include //#include //#include #define uint unsigned int #define uchar unsigned char #include ***it qd=P2^0; void delay(unsigned int cnt); void UART_init (void) { EA = 1; ES = 1; PCON |= 0x80; //使能波特率倍速位SMOD SCON = 0x50; //8位数据,可变波特率 AUXR |= 0x40; //定时器1时钟为Fosc,即1T AUXR &= 0xfe; //串口1选择定时器1为波特率发生器 TMOD &= 0x0f; //清除定时器1模式位 TMOD |= 0x20; //设定定时器1为8位自动重装方式 TL1 = 0xFA; //设定定时初值 TH1 = 0xFA; //设定定时器重装值 ET1 = 0; //禁止定时器1中断 TR1 = 1; //启动定时器1 } //设置串口通讯的波特率,这里设置的是115200,11.0592晶振 void UART_R (void) interrupt 4 using 1 { unsigned char UART_data; RI = 0; UART_data = SBUF; } //设置串口中断函数 void UART_T (unsigned char UART_data) { SBUF = UART_data; while(ti == 0); TI = 0; }//串口发送字符函数 void UART_TC (unsigned char *str) { while(*str != ' |
