扫一扫,分享给好友
下面是我的程序,谢谢!
#include #define uint unsigned int #define uchar unsigned char #define CS_H P2OUT|=BIT2 #define CS_L P2OUT&=~BIT2 #define SID_H P2OUT|=BIT1 #define SID_L P2OUT&=~BIT1 #define SCLK_H P2OUT|=BIT0 #define SCLK_L P2OUT&=~BIT0 #define Number 32 static uint index = 0; static uint result[Number]; uchar flag=0; uchar zifu[10]={"0123456789"}; uint maxaver=0; long dis=0; double max=0,maxr=0; void delay(uchar z) { uint x,y; for(x = 110;x>0;x--) for(y = z;y>0;y--); } void Sys_init() { // uchar i; WDTCTL = WDTPW + WDTHOLD; if(CALBC1_8MHZ==0XFF || CALDCO_8MHZ==0XFF) { while(1); } BCSCTL1 = CALBC1_8MHZ; DCOCTL = CALDCO_8MHZ;//设置内部时钟8M // BCSCTL2 |= SELM_0; // BCSCTL2 |= DIVS_0; } void send_byte(uchar bbyte) { uchar i,temp; for(i=0;i<8;i++) { // P2DIR = 0xff; temp = bbyte & 0x80; if(temp) { SID_H; } else { SID_L; } SCLK_L; SCLK_H; bbyte = bbyte<<1; } } void LCD12864_write_cmd(uchar ddata) { uchar hdata,ldata; hdata = ddata & 0xf0; ldata = (ddata<<4) & 0xf0; CS_H; send_byte(0xf8); delay(5); send_byte(hdata); delay(1); send_byte(ldata); delay(1); CS_L; } void LCD12864_write_data(uchar ddata) { uchar hdata,ldata; hdata = ddata & 0xf0; ldata = (ddata<<4) & 0xf0; CS_H; send_byte(0xfa); delay(5); send_byte(hdata); delay(1); send_byte(ldata); delay(1); CS_L; } void LCD12864_init() { P2DIR |= BIT0 + BIT1 + BIT2; delay(10); CS_H; LCD12864_write_cmd(0x34); delay(1); LCD12864_write_cmd(0x30); delay(1); LCD12864_write_cmd(0x0c);// delay(1); LCD12864_write_cmd(0x01); delay(1); LCD12864_write_cmd(0x02); delay(1); } void LCD12864_pos(uchar x,uchar y) { uchar pos; switch(x) { case 1:pos = 0x80;break; case 2:pos = 0x90;break; case 3:pos = 0x88;break; case 4:pos = 0x98;break; default:pos = 0x80; } pos += y; LCD12864_write_cmd(pos); } void shuju() { uchar j; maxr = 0; maxaver = 0; for(j = 0;j < 64;j++) { if((result[j]>maxaver) && (result[j]<1024)) { maxaver = result[j]; } } maxr = (maxaver*3.56)/1023; max = maxr*10000; dis = max; LCD12864_pos(2,2); LCD12864_write_data(zifu[dis/10000]); LCD12864_write_data('.'); LCD12864_write_data(zifu[dis/1000%10]); LCD12864_write_data(zifu[dis/100%10]); LCD12864_write_data(zifu[dis/10%10]); LCD12864_write_data(zifu[dis%10]); } void IO_init(void) { P1REN = BIT0 + BIT1; P1OUT = 0x00; P1DIR |= BIT0 + BIT1 + BIT2 + BIT3; } void ADC_init(void) { ADC10CTL0 = ADC10ON + ADC10SHT_3 + MSC + ADC10IE + SREF_1 + REFON; ADC10CTL1 |= CONSEQ_2 + INCH_10; ADC10AE0 |= BIT0 + BIT1; ADC10CTL0 &=~ADC10IFG; // ADC10DTC1 = 0x40; } void main(void) { WDTCTL = WDTPW + WDTHOLD; // IO_init(); // P2DIR = 0XFF; P1DIR |= BIT3; P1SEL |= BIT3; LCD12864_init(); Sys_init(); ADC_init(); _EINT(); while(1) { ADC10CTL0 &=~ENC; while(ADC10CTL1 & ADC10BUSY); ADC10CTL0 |= ENC + ADC10SC;//启动 _NOP(); // ADC10SA = (unsigned int)aver; // ADC10CTL0&=~ADC10IFG; _BIS_SR(LPM0_bits + GIE); } } #pragma vector=ADC10_VECTOR __interrupt void ADC10_ISR(void) { // uint i; // // P2SEL = 0X00; result[index++] = ADC10MEM; // if(index == 32) // { shuju(); // } _NOP(); // shuju(); ADC10CTL0 &=~ADC10IFG; // _BIC_SR_IRQ(CPUOFF + GIE); } |
2个回答
这个是我写的 你参考一下
只有小组成员才能发言,加入小组>>
3327个成员聚集在这个小组
加入小组9556 浏览 1 评论
10355 浏览 1 评论
MSP430FR5994 使用库函数 定时器触发AD问题请教
10677 浏览 2 评论
请问怎么把下面51单片机的代码改成msp430 g2 pocket的代码,还有改下时间变成30秒
2657 浏览 1 评论
5114 浏览 1 评论
10685浏览 2评论
10365浏览 1评论
9567浏览 1评论
8223浏览 0评论
/9
GMT+8, 2025-12-2 16:47 , Processed in 0.715077 second(s), Total 81, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3314
