原程序是10Hz-100Hz的,有没有办法改成0.1-50Hz?下面的是程序#include
#define uchar unsigned char //宏定义 #define uint unsigned int ***it s1=P3^5; //定义按键的接口 ***it s2=P3^6; ***it s3=P3^7; ***it s4=P3^4; ***it led0=P3^0; //定义四个LED,分别表示不同的波形 ***it led1=P3^1; ***it led2=P3^2; ***it led3=P3^3; ***it lcdrs=P2^7; //液晶控制引脚,还有一个控制脚是RW,因为我们只需要向液晶里写数据系那是就好了,所以,我们直接将RW引脚接地 ***it lcden=P2^6; char num,boxing,u; //定义全局变量 uchar pinlv=100,bujin=1,bujin1=1; //频率初始值是10Hz,步进值默认是0.1,显示步进值变量 uchar code table[]="0123456789"; //定义显示的数组 uchar code table1[]="Fout= Wave form:"; //初始化显示字符 unsigned int m; //定义变量 m int a,b,h,num1; //定义全局变量 //自定义字符 uchar code zifu[]={ //此数组内数据为液晶上显示波形符号的自定义字符 0x0e,0x11,0x11,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x11,0x11,0x0e,0x00, //正弦波 0 1 0x00,0x07,0x04,0x04,0x04,0x04,0x1c,0x00, 0x00,0x1c,0x04,0x04,0x04,0x04,0x07,0x00, //矩形波 2 3 0x00,0x01,0x02,0x04,0x08,0x10,0x00,0x00, 0x00,0x10,0x08,0x04,0x02,0x01,0x00,0x00, //三角波 4 5 0x00,0x01,0x03,0x05,0x09,0x11,0x00,0x00, //锯齿波 6 }; uchar code sin[64]={ //此数组内的数据为,da输出对应电压值对应的数字量,0是0V,255是5V 135,145,158,167,176,188,199,209,218,226,234,240,245,249,252,254,254,253,251,247,243,237,230,222,213,204,193,182,170,158, 146,133,121,108,96,84,72,61,50,41,32,24,17,11,7,3,1,0,0,2,5,9,14,20,28,36,45,55,66,78,90,102,114,128 }; //正弦波取码 uchar code juxing[64]={ //一个周期是采样64个点, 所以数组内是64个数据 255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255, 255,255,255,255,255,255,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0 }; //矩形波取码 uchar code sanjiao[64]={ 0,8,16,24,32,40,48,56,64,72,80,88,96,104,112,120,128,136,144,152,160,168,176,184,192,200,208,216,224,232,240,248, 248,240,232,224,216,208,200,192,184,176,168,160,152,144,136,128,120,112,104,96,88,80,72,64,56,48,40,32,24,16,8,0 }; //三角波取码 uchar code juchi[64]={ 0,4,8,12,16,20,24,28,32,36,40,45,49,53,57,61,65,69,73,77,81,85,89,93,97,101,105,109,113,117,121,125,130,134,138,142, 146,150,154,158,162,166,170,174,178,182,186,190,194,198,202,206,210,215,219,223,227,231,235,239,243,247,251,255 }; //锯齿波取码 void delay(uint xms) //延时函数 { int a,b; for(a=xms;a>0;a--) for(b=110;b>0;b--); } void write_com(uchar com) //写命令函数 { lcdrs=0; P0=com; delay(1); lcden=0; delay(1); lcden=1; } void write_date(uchar date) //写数据函数 { lcdrs=0; P0=date; delay(1); lcden=0; delay(1); lcden=1; } //自定义字符集 void Lcd_ram() { uint i,j,k=0,temp=0x04; for(i=0;i<7;i++) { for(j=0;j<8;j++) { write_com(temp+j); write_date(zifu[k]); k++; } temp=temp+8; } } void init_lcd() //初始化函数 { uchar i; lcden=0; //默认开始状态为关使能端,见时序图 Lcd_ram(); write_com(0x01); //显示清屏,将上次的内容清除,默认为0x01. write_com(0x0f); write_com(0x38); //显示模式设置,默认为0x38,不用变。 write_com(0x0c); //显示功能设置0x0f为开显示,显示光标,光标闪烁;0x0c为开显示,不显光标,光标不闪 write_com(0x06); //设置光标状态默认0x06,为读一个字符光标加1. write_com(0x80); //设置初始化数据指针,是在读指令的操作里进行的 for(i=10;i<20;i++) //显示初始化 { write_date(table1[i]); //显示第一行字符 } write_com(0x80+40); //选择第二行 for(i=0;i<9;i++) { write_date(table1[i]); //显示第二行字符 } write_com(0x80+10); //选择第一行第十个位置 write_date(0); write_date(1); write_date(0); write_date(1); write_date(0); write_date(1); //显示自定义的波形图案 write_com(0x80+40+9); //选择第二行第九个位置 write_date(' '); write_date('1'); write_date('0'); write_date('.'); write_date('0'); write_date('H'); write_date('z'); //显示初始的频率值 } void initclock() //定时器初始化函数 { TMOD=0x10; //定时器的工作方式 TH0=a; TL0=b; //定时器赋初值 EA=1; //打开中断总开关 ET0=1; //打开定时器允许中断开关 TR0=1; //打开定时器定时开关 } void display() //显示函数 { uchar qian,bai,shi,ge; //定义变量用于显示 qian=pinlv/1000; //将频率值拆成一位的数据,将数据除以1000,得到的商是一位数,赋值给qian bai=pinlv%1000/100; //将频率除以1000的余数再除以100就得到了频率的百位,赋值给bai shi=pinlv%1000%100/10; //同上,得到频率的十位 ge=pinlv%1000/100%10; write_com(0x80+40+9); //选中第二行第九个位置 if(qian==0) //千位如果为0 write_date(' '); //不显示 else //千位不为0 write_date(table[qian]); //正常显示千位 if(qian==0&&bai==0) //千位和百位都为0 write_date(' '); //百位不显示 else //不都为0 write_date(table[bai]); //百位正常显示 write_date(table[shi]); //显示十位数 write_date('.'); //显示小数点 write_date(table[ge]); //显示个位 write_date('H'); //显示频率的单位Hz write_date('z'); if(boxing==0) //判断波形为正弦波 { write_com(0x80+10); //选中一行频率图案位置 write_date(0); //显示正弦波图案 write_date(1); write_date(0); write_date(1); write_date(0); write_date(1); led3=1; led0=0; //点亮正弦波指示灯 } if(boxing==1) //注释同上 { write_com(0x80+10); write_date(2); write_date(3); write_date(2); write_date(3); write_date(2); write_date(3); led0=1; led1=0; } if(boxing==2) { write_com(0x80+10); write_date(4); write_date(5); write_date(4); write_date(5); write_date(4); write_date(5); led1=1; led2=0; } if(boxing==3) { write_com(0x80+10); write_date(6); write_date(6); write_date(6); write_date(6); write_date(6); write_date(6); led2=1; led3=0; } } void keyscan() //频率调节键盘检测函数 { if(s1==0) //加按键是否按下 { EA=0; //关闭中断 delay(2); //延时去抖 if(s1==0) //再次判断 { while(!s1); //按键松开 pinlv+=bujin; //频率以步进值加 if(pinlv>1000) //最大加到100Hz { pinlv=100; //100Hz } display(); //显示函数 m=65536-(15000/pinlv);//计算频率 /*频率值最小是10Hz,pinlv的值是100(因为要显示小数点后一位),150000/100=1500,这个1500就是定时器需要计时的,单位是us,65536-1500得到的是定时器的初值, 先不管初值,先看定时时间,1500us,一个波形的周期是由64个定时组成的,所以,一个波形周期就是64*1500us=96000,也就是96ms,约等 于100ms,也就是10Hz的频率*/ a=m/256; //将定时器的初值赋值给变量 b=m%256; EA=1; //打开中断总开关 } } if(s2==0) //减按键按下 { delay(5); if(s2==0) { EA=0; while(!s2); pinlv-=bujin; //频率以步进值减 if(pinlv<100) { pinlv=100; } display(); m=65536-(15000/pinlv); a=m/256; b=m%256; EA=1; } } if(s3==0) //波形切换按键 { delay(5); if(s3==0) { EA=0; while(!s3); boxing++; //波形切换 if(boxing>=4) //4种波形 { boxing=0; } display(); EA=1; } } } void bujindisplay() //步进值设置界面显示程序 { uint bai,shi,ge; //定义步进值 百十个位 bai=bujin1/100; //将步进值除以100得到百位,也就是频率值的十位,因为有一个小数位 shi=bujin1%100/10; //将步进值除以100的余数除以十得到十位 ge=bujin1%100%10; //取余10后得到个位,也就是频率步进值的小数点后一位 write_com(0x80+11); //选中液晶第一行第十一列 if(bai==0) //百位是否为0 write_date(' '); //百位不显示 else //百位不为0 write_date(table[bai]); //显示百位数据 write_date(table[shi]); //显示十位数据 write_date('.'); //显示小数点 write_date(table[ge]); //显示个位,也就是小数点后一位 } void bujinjiance() //步进值设置键盘程序 { if(s4==0) //步进设置按键按下 { delay(5); //延时去抖 if(s4==0) //再次判断按键 { while(!s4); //按键释放,按键松开才继续向下执行 h++; //变量加 if(h==1) //进入设置状态时 { write_com(0x01); //清屏 write_com(0x80); //初始化显示步进设置界面 write_date('S');delay(1); //step value write_date('t');delay(1); write_date('e');delay(1); write_date('p');delay(1); write_date(' ');delay(1); write_date('v');delay(1); write_date('a');delay(1); write_date('l');delay(1); write_date('u');delay(1); write_date('e');delay(1); write_date(':');delay(1); bujin1=bujin; //步进值赋值给临时变量 bujindisplay(); //显示步进值 } if(h==2) //退出设置 { h=0; //清零 bujin=bujin1; //设置好的临时步进值赋值给步进变量 init_lcd(); //初始化液晶显示 initclock(); //定时器初始化 display(); //调用显示程序 } } } if(h==1) //设置步进值时 { if(s1==0) //加按键按下 { delay(5); //延时去抖 if(s1==0) //再次判断 { while(!s1); //按键释放 bujin1++; //步进值加1 if(bujin1>=101) //步进值最大100,也就是10.0Hz { bujin1=1; //超过最大值就恢复到0.1Hz } bujindisplay(); //步进显示 } } if(s2==0) //减按键,注释同上 { delay(5); if(s2==0) { while(!s2); bujin1--; //步进减 if(bujin1<=0) { bujin1=100; } bujindisplay(); } } } } void main() //主函数 { init_lcd(); //调用初始化程序 m=65536-(15000/pinlv); //定时器初值 a=m/256; b=m%256; initclock(); //定时器初始化 led0=0; //点亮第一个波形指示灯 while(1) //进入while循环,括号内为1,一直成立,所以也叫死循环,程序不会跳出,一直在内执行 { if(h==0) //正常模式不是步进调节 { keyscan(); //扫描按键 // display(); } bujinjiance(); //扫描步进调节程序 switch(boxing) //选择波形 { case 0 : P1=sin[u]; break; //正弦波 case 1 : P1=juxing[u]; break; //矩形波 case 2 : P1=sanjiao[u]; break; //三角波 case 3 : P1=juchi[u]; break; //锯齿波 } } } void T0_time()interrupt 1 //定时器 { TH0=a; TL0=b; //根据不同的初值,定时器定时时间不同,达到不同频率的目的 u++; //变量加 if(u>=64) //一个周期采样64个点, 所以加到64就清零 u=0; //u清零 } |
3个回答
你这样太复杂啦吧 直接可以写一个波形出来 不用定义数组 你这个要改变频率 你那个数组就要变化
/*******************************/ /*同时用两个定时器控制蜂鸣器发声, T0控制频率,T1控制同个频率持续的 时间,间隔两秒依次输出1,10,50,100, 200,400,800?1000的方波,设晶振频率为12MHZ*/ /****************************************/ #include #define uint unsigned int #define uchar unsigned char ***it beep=P2^3; uchar tt; uint fre,flag; void main() { fre=50000; beep=0; TMOD=0x11; TH0=(65536-fre)/256; TL0=(65536-fre)/256; TH1=(65536-50000)/256; TL0=(65536-50000)%256; EA=1; ET0=1; TR0=1; ET1=1; TR1=1; while(1); } void T0_timer() interrupt 1 { TR0=0; TH0=(65536-fre)/256; TL0=(65536-fre)/256; tt++; if(flag<40) 这里的40怎么算出来的 { if(tt==10) { tt=0; fre=50000;以及这里为什么是50000 beep=~beep; } } if(flag>=40&&flag<80)这里的40 ,80怎么算出来的 { tt=0; fre=50000; beep=~beep; } if(flag>=80&&flag<120) { tt=0; fre=10000;这里的10000怎么算出来 beep=~beep; } if(flag>=120&&flag<160)这里的120 160怎么算出来 { tt=0; fre=5000;这里的5000怎么算出来 beep=~beep; } if(flag>=160&&flag<200) { tt=0; fre=2500;这里的2500怎么算出来的 beep=~beep; } if(flag>=200&&flag<240)这里的200 240怎么算出来 { tt=0; fre=1250;这里的1250怎么算出来的 beep=~beep; } if(flag>=240&&flag<280)这里的240 280 怎么算出来的 { tt=0; fre=625;这里的625怎么算出来的 beep=~beep; } if(flag>=280&&flag<320)这里的280 320怎么算出来 { tt=0; fre=312;这里的312怎么算出来的 beep=~beep; } if(flag>=320&&flag<360)这里的320 360 怎么算出来的 { tt=0; fre=156;这里的156怎么算出来的 beep=~beep; } TR0=1; } void T1_timer() interrupt 3 { TH1=(65536-50000)/256; TL0=(65536-50000)%256; flag++; if(flag==360) { flag=0; fre=50000; } } 你试试这个 这个好理解 |
楼主程序查重吗
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
【瑞萨RA6E2】瑞萨E2S软件安装过程,等待过程玩下97_e2 studio_ZGZZ
140 浏览 0 评论
483 浏览 0 评论
【原创】【RA4M2-SENSOR开发板评测】低功耗+USB综合测试
815 浏览 0 评论
1346 浏览 2 评论
804 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
16904 浏览 31 评论
/9
GMT+8, 2025-12-2 19:51 , Processed in 0.616908 second(s), Total 79, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2156
