扫一扫,分享给好友
难道是我的程序问题吗,谁帮我看看啊,程序好长好长
1. Main.c #define uchar unsigned char #define uint unsigned int #include #include "led.h" #include "botton.h" #include "delay.h" #include "controlfunction.h" #include "feedback.h" ***it RC=P3^0; ***it A0=P3^1; ***it CE=P2^3; ***it CS=P3^3; ***it LED0=P2^0; ***it LED1=P2^1; ***it MOTOR=P2^2; extern uchar code hall[6]; extern uchar code zz[6]; extern uchar code fz[6]; extern uchar hal; extern uchar code seglednode[8]; extern uchar hal; char r=0; void main() { P1=0xff; P3=0xff; P2=0; P0=0; motor_set(); IE=0x83; IP=0; TMOD=0x01; led0(seglednode[0]); led1(seglednode[0]); sl(0); TR0=0; while(1){ } } 2. Led.c #include #include "led.h" #include "botton.h" #include "delay.h" uchar codeseglednode[8]={0x7e,0x30,0x6d,0x79,0x33,0x5b,0x5f,0x01}; uchar codespeednode[11]={0x7e,0x30,0x6d,0x79,0x33,0x5b,0x5f,0x70,0xff,0xfb}; extern char r; ***it LED0=P2^0; ***it LED1=P2^1; ***it SL1=P2^4; ***it SL2=P2^5; ***it SL3=P2^6; ***it SL4=P2^7; void led0(uchar seg){ LED0=1; P0=seg; LED0=0; } void led1(uchar seg){ LED1=1; P0=seg; LED1=0; } void sl(int result){ int buff; buff=result/1000; SL1=1; P0=speednode[buff]; SL1=0; buff=(result%1000)/100; SL2=1; P0=speednode[buff]; SL2=0; buff= (result%100)/10; SL3=1; P0=speednode[buff]; SL3=0; buff=result%10; SL4=1; P0=speednode[buff]; SL4=0; 3. Led.h #ifndef uchar #define uchar unsigned char #endif #ifndef uint #define uint unsigned int #endif void led0(uchar); void led1(uchar); void sl(int); 4. Feedback.c #include #include "delay.h" #include "led.h" #include "math.h" #define uchar unsigned char #define uint unsigned int ***it RC=P3^0; ***it A0=P3^1; ***it CE=P2^3; ***it CS=P3^3; ***it MOTOR=P2^2; ***it SL1=P2^4; ***it SL2=P2^5; ***it SL3=P2^6; ***it SL4=P2^7; float result=0.0; int bdata temp=0; extern char r; extern char oldr; extern uchar code seglednode[8]; void inti() {MOTOR=0; P0=0xff; CS=1; CE=0; } void adread() { inti(); CS=0; A0=0; RC=0; CE=1; { CE=0; RC=1; A0=0; CE=1; temp=P0; temp=temp<<4; CE=0; RC=1; A0=1; CE=1; temp+=P0>>4; } CE=0; CS=1; if(temp&0x800) {temp=temp&0x7ff; result=((float)temp)*0.837053571;} else{ temp=~temp+1; temp=temp&0x7ff; result=0-((float)temp)*0.837053571; } } 5. Feedback.h void adread(); extern float result; 6. Delay.asm PUBLIC _DELAY12_1MS SEG_US SEGMENT CODE RSEG SEG_US _DELAY12_1MS:MOV R6,#250 DELAYL0:NOP NOP DJNZ R6,DELAYL0 DJNZ R7,_DELAY12_1MS RET PUBLIC _DELAY12_100MS _DELAY12_100MS:MOV R5,#100 DELAYL1:MOV R6,#250 DELAYL2:NOP NOP DJNZ R6,DELAYL2 DJNZ R5,DELAYL1 DJNZ R7,_DELAY12_100MS RET PUBLIC NOP1 NOP1: NOP RET END 7. delay.h extern void delay12_1ms(char); extern void delay12_100ms(char); extern void nop1(void); #ifndef unchar #define unchar unsigned char #endif #ifndef unint #define unint unsinged int #endif 8. button.c #include #include "led.h" #include "botton.h" #include "delay.h" #include "pwm.h" extern char r; extern uchar code seglednode[8]; ***it MOTOR=P2^2; void check() interrupt 0 { //判断按键算法 if(OPEN==0&&r==0){ delay12_1ms(70); //防抖处理 if(OPEN==0){ r=1; TH0=65436/256; TL0=65436%256; TR0=1;} } else if(UP==0&&r>0){ delay12_1ms(100); if(UP==0) r++; if(r>=6) r=6; if(r<=-6) r=-6; } else if(UP==0&&r<0){ delay12_1ms(100); if(UP==0) r--; if(r>=6) r=6; if(r<=-6) r=-6; } else if(DOWN==0&&r>0){ delay12_1ms(100); if(DOWN==0) r--; if(r>=6) r=6; if(r<=-6) r=-6;} else if(DOWN==0&&r<0){ delay12_1ms(70); if(DOWN==0) r++; if(r>=6) r=6; if(r<=-6) r=-6; } else if(CPL==0){ delay12_1ms(100); if(CPL==0) r=0-r; } else if(CLOSE==0){ r=0;} else r=r; P1=0xff; if(r>=0){ led0(seglednode[0]); led1(seglednode[r]); } else{ led0(seglednode[7]); led1(seglednode[0-r]); } } 9. button.h #ifndef uchar #define uchar unsigned char #endif #ifndef uint #define uint unsigned int #endif ***it OPEN=P1^0; ***it UP= P1^1; ***it DOWN=P1^2; ***it CPL=P1^3; ***it CLOSE=P1^4; 10.controlfunction.c #define uchar unsigned char #define uint unsigned int #include #include "led.h" #include "botton.h" #include "delay.h" #include "pwm.h" #include "math.h" ***it LED0=P2^0; ***it LED1=P2^1; ***it MOTOR=P2^2; uchar codehall[6]={0x0a0,0x20,0x060,0x40,0xc0,0x80}; uchar codefz[6]={0x24,0x06,0x12,0x18,0x09,0x21}; uchar codezz[6]={0x18,0x09,0x21,0x24,0x06,0x12}; uchar hal; extern char r; extern float result; extern int sp; void motor_set(){ uchar i; hal=P1&0xe0; for(i=0;i<6;i++) if(hall==hal) break; MOTOR=1; if(r>0) P0=zz; else if(r<0) P0=fz; else P0=0; MOTOR=0; 11.controlfunction.h void motor_set(); 12.pid.c #include"reg51.h" #include "math.h" float error[3]={0,0,0}; extern float sum; int pid(int speed,float result) {float kp=0.9,ki=0.75,kd=0.05,ut=0; error[0]=(float)speed-fabs(result); sum=sum+(ki*error[0]); ut=sum+kp*error[0]+kd*(error[0]-error[1]); //ut=kp*(1.0+2.0*ki+0.5*kd)*(error[0])-kp*(1.0+kd)*error[1]+0.5*kp*kd*error[2]; //error[2]=error[1]; error[1]=error[0]; return (int)ut; 13.pwm.c #include #include "botton.h" #include "controlfunction.h" #include "delay.h" #include "led.h" #include "feedback.h" #include "math.h" #include #define uchar unsigned char #define uint unsigned int ***it RC=P3^0; ***it A0=P3^1; ***it CE=P2^3; ***it CS=P3^3; ***it LED0=P2^0; ***it LED1=P2^1; ***it MOTOR=P2^2; ***it SL1=P2^4; ***it SL2=P2^5; ***it SL3=P2^6; ***it SL4=P2^7; ***it check=P3^5; extern uchar code seglednode[8]; extern char r; extern uchar code hall[6]; extern uchar code zz[6]; extern uchar code fz[6]; extern uchar hal; extern float result; uchar count=0; uchar sc=0; uchar zys[6]={90,17,12,8,6,4}; uchar fys[6]={145,84,59,39,30,23}; intspeed[7]={0,220,370,530,750,960,1200}; int ys=100; int flag=100; int sp; float sum=0.0; extern float error[3]; int pid(int speed,float result); void dianji() interrupt 1 {char c; TR0=0; adread(); if(r>0) {c=r; sp=speed[c];} else {c=0-r; sp=0-speed[c];} ys=flag-pid(speed[c],fabs(result));//ys=ys-pid(speed[c],fabs(result));//ys=ys+(int)(0.8*((float)(result)-(float)(speed[c])));////// if(ys<=1&&r!=0) {ys=3; sum=0; flag=3; error[1]=0; error[0]=0;} if(ys>=150) {ys=100; flag=100; sum=0; error[1]=0; error[0]=0;} if((result>0&&sp<0)||result<0&&sp>0) ys=3; if(speed[c]==0&&((int)(fabs(result))-speed[c])<=10){ sl(0); ys=100; TR0=0; MOTOR=1; P0=0; MOTOR=0;} TH0=65436/256; TL0=65436%256; if(count==ys) {motor_set(); count=0; sc++;} count++; if(sc==2){ sl(abs((int)result)); sc=0; } check=~check; TR0=1; } |
1个回答
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
1477 浏览 3 评论
2772 浏览 1 评论
2999 浏览 0 评论
Protues中自己封装的芯片元件无Program File、Clock Frequency选项怎么解决,求求大神了!
4781 浏览 1 评论
基于51单片机的车辆倒车雷达报警系统,HC-SR04超声波测距,全套资料
1103 浏览 0 评论
GMT+8, 2024-9-28 01:19 , Processed in 0.557007 second(s), Total 78, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
