根據lemaker開發板手冊,先將系統燒到SD卡,想從SD卡啟動系統,串口打印信息如下,求前輩幫我看一下,燒寫成功沒,不甚感激了!!!
- bus_id 0
- bus_mfp 0
- pmu_id 3
- vddr_pmu_dcdc_cfg 4
- ddr_clk 468
- ddr_cap 1024
- ddr_bits_width 0
- rank 1
- ddr_type 0
- row_col 0
- rdodt 0
- wrodt 0
- zpzq 12
- rx_tx_adfu 0
- uart_id 3
- uart_baudrate 115200
- uart_pad 0
- jtag_pad 0
- bootdev 34
- version 1.1
- scan 1
- busid = 0bus_mfp = 0pmu_id = 3vddr_pmu_dcdc_cfg = 4
- ddr_clk = 0x1d4 ddr_cap = 400 ddr_bits_width = 0 rank = 1 ddr_type = 0 row_col = 0 rdodt = 0 wrodt = 0 zpzq = c, row_col_detect = 68
- consolse init :port 3, baudrate 115200 mfp 0
- pmu init
- g_current_bus = 00x51:0x8b3:0x8b3
- 0x39:0x325b:0x325b
- 0x14:0x88a
- VERSION A:set val = 0x84cf
- 0x14:0x84cf:0x84cf
- 0x62:0x0
- 0x15:0x6cae:0x6cae
- 0x16:0x334b:0x334b
- ATC2609A_PMU_SYS_CTL3 = 16512
- ,s2 flag = 0
- enter from s40x3f:0x1e3:0x1e3
- check adfu
- reg_val = 0x0ddr init
- ddr_cap = 0 row_col = 0 row_col_detect = 0
- DRAM init mode0,type0,2cs,x32,468MHz,0x0.@150616_R...Fail:0x8023,0x8023,0x8023,0x8023;0x0,0x0,0x0,0x0
- DRAM init mode0,type0,1cs,x32,468MHz,0x334d.@150616_R...Ok:1024MByte Cap.
- ddr size=1024MB
- load app
- load uboot: load address is 0x8000000, entry point is 0x8000040
- in fourth
- dvfs = 0xc583bb75
- SDC0 cfg:(MFP_CTL2=0x0 PAD_PULLCTL1=0x203e001)
- mmc->clock=187500
- low rate:0x100
- mmc->clock=50000000
- high:0x0
- boot sd/emmc init ok
- mmc cap:6737920
- ddr scan = 1
- dvfs maigc = 0x44564653, dvfs = 0xc583bb75ddr_clk = 0x1d4 ddr_cap = 400 ddr_bits_width = 0 rank = 1 ddr_type = 0 row_col = 0 rdodt = 0 wrodt = 0 zpzq = c, row_col_detect = 68
- mmc->clock=187500
- low rate:0x100
- error: SDC2 send CMD8, No rsp
- error: SDC2 send CMD55, No rsp
- go to try mmc card
- mmc->clock=52000000
- high:0x0
- mmc cap:6881280
- U-Boot 2015.04-g66e41a5 (Jan 16 2016 - 14:32:57)Actions-Semi
- DRAM: mem-size=1024MB
- 1 GiB
- PLL:core=0x311,dev=0x1164,bus=0x1c710000,bus1=0x2e004,display=0x164, spead=0x0
- MMC: ERROR: v7_dcache_inval_range - stop address is not aligned - 0x3deff448
- SD0: 0 (SD), eMMC: 1 (eMMC)
- Using default environment
- *** sd boot ***
- get_partition_info_efi: Invalid Argument(s)
- Failed to register mmc: 0:0
- not find update.zip, ret=0
- reading boot_logo.bmp.gz
- reading new_gamma_data
- fdtdec_get_hdmi_par: not support auto ,we used default vid = 1039136640
- EDID block 0 checksum error
- edid_checksum error!!!
- read edid err0
- parse hdmi edid information unsuccessfully
- In: serial
- Out: serial
- Err: serial
- Net: owl_mac
- Error: owl_mac address 65:76:7d:3a:24:7b illegal value
- , u***_ether
- Error: u***_ether address not set.
- Hit any key to stop autoboot: 0
- boot from mmc card ...
- reading uEnv.txt
- 177 bytes read in 3 ms (57.6 KiB/s)
- Loaded environment from uEnv.txt
- Running uenvcmd ...
- reading boot.scr
- ** Unable to read file boot.scr **
- reading uImage
- 5710784 bytes read in 495 ms (11 MiB/s)
- reading kernel.dtb
- 34456 bytes read in 7 ms (4.7 MiB/s)
- ## Booting kernel from Legacy Image at 00007fc0 ...
- Image Name: Linux-3.10.37
- Image Type: ARM Linux Kernel Image (uncompressed)
- Data Size: 5710720 Bytes = 5.4 MiB
- Load Address: 00008000
- Entry Point: 00008000
- Verifying Checksum ... OK
- ## Flattened Device Tree blob at 04000000
- Booting using the fdt blob at 0x4000000
- XIP Kernel Image ... OK
- Using Device Tree in place at 04000000, end 0400b697
- read_mi_head, line 430, magic 0x0, length 0, item num 0
- Starting kernel ...
- [ 0.000000] Booting Linux on physical CPU 0x0
- [ 0.000000] Initializing cgroup subsys cpu
- [ 0.000000] Initializing cgroup subsys cpuacct
- [ 0.000000] Linux version 3.10.37 (root@hayden-pc) (gcc version 4.7.3 20130328 (prerelease) (crosstool-NG linaro-1.13.1-4.7-2013.04-20130415 - Linaro GCC 2013.04) ) #2 SMP PREEMPT Sat Jan 16 14:33:53 CST 2016
- [ 0.000000] CPU: ARMv7 Processor [414fc091] revision 1 (ARMv7), cr=10c53c7d
- [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
- [ 0.000000] Machine: gs705a, model: Actions GS705A board
- [ 0.000000] owl_reserve: pyhsical memory size 1073741824 bytes, end @0x2f800000
- [ 0.000000] ion_reserve: ion_fb reserved base 1fb00000 size 255852544
- [ 0.000000] Reserved memory 342MB
- [ 0.000000] FB: 0x2f000000, 8MB
- [ 0.000000] KINFO: 0x2ef00000, 1MB
- [ 0.000000] ION0: 0x1fb00000, 244MB
- [ 0.000000] ION1: 0x19900000, 98MB
- [ 0.000000] cma: CMA: reserved 100 MiB at 19400000
- [ 0.000000] Memory policy: ECC disabled, Data cache writealloc
- [ 0.000000] owl_smp_init_cpus(): ncores 4
- [ 0.000000] PERCPU: Embedded 9 pages/cpu @c1497000 s13888 r8192 d14784 u36864
- [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 260624
- [ 0.000000] Kernel command line: console=ttyS3 clk_ignore_unused selinux=0 scandelay root=/dev/mmcblk0p2 rw console=tty0 rootfstype=ext4 console=ttyS3 rootwait boot_dev=sd0 hdmi_vid=4
- [ 0.000000] -------- boot_hdmi_vid_setup 4 --------
- [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
- [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
- [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
- [ 0.000000] allocated 2097152 bytes of page_cgroup
- [ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
- [ 0.000000] Memory: 1024MB = 1024MB total
- [ 0.000000] Memory: 662784k/662784k available, 385792k reserved, 270336K highmem
- [ 0.000000] Virtual kernel memory layout:
- [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
- [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
- [ 0.000000] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB)
- [ 0.000000] lowmem : 0xc0000000 - 0xef800000 ( 760 MB)
- [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
- [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
- [ 0.000000] .text : 0xc0008000 - 0xc0a42790 (10474 kB)
- [ 0.000000] .init : 0xc0a43000 - 0xc0aae640 ( 430 kB)
- [ 0.000000] .data : 0xc0ab0000 - 0xc0b38f94 ( 548 kB)
- [ 0.000000] .bss : 0xc0b38f94 - 0xc0c82204 (1317 kB)
- [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
- [ 0.000000] Preemptible hierarchical RCU implementation.
- [ 0.000000] NR_IRQS:247
- [ 0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
- [ 0.000000] Console: colour dummy device 80x30
- [ 0.000000] console [tty0] enabled
- [ 0.000000] kmemleak: Kernel memory leak detector disabled
- [ 0.002903] Calibrating delay loop... 405.50 BogoMIPS (lpj=2027520)
- [ 0.060324] pid_max: default: 32768 minimum: 301
- [ 0.060951] Security Framework initialized
- [ 0.061071] SELinux: Disabled at boot.
- [ 0.061147] AppArmor: AppArmor disabled by boot time parameter
- [ 0.061445] Mount-cache hash table entries: 512
- [ 0.084631] Initializing cgroup subsys debug
- [ 0.084740] Initializing cgroup subsys memory
- [ 0.084904] Initializing cgroup subsys freezer
- [ 0.085109] CPU: Testing write buffer coherency: ok
- [ 0.086223] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
- [ 0.086382] owl_smp_prepare_cpus(max_cpus:4)
- [ 0.086627] Setting up static identity map for 0xc0745038 - 0xc0745134
- [ 0.087035] L310 cache controller enabled
- [ 0.087120] l2x0: 16 ways, CACHE_ID 0x410080c9, AUX_CTRL 0x3e050000, Cache size: 524288 B
- [ 0.127145] ftrace: Allocated trace_printk buffers
- [ 0.206437] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
- [ 0.276435] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
- [ 0.346436] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
- [ 0.346877] Brought up 4 CPUs
- [ 0.347004] SMP: Total of 4 processors activated (1629.38 BogoMIPS).
- [ 0.347067] CPU: All CPU(s) started in SVC mode.
- [ 0.350193] devtmpfs: initialized
- [ 0.367023] pinctrl core: initialized pinctrl subsystem
- [ 0.378275] NET: Registered protocol family 16
- [ 0.477292] DMA: preallocated 14336 KiB pool for atomic coherent allocations
- [ 0.488640] sirq map 45 -> 213
- [ 0.488720] sirq map 46 -> 214
- [ 0.488789] sirq map 47 -> 215
- [ 0.498783] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
- [ 0.498884] hw-breakpoint: maximum watchpoint size is 4 bytes.
- [ 0.499655] free reserve pages 256 to buddy system
- [ 0.502563] dmm debugfs support
- [ 0.515450] i2c i2c-2: of_i2c: invalid reg on /i2c@b0178000/mpu6515@68
- [ 0.547617] bio: create slab at 0
- [ 0.552423] owl_dma b0260000.dma: actions AHB DMA Controller ( cpy slave memset ), 12 channels
- [ 0.562688] atc260x_i2c 0-0065: icm_ohm not config, use default value
- [ 0.562799] atc260x_i2c 0-0065: auxadc icm_ohm = 20
- [ 0.598735] atc260x-switch-ldo atc2603c-switch1.1: Probing atc2603c-switch1, id=1
- [ 0.598909] atc260x-switch-ldo atc2603c-switch1.1: pmic_ver=0
- [ 0.599194] [SWITCH1] set switch 1 to ldo mode Version D!
- [ 0.601615] atc260x-ext-pwm-dcdc atc2603c-ext-pwm-dcdc1.1: got init voltage selector 8
- [ 0.603234] atc260x-ext-pwm-dcdc atc2603c-ext-pwm-dcdc2.2: got init voltage selector 6
- [ 0.606765] atc2603c-sgpio atc2603c-sgpio.0: root virq num : 218
- [ 0.612816] atc260x-pm atc2603c-pm.0: _set_s2_mode() can not get of_property s2_mode
- [ 0.617243] [PM] set pmic suspend ops 0xc0afca08
- [ 0.618369] SCSI subsystem initialized
- [ 0.620398] asoc_spi0 b0200000.spi: master is unqueued, this is deprecated
- [ 0.622794] u***core: registered new interface driver u***fs
- [ 0.623066] u***core: registered new interface driver hub
- [ 0.623492] u***core: registered new device driver u***
- [ 0.623928] Linux video capture interface: v2.00
- [ 2.245816] Advanced Linux Sound Architecture Driver Initialized.
- [ 2.247771] Bluetooth: Core ver 2.16
- [ 2.247963] NET: Registered protocol family 31
- [ 2.248030] Bluetooth: HCI device and connection manager initialized
- [ 2.248129] Bluetooth: HCI socket layer initialized
- [ 2.248213] Bluetooth: L2CAP socket layer initialized
- [ 2.248352] Bluetooth: SCO socket layer initialized
- [ 2.249527] cfg80211: Calling CRDA to update world regulatory domain
- [ 2.253718] Switching to clocksource timer0
- [ 2.371752] NET: Registered protocol family 2
- [ 2.374031] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
- [ 2.374605] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
- [ 2.375164] TCP: Hash tables configured (established 8192 bind 8192)
- [ 2.375400] TCP: reno registered
- [ 2.375481] UDP hash table entries: 512 (order: 2, 16384 bytes)
- [ 2.375649] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
- [ 2.376681] NET: Registered protocol family 1
- [ 2.377840] RPC: Registered named UNIX socket transport module.
- [ 2.377932] RPC: Registered udp transport module.
- [ 2.377990] RPC: Registered tcp transport module.
- [ 2.378046] RPC: Registered tcp NFSv4.1 backchannel transport module.
- [ 2.379712] hw perfevents: enabled with ARMv7_Cortex_A9 PMU driver, 7 counters available
- [ 2.381478] owl_uart: no device is found
- [ 2.381968] b0120000.serial: ttyS0 at MMIO 0xb0120000 (irq = 61) is a OWL_SERIAL
- [ 2.383444] b0124000.serial: ttyS2 at MMIO 0xb0124000 (irq = 63) is a OWL_SERIAL
- [ 2.384844] b0126000.serial: ttyS3 at MMIO 0xb0126000 (irq = 64) is a OWL_SERIAL
- [ 3.083499] console [ttyS3] enabled
- [ 3.088296] b012a000.serial: ttyS5 at MMIO 0xb012a000 (irq = 66) is a OWL_SERIAL
- [ 3.097134] ## boot_dev: 0x20
- [ 3.102547] audit: initializing netlink socket (disabled)
- [ 3.108153] type=2000 audit(3.090:1): initialized
- [ 3.148048] NFS: Registering the id_resolver key type
- [ 3.153274] Key type id_resolver registered
- [ 3.157574] Key type id_legacy registered
- [ 3.163632] Key type cifs.spnego registered
- [ 3.168007] Key type cifs.idmap registered
- [ 3.172166] NTFS driver 2.1.30 [Flags: R/W].
- [ 3.178140] fuse init (API version 7.22)
- [ 3.183611] exFAT: Core Version 1.1.3
- [ 3.187385] exFAT: FS Version 1.1.3
- [ 3.191435] msgmni has been set to 968
- [ 3.201397] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
- [ 3.208946] io scheduler noop registered
- [ 3.212913] io scheduler deadline registered
- [ 3.217804] io scheduler cfq registered (default)
- [ 3.228007] #### insmod vde driver!
- [ 3.232466] mali0 b0280000.vde: Probe vde device
- [ 3.240652] mali0 b0280000.vde: resource: iomem: [mem 0xb0280000-0xb0280107] mapping to f8280000, irq 82
- [ 3.288844] owl_dss MMU: mmu_init: base 0xda200000 base_phys 0xc07a0b581a200000 free_info->addr 0xda200000
- [ 3.301275] owl pinctrl: 1pinmux_request_check_gpio
- [ 3.306363] owl pinctrl: 1CHECK PMX:P_LVDS_OBN has already been requested by owl-gpio:49
- [ 3.314572] owl_dss LCDC: error!lcdchw_parse_params, fail to get lcd reset gpio
- [ 3.322132] owl_dss LCDC: error!lcdchw_parse_params, fail to get lcd standby gpio
- [ 3.330676] current type lcd
- [ 3.337220] timings : xres 1920 yres 1080 size of 40 4
- [ 3.342712] Actions CEC for OWL Driver, (c) 2009 ACTIONS Electronics
- [ 3.350080] atm7059a-hdmi-cec b02c0000.hdmi_cec: probe successful
- [ 3.381138] brd: module loaded
- [ 3.384561] no blk dev
- [ 3.386959] read MiscInfoHeader failed
- [ 3.390738] read Head failed
- [ 3.393644] OWL_HDMI_ERR: failed to read hdcp key from secure storage
- [ 3.412719] loop: module loaded
- [ 3.419122] tun: Universal TUN/TAP device driver, 1.6
- [ 3.424299] tun: (C) 1999-2004 Max Krasnyansky
- [ 3.431348] u***core: registered new interface driver rtl8150
- [ 3.437362] u***core: registered new interface driver r8152
- [ 3.449888] GS705A phy init for dwc3 gadget 14:22:11
- [ 3.455803] GS705A phy init for dwc3 gadget 14:22:11
- [ 3.505030] aotg_hcd b0600000.u***: can't find u***h-1 dts node
- [ 3.510861] aotg_hcd b0600000.u***: aotg_hub_probe: u*** probe hcd failed, error is -19
- [ 3.519407] aotg_hcd b0700000.u***: can't find u***h-1 dts node
- [ 3.525286] aotg_hcd b0700000.u***: aotg_hub_probe: u*** probe hcd failed, error is -19
- [ 3.534141] port_host_plug_detect[0]:1
- [ 3.537934] port0_vubs_en:-1
- [ 3.541060] port_host_plug_detect[1]:1
- [ 3.544889] can't find vbus_otg1_en_gpio config
- [ 3.549454] port1_vubs_en:-1
- [ 3.552867] start mon 0 ......
- [ 3.556436] start mon 1 ......
- [ 3.559813] u***core: registered new interface driver cdc_acm
- [ 3.565578] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
- [ 3.573865] u***core: registered new interface driver u***-storage
- [ 3.580334] u***core: registered new interface driver u***serial
- [ 3.586420] u***core: registered new interface driver u***serial_generic
- [ 3.593111] u***serial: USB Serial support registered for generic
- [ 3.599372] u***core: registered new interface driver option
- [ 3.605165] u***serial: USB Serial support registered for GSM modem (1-port)
- [ 3.613598] mousedev: PS/2 mouse device common for all mice
- [ 3.620578] atc260x-onoff atc2603c-onoff.0: Probing atc2603c-onoff
- [ 3.626907] atc260x-onoff atc2603c-onoff.0: atc260x_onoff IRQ num : 216
- [ 3.634299] input: atc260x_onoff as /devices/b0170000.i2c/i2c-0/0-0065/atc2603c-onoff.0/input/input0
- [ 3.645710] u***core: registered new interface driver xpad
- [ 3.651333] u***core: registered new interface driver u***_acecad
- [ 3.657526] u***core: registered new interface driver aiptek
- [ 3.663285] u***core: registered new interface driver gtco
- [ 3.668929] u***core: registered new interface driver hanwang
- [ 3.674861] u***core: registered new interface driver kbtab
- [ 3.680536] u***core: registered new interface driver wacom
- [ 3.692715] atc260x-rtc atc2603c-rtc.0: rtc core: registered atc260x-RTC as rtc0
- [ 3.700738] atc260x-rtc atc2603c-rtc.0: invalid year(0), reset to year 2011
- [ 3.713003] atc260x-hwmon atc2603c-hwmon.0: Probing atc2603c-hwmon
- [ 3.722188] device-mapper: uevent: version 1.0.3
- [ 3.728192] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
- [ 3.737746] Bluetooth: HCI UART driver ver 2.2
- [ 3.742245] Bluetooth: HCI H4 protocol initialized
- [ 3.747142] Bluetooth: Realtek h5 driver version 1.0.1
- [ 3.752319] Realtek h5 driver version 1.0.1
- [ 3.756394] Bluetooth: HCI Realtek H5 protocol initialized
- [ 3.762094] HCI Realtek H5 protocol initialized
- [ 3.766508] rtk_btu***: Realtek Bluetooth USB driver module init, version 2.21
- [ 3.774174] u***core: registered new interface driver rtk_btu***
- [ 3.780406] cpuidle: using governor ladder
- [ 3.784617] cpuidle: using governor menu
- [ 3.789880] pinctrl-owl pinctrl.1: pin P_SD0_D0 already requested by b012a000.serial; cannot claim for b0230000.mmc
- [ 3.800489] pinctrl-owl pinctrl.1: pin-74 (b0230000.mmc) status -22
- [ 3.806865] pinctrl-owl pinctrl.1: could not request pin 74 on device pinctrl.1
- [ 3.814279] gl520x_mmc b0230000.mmc: Error applying setting, reverse things back
- [ 3.821877] ## host_id: 0 boot_dev 20 host->index: 0
- [ 3.827919] SDC0 use sdio uart conversion
- [ 3.832398] gl520x_mmc b0230000.mmc: using dma0chan2 for DMA transfers
- [ 3.840048] use GPIO to detect SD/MMC card
- [ 3.844998] ## host_id: 1 boot_dev 20 host->index: 1
- [ 3.850968] gl520x_mmc b0234000.mmc: using dma0chan3 for DMA transfers
- [ 3.859367] ## host_id: 2 boot_dev 20 host->index: 2
- [ 3.865425] gl520x_mmc b0238000.mmc: using dma0chan4 for DMA transfers
- [ 3.872977] leds-gpio leds.6: pins are not configured from the driver
- [ 3.879643] owl pinctrl: 1gpio_request_check_pinmux
- [ 3.884707] owl pinctrl: 1CHECK PMX:P_LVDS_ODP has already been requested by b02a0000.lcd0
- [ 3.894117] ledtrig-cpu: registered to indicate activity on CPUs
- [ 3.900903] hidraw: raw HID events driver (C) Jiri Kosina
- [ 3.914964] u***core: registered new interface driver u***hid
- [ 3.920594] u***hid: USB HID core driver
- [ 3.926272] zram: Created 1 device(s) ...
- [ 3.932037] ashmem: initialized
- [ 3.935943] logger: created 256K log 'log_main'
- [ 3.941167] logger: created 256K log 'log_events'
- [ 3.947080] logger: created 256K log 'log_radio'
- [ 3.952381] logger: created 256K log 'log_system'
- [ 3.962374] [SNDRV]:[atc2603a_get_cfg] Fail to get device_node
- [ 3.968681] [SNDRV]:[atc2603a_init] audio get cfg failed!
- [ 3.975126] [SNDRV]:[atc2603c_get_cfg] get gpio[speaker_en_gpios] fail
- [ 3.985668] [SNDRV]:[atm7059_audio_gpio_init] find i2s_switch_gpio property fail
- [ 3.993182] [SNDRV]:[atm7059_audio_gpio_init] find earphone_detect_gpios property fail
- [ 4.001600] [SNDRV]:[atm7059_audio_gpio_init] find speaker_en_gpios property fail
- [ 4.009250] [SNDRV]:[atm7059_link_init] maybe using irq
- [ 4.015062] soc-audio soc-audio: ASoC: machine atm7059_link should use snd_soc_register_card()
- [ 4.051063] acts_mmc_get_ro: Card read-only status -38
- [ 4.056422] mmc0: host does not support reading read-only switch. assuming write-enable.
- [ 4.065721] sd card init ok
- [ 4.068562] mmc_add_card: bootdev 0x20
- [ 4.072338] force sd0/sd1 host ext-card
- [ 4.076281] mmc0: new high speed SDHC card at address 1234
- [ 4.082408] ## md->name_idx: 0
- [ 4.086180] mmcblk0: sd_card SA08G 7.21 GiB
- [ 4.102208] GPT:Primary header thinks Alt. header is not at the end of the disk.
- [ 4.109895] GPT:7167999 != 15126527
- [ 4.113422] GPT:Alternate GPT header not at the end of the disk.
- [ 4.119532] GPT:7167999 != 15126527
- [ 4.123050] GPT: Use GNU Parted to correct GPT errors.
- [ 4.128338] mmcblk0: p1 p2
- [ 4.170195] atc2603c-audio atc260x-audio: ASoC: no dapm match for AOUT FL FR Mixer --> AOUT MIXER --> ADC0 Mux
- [ 4.180397] atc2603c-audio atc260x-audio: ASoC: Failed to add route AOUT FL FR Mixer -> AOUT MIXER -> ADC0 Mux
- [ 4.197873] soc-audio soc-audio: atc2603c-dai <-> owl-audio-i2s mapping ok
- [ 4.206968] soc-audio soc-audio: atm7059-hdmi-dai <-> owl-audio-i2s mapping ok
- [ 4.214603] mmc2: BKOPS_EN bit is not set
- [ 4.218867] u32 classifier
- [ 4.221625] Actions configured
- [ 4.224916] Netfilter messages via NETLINK v0.30.
- [ 4.227417] mmc_add_card: bootdev 0x20
- [ 4.227424] force sd2(emmc) host ext-card
- [ 4.227452] mmc2: new high speed DDR MMC card at address 0001
- [ 4.228228] ## md->name_idx: 1
- [ 4.228896] mmcblk1: emmc H8G1e 7.28 GiB
- [ 4.239987] mmcblk1: p1 p2
- [ 4.253341] nfnl_acct: registering with nfnetlink.
- [ 4.258429] nf_conntrack version 0.5.0 (11972 buckets, 47888 max)
- [ 4.266619] ctnetlink v0.93: registering with nfnetlink.
- [ 4.272141] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
- [ 4.279213] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
- [ 4.285776] xt_time: kernel timezone is -0000
- [ 4.290801] ip_tables: (C) 2000-2006 Netfilter Core Team
- [ 4.296825] TCP: cubic registered
- [ 4.300182] Initializing XFRM netlink socket
- [ 4.306532] NET: Registered protocol family 10
- [ 4.313483] mip6: Mobile IPv6
- [ 4.316716] ip6_tables: (C) 2000-2006 Netfilter Core Team
- [ 4.323002] sit: IPv6 over IPv4 tunneling driver
- [ 4.331553] NET: Registered protocol family 17
- [ 4.336251] NET: Registered protocol family 15
- [ 4.341012] Bridge firewalling registered
- [ 4.345681] Bluetooth: RFCOMM socket layer initialized
- [ 4.350871] Bluetooth: RFCOMM ver 1.11
- [ 4.354720] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
- [ 4.360716] Bluetooth: HIDP socket layer initialized
- [ 4.366039] l2tp_core: L2TP core driver, V2.0
- [ 4.370445] 8021q: 802.1Q VLAN Support v1.8
- [ 4.374797] lib80211: common routines for IEEE802.11 drivers
- [ 4.380769] Key type dns_resolver registered
- [ 4.386297] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
- [ 4.394167] ThumbEE CPU extension supported.
- [ 4.398778] train_Msize:1024, train_ces:1
- [ 4.442177] start:0xc0008000, end:0xc0a42790, checksum:0x620ff9b5
- [ 4.451151] fbdev info : xres 1920 yres 1080 refresh 60 name hdmi
- [ 4.457501] connected display to managers is fb0
- [ 4.768193] Console: switching to colour frame buffer device 240x67
- [ 4.864011] mmc0: Slot status change detected (0 -> 1)
- [ 4.897206] regulator-dummy: disabling
- [ 4.902742] atc260x-rtc atc2603c-rtc.0: setting system clock to 2011-01-01 00:00:15 UTC (1293840015)
- [ 4.917896] ATC260X_POWER: create sysfs for atc260x power
- [ 5.008344] clk: Not disabling unused clocks
- [ 5.020373] ALSA device list:
- [ 5.023393] #0: atm7059_link
- [ 5.374456]
- [ 5.374456] [power] No battery detected
- [ 5.394199] no blk dev
- [ 5.396679] read MiscInfoHeader failed
- [ 5.400639] read Head failed
- [ 5.403649] OWL_HDMI_ERR: failed to read hdcp key from secure storage
- [ 5.435874] [atc260x_u***_get_prop] first_power_on = false!
- [ 5.719748] OWL: Kernel Thermal management registered
- [ 7.404051] no blk dev
- [ 7.406517] read MiscInfoHeader failed
- [ 7.410436] read Head failed
- [ 7.413447] OWL_HDMI_ERR: failed to read hdcp key from secure storage
- [ 9.414051] no blk dev
- [ 9.416515] read MiscInfoHeader failed
- [ 9.420403] read Head failed
- [ 9.423389] OWL_HDMI_ERR: failed to read hdcp key from secure storage
- [ 11.424050] no blk dev
- [ 11.426512] read MiscInfoHeader failed
- [ 11.430400] read Head failed
- [ 11.433385] OWL_HDMI_ERR: failed to read hdcp key from secure storage
- [ 13.024653] EXT4-fs (mmcblk0p2): recovery complete
- [ 13.047530] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
- [ 13.056114] VFS: Mounted root (ext4 filesystem) on device 179:2.
- [ 13.063621] devtmpfs: mounted
- [ 13.067446] Freeing unused kernel memory: 428K (c0a43000 - c0aae000)
- Welcome to Debian GNU/Linux 8 (jessie)!
- Expecting device dev-ttyS3.device...
- [ OK ] Reached target Remote File Systems (Pre).
- [ OK ] Reached target Encrypted Volumes.
- [ OK ] Reached target Swap.
- [ OK ] Created slice Root Slice.
- [ OK ] Created slice User and Session Slice.
- [ OK ] Listening on /dev/initctl Compatibility Named Pipe.
- [ OK ] Listening on Delayed Shutdown Socket.
- [ OK ] Listening on Journal Socket (/dev/log).
- [ OK ] Listening on udev Control Socket.
- [ OK ] Listening on udev Kernel Socket.
- [ OK ] Listening on Journal Socket.
- [ OK ] Created slice System Slice.
- [ OK ] Created slice system-getty.slice.
- [ OK ] Created slice system-serialx2dgetty.slice.
- Starting Increase datagram queue length...
- Starting Create list of required static device nodes...rrent kernel...
- Starting Load Kernel Modules...
- Mounting Debug File System...
- Starting udev Coldplug all Devices...
- [ OK ] Reached target Slices.
- [ 14.735810] asoc_ethernet_init 3728
- [ 14.752394] read_mi_head, line 429, magic 0x0, length 0, item num 0
- [ OK ] Mounted Debug File System.
- [ 14.790893] no random-mac-address in dts
- [ OK ] Started Increase datagram queue length.
- [ 14.827352] phy_mode: 0
- [ OK ] Started Create list of required static device nodes ...current kernel.
- [ 14.861185] owl pinctrl: 1gpio_request_check_pinmux
- Starting Create Static Device Nodes in /dev...
- [ OK ] Listening on Syslog Socket.
- Starting Journal Service...
- [ OK ] Started Journal Service.
- [ 15.129420] RTL871X: module init start
- [ OK ] Started udev Coldplug all Devices.
- [ 15.165968] RTL871X: build time: Jan 16 2016 14:19:34
- [ OK ] Started Create Static Device Nodes in /dev.
- [ 15.202934] Wlan or BT power on, ref count:1
- Starting udev Kernel Device Manager...
- [FAILED] Failed to start Load Kernel Modules.
- [ 15.311624] mmc_add_card: bootdev 0x20
- [ 15.314852] systemd-udevd[146]: starting version 215
- See 'systemctl status systemd-modules-load.service' for details.
- [ OK ] Started udev Kernel Device Manager.
- Starting Copy rules generated while the root was ro...
- [ 15.449990] RTL871X: rtw_ndev_init(wlan0)
- Starting LSB: Set preliminary keymap...
- Mounting FUSE Control File System...
- Mounting Configuration File System...
- Starting Apply Kernel Variables...
- [ OK ] Mounted Configuration File System.
- [ OK ] Mounted FUSE Control File System.
- [ OK ] Started Copy rules generated while the root was ro.
- [ OK ] Started LSB: Set preliminary keymap.
- [ OK ] Started Apply Kernel Variables.
- Starting Remount Root and Kernel File Systems...
- [ OK ] Found device /dev/ttyS3.
- [ OK ] Started Remount Root and Kernel File Systems.
- [ 15.998160] atc260x-irkeypad atc2603c-irkeypad.0: size = 28
- Starting Load/Save Random Seed...
- [ OK ] Reached target[ 16.091734] input: atc2603c-irkeypad as /devices/b0170000.i2c/i2c-0/0-0065/atc2603c-irkeypad.0/input/input1
- Local File Systems (Pre).
- [ OK ] Reached target Local File Systems.
- Starting Create Volatile Files and Directories...
- [ 16.169816] ft5x06_hw_init 1078
- [ OK ] Reached target Remote File Sys[ 16.201510] SI paddr is f8270000tems.
- res->start is : 0xb0160020,resource size is 0x4
- [ 16.210759] owl pinctrl: 1gpio_request_check_pinmux
- Starting
- Trigger Flushing of Journal to Persistent Storage...
- [ 16.240753] owl pinctrl: 1gpio_request_check_pinmux
- Starting LSB: Set console font and keymap...
- [ OK ] Started Load/Save Random Seed.
- [ 16.335956] [drm] Initialized drm 1.1.0 20060810
- [ OK ] Started LSB: Set console font and keymap.
- [ OK ] Started Create Volatile Files and Directories.
- [ OK ] Reached target Sound Card.
- [ OK ] Created slice system-systemdx2dbacklight.slice.
- Starting Load/Save Screen Backlight Brightness of ba...:backlight.2...
- Starting Update UTMP about System Boot/Shutdown...
- Starting LSB: Raise network interfaces....
- [ OK ] Started Trigger Flushing of Journal to Persistent Storage.
- [ OK ] Started Load/Save Screen Backlight Brightness of bac...ht:backlight.2.
- [ OK ] Started Update UTMP about System Boot/Shutdown.
- [ OK ] Created slice system-ifup.slice.
- [ OK ] Created slice system-systemdx2drfkill.slice.
- Starting Load/Save RF Kill Switch Status of rfkill0...
- [ OK ] Started Load/Save RF Kill Switch Status of rfkill0.
- [ OK ] Started LSB: Raise network interfaces..
- Starting ifup for wlan0...
- [ OK ] Started ifup for wlan0.
- [ OK ] Reached target Network.
- [ OK ] Reached target Network is Online.
- [ OK ] Reached target System Initialization.
- [ OK ] Listening on D-Bus System Message Bus Socket.
- [ OK ] Reached target Timers.
- [ OK ] Listening on CUPS Printing Service Sockets.
- [ OK ] Reached target Sockets.
- [ OK ] Reached target Paths.
- Starting Restore Sound Card State...
- [ OK ] Reached target Basic System.
- Starting Deferred execution scheduler...
- [ OK ] Started Deferred execution scheduler.
- Starting Network Manager...
- Starting OpenBSD Secure Shell server...
- [ OK ] Started OpenBSD Secure Shell server.
- Starting Regular background program processing daemon...
- [ OK ] Started Regular background program processing daemon.
- Starting /etc/rc.local Compatibility...
- Starting Login Service...
- Starting LSB: Start NTP daemon...
- Starting D-Bus System Message Bus...
- [ OK ] Started D-Bus System Message Bus.
- Starting System Logging Service...
- Starting Permit User Sessions...
- [ OK ] Started Restore Sound Card State.
- [ OK ] Started /etc/rc.local Compatibility.
- [ OK ] Started LSB: Start NTP daemon.
- [ OK ] Started Permit User Sessions.
- [ OK ] Started System Logging Service.
- Starting Light Display Manager...
- Starting Getty on tty1...
- [ OK ] Started Getty on tty1.
- Starting Serial Getty on ttyS3...
- [ OK ] Started Serial Getty on ttyS3.
- [ OK ] Reached target Login Prompts.
- [ OK ] Started Login Service.
- [ OK ] Started Light Display Manager.
- Starting Authenticate and Authorize Users to Run Privileged Tasks...
- [ OK ] Started Authenticate and Authorize Users to Run Privileged Tasks.
- [ OK ] Started Network Manager.
- [ 21.937376] PVR_K: UM DDK-(3625561) and KM DDK-(3625561) match. [ OK ]
- [ OK ] Reached target Multi-User System.
- [ 21.963183] link status is: false
- [ 21.966524] InitFBinfo uiFBDevID: 0.
- [ 21.966730] eth0 link off.
- [ 21.966796] IRQ 32 requested
- [ 21.967537] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
- [ OK ] Reached target Graphical Interface.
- Starting Update UTMP about System Runlevel Changes...
- [ OK ] Started Update UTMP about System Runlevel Changes.
- Debian GNU/Linux 8 Lemuntu ttyS3
- Lemuntu login: [ 42.975746] EXT4-fs (mmcblk1p2): recovery complete
- [ 42.981237] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
- [ 43.061429] FAT-fs (mmcblk1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
- [ 43.576283] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
复制代码
