1、请问SimpleBLEPeripheral 例子里面,char5被设置成GATT_PERMIT_AUTHEN_READ,那么我应该怎么读取它呢?
2、在SimpleBLEPeripheral 例子里面有个读属性的回调函数simpleProfile_ReadAttrCB. static uint8 simpleProfile_ReadAttrCB( uint16 connHandle, gattAttribute_t *pAttr, uint8 *pValue, uint8 *pLen, uint16 offset, uint8 maxLen ) { bStatus_t status = SUCCESS; // If attribute permissions require authorization to read, return error if ( gattPermitAuthorRead( pAttr->permissions ) ) { // Insufficient authorization return ( ATT_ERR_INSUFFICIENT_AUTHOR ); } // Make sure it's not a blob operation (no attributes in the profile are long) if ( offset > 0 ) { return ( ATT_ERR_ATTR_NOT_LONG ); } if ( pAttr->type.len == ATT_BT_UUID_SIZE ) { // 16-bit UUID uint16 uuid = BUILD_UINT16( pAttr->type.uuid[0], pAttr->type.uuid[1]); switch ( uuid ) { // No need for "GATT_SERVICE_UUID" or "GATT_CLIENT_CHAR_CFG_UUID" cases; // gattserverapp handles those reads // characteristics 1 and 2 have read permissions // characteritisc 3 does not have read permissions; therefore it is not // included here // characteristic 4 does not have read permissions, but because it // can be sent as a notification, it is included here case SIMPLEPROFILE_CHAR1_UUID: case SIMPLEPROFILE_CHAR2_UUID: case SIMPLEPROFILE_CHAR4_UUID: *pLen = 1; pValue[0] = *pAttr->pValue; break; case SIMPLEPROFILE_CHAR5_UUID: *pLen = SIMPLEPROFILE_CHAR5_LEN; VOID osal_memcpy( pValue, pAttr->pValue, SIMPLEPROFILE_CHAR5_LEN ); break; default: // Should never get here! (characteristics 3 and 4 do not have read permissions) *pLen = 0; status = ATT_ERR_ATTR_NOT_FOUND; break; } } else { // 128-bit UUID *pLen = 0; status = ATT_ERR_INVALID_HANDLE; } return ( status ); } 当已经得到鉴定后,读char5时会执行上面的回调函数吗?如果会的话,当执行到红色部分时函数同样会返回ATT_ERR_INSUFFICIENT_AUTHOR??这样还是没法读取char5?? |
1个回答
建议你打开鉴权, 如果master没有主动发送鉴权请求, 可以发slave request来做
只有小组成员才能发言,加入小组>>
物联网工程师必备:怎么选择不同的无线连接技术,本指南帮你忙!
3813 浏览 1 评论
【DFRobot TinkerNode NB-IoT 物联网开发板试用连载】WIFI功能测试
4378 浏览 0 评论
【DFRobot TinkerNode NB-IoT 物联网开发板试用连载】Arduino的替代SublimeText3+STino
3854 浏览 0 评论
使用端口扩展器轻松高效地向IIoT端点添加具有成本效益的子节点
4585 浏览 1 评论
21379 浏览 11 评论
模组有时候复位重启后输出日志为“REBOOT_CAUSE_SECURITY_PMU_POWER_ON_RESET”的原因?
1602浏览 2评论
9219浏览 2评论
1557浏览 1评论
1977浏览 1评论
889浏览 1评论
/9
GMT+8, 2025-12-3 03:00 , Processed in 3.203853 second(s), Total 75, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
332
