扫一扫,分享给好友
我已完成以下代码,不知延时怎么加!大神求帮助! 求大神帮助!
library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; entity test4 is port (clk,clr,en : in std_logic; co : out std_logic; dout : out std_logic_vector(3 downto 0); m: out std_logic_vector(3 downto 0); SEGOUT : OUT STD_LOGIC_VECTOR(7 DOWNTO 0); SELOUT : OUT STD_LOGIC_VECTOR(7 DOWNTO 0)); end test4; architecture behav of test4 is SIGNAL SEC : STD_LOGIC_VECTOR(3 DOWNTO 0); begin process(clk,clr,en) variable Q : std_logic_vector(3 downto 0); begin m<="0001"; if en='1' then if clk'event and clk='1' then if clr='1' then Q:=(others=>'0'); elsif Q<9 then Q := Q + 1; else Q:=(others=>'0'); end if; end if; end if; if Q="0000" then co<='1'; else co<='0'; end if; SEC<=Q; CASE SEC IS WHEN "0000"=>SEGOUT<="00111111"; SELOUT<="01111111"; WHEN "0001"=>SEGOUT<="00000110"; SELOUT<="01111111"; WHEN "0010"=>SEGOUT<="01011011"; SELOUT<="01111111"; WHEN "0011"=>SEGOUT<="01001111"; SELOUT<="01111111"; WHEN "0100"=>SEGOUT<="01100110"; SELOUT<="01111111"; WHEN "0101"=>SEGOUT<="01101101"; SELOUT<="01111111"; WHEN "0110"=>SEGOUT<="01111101"; SELOUT<="01111111"; WHEN "0111"=>SEGOUT<="00000111"; SELOUT<="01111111"; WHEN "1000"=>SEGOUT<="01111111"; SELOUT<="01111111"; WHEN "1001"=>SEGOUT<="01101111"; SELOUT<="01111111"; WHEN OTHERS=>NULL; end CASE; dout <= Q; end process; end behav; |
1个回答
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
NVMe高速传输之摆脱XDMA设计50:主要功能测试结果与分析2 nvmePCIe高速存储
252 浏览 0 评论
NVMe高速传输之摆脱XDMA设计49:主要功能测试结果与分析1
1501 浏览 0 评论
907 浏览 0 评论
855 浏览 0 评论
658 浏览 0 评论
4427 浏览 63 评论
/9
GMT+8, 2025-12-2 09:03 , Processed in 0.460224 second(s), Total 40, Slave 32 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1522
