#include
#include #define uchar unsigned char #define uint unsigned int #define RdCommand 0x01 //定义ISP的操作命令 读命令 #define PrgCommand 0x02 //对应用程序Flash区及数据Flash区字节编程 #define EraseCommand 0x03 //对应用程序Flash区及数据Flash区扇区擦除 #define Error 1 #define Ok 0 #define ENABLE_IAP 0x82 //定义CPU的等待时间 sfr IAP_DATA=0XE2; //Flash数据寄存器 sfr IAP_ADDRH=0XE3; //Flash高字节地址寄存器 sfr IAP_ADDRL=0XE4; //Flash低字节地址寄存器 sfr IAP_CMD=0XE5; //Flash命令模式寄存器 sfr IAP_TRIG=0XE6; //Flash命令触发寄存器 sfr IAP_CONTR=0XE7; //ISP/IAP控制寄存器 uchar num1; uchar code Disp_Tab[] = {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f}; // 共阴数码管 0-/**************关闭ISP,IAP功能*********************/ void IAP_disable(void) { IAP_CONTR=0; IAP_CMD=0; IAP_TRIG=0; IAP_ADDRH=0X80; IAP_ADDRL=0; } /**************字节读功能*********************/ unsigned char byte_read(unsigned int addr) { IAP_CONTR=ENABLE_IAP; IAP_CMD= RdCommand; IAP_ADDRL=addr; IAP_ADDRH=addr>>8; IAP_TRIG=0x46; IAP_TRIG=0xb9; _nop_(); IAP_disable(); return(IAP_DATA); } /**************扇区擦除功能*********************/ void SectorErase(unsigned int addr ) { IAP_CONTR=ENABLE_IAP; IAP_CMD=EraseCommand; IAP_ADDRL=addr; IAP_ADDRH=addr>>8; IAP_TRIG=0x46; IAP_TRIG=0xb9; _nop_(); IAP_disable(); } /**************字节写功能*********************/ void byte_write(unsigned int addr,unsigned char original_data) { IAP_CONTR=ENABLE_IAP; IAP_CMD= PrgCommand; IAP_ADDRL=addr; IAP_ADDRH=addr>>8; IAP_DATA=original_data; IAP_TRIG=0x46; IAP_TRIG=0xb9; _nop_(); IAP_disable(); } void display(uchar shi,uchar ge) { P0=Disp_Tab[shi]; P1=0XFd; //十位 P1=0XFF; P0=Disp_Tab[ge]; P1=0XFe; //个位 P1=0XFF; } void main() { uchar num,a,b; num=byte_read(0x2000); if(num>=60) num=0; TMOD=0X01; TH0=(65536-45872)/256; TL0=(65536-45872)%256; EA=1; ET0=1; TR0=1; while(1) { if(num1>=20) { num1=0; num++; SectorErase(0x2000); //擦除扇区 byte_write(0x2000,num); //重新写入数据 if(num==60) num=0; a=num/10; b=num%10; } display(a,b); } } void timer0() interrupt 1 { TH0=(65536-45872)/256; TL0=(65536-45872)%256; num1++; } |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
【瑞萨RA6E2】瑞萨E2S软件安装过程,等待过程玩下97_e2 studio_ZGZZ
140 浏览 0 评论
483 浏览 0 评论
【原创】【RA4M2-SENSOR开发板评测】低功耗+USB综合测试
815 浏览 0 评论
1346 浏览 2 评论
804 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
16907 浏览 31 评论
/9
GMT+8, 2025-12-2 21:53 , Processed in 0.539638 second(s), Total 71, Slave 52 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
4495
