以下就是全部程序,但我看不懂他的主函数,跪求解释,搞了几天了,,主要是主函数不懂
- *****BST-V51ʵÑ鿪·¢°åÀý³Ì************************
- 功能是,把多次按下的按键值在数码管上依次显示,
- #include
- #define uchar unsigned char
- ***it dula=P2^6;
- ***it wela=P2^7;
- ***it beep=P2^3;
- uchar a=16,b=16,c=16,d=16,e=16,f=16,g=16,h=16;
- uchar wei,temp,key,ok;
- uchar s1,s2,s3,s4,s5,s6,s7,s8;
- unsigned long shu;
- unsigned char code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,
- 0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71,0x00};
- void delay(uchar i)
- uchar j,k;
- for(j=i;j>0;j--)
- for(k=125;k>0;k--);
- void keyscan()
- P3=0xfe;
- temp=P3;
- temp=temp&0xf0;
- if(temp!=0xf0)
- delay(10);
- if(temp!=0xf0)
- temp=P3;
- switch(temp)
- case 0xee:
- key=0;
- wei++;
- break;
- case 0xde:
- key=1;
- wei++;
- break;
- case 0xbe:
- key=2;
- wei++;
- break;
- case 0x7e:
- key=3;
- wei++;
- break;
- while(temp!=0xf0)
- temp=P3;
- temp=temp&0xf0;
- beep=0;
- beep=1;
- P3=0xfd;
- temp=P3;
- temp=temp&0xf0;
- if(temp!=0xf0)
- delay(10);
- if(temp!=0xf0)
- temp=P3;
- switch(temp)
- case 0xed:
- key=4;
- wei++;
- break;
- case 0xdd:
- key=5;
- wei++;
- break;
- case 0xbd:
- key=6;
- wei++;
- break;
- case 0x7d:
- key=7;
- wei++;
- break;
- while(temp!=0xf0)
- temp=P3;
- temp=temp&0xf0;
- beep=0;
- beep=1;
- P3=0xfb;
- temp=P3;
- temp=temp&0xf0;
- if(temp!=0xf0)
- delay(10);
- if(temp!=0xf0)
- temp=P3;
- switch(temp)
- case 0xeb:
- key=8;
- wei++;
- break;
- case 0xdb:
- key=9;
- wei++;
- break;
- case 0x7b:
- ok=1;
- //key=11;
- //wei++;
- break;
- while(temp!=0xf0)
- temp=P3;
- temp=temp&0xf0;
- beep=0;
- beep=1;
- void display(uchar a,uchar b,uchar c,uchar d,uchar e,uchar f,uchar g,uchar h)
- P0=table[a];
- dula=1;
- dula=0;
- P0=0xfe;
- wela=1;
- wela=0;
- delay(5);
- P0=table;
- dula=1;
- dula=0;
- P0=0xfd;
- wela=1;
- wela=0;
- delay(5);
- P0=table[c];
- dula=1;
- dula=0;
- P0=0xfb;
- wela=1;
- wela=0;
- delay(5);
- P0=table[d];
- dula=1;
- dula=0;
- P0=0xf7;
- wela=1;
- wela=0;
- delay(5);
- P0=table[e];
- dula=1;
- dula=0;
- P0=0xef;
- wela=1;
- wela=0;
- delay(5);
- P0=table[f];
- dula=1;
- dula=0;
- P0=0xdf;
- wela=1;
- wela=0;
- delay(5);
- P0=table[g];
- dula=1;
- dula=0;
- P0=0xbf;
- wela=1;
- wela=0;
- delay(5);
- P0=table[h];
- dula=1;
- dula=0;
- P0=0x7f;
- wela=1;
- wela=0;
- delay(5);
- void main()
- while(1)
- keyscan();
- if(wei!=0) //ʵʱÏÔʾ
- switch(wei)
- case 1: a=key;s1=a; break;
- case 2: b=key;s2=b; break;
- case 3: c=key;s3=c; break;
- case 4: d=key;s4=d; break;
- case 5: e=key;s5=e; break;
- case 6: f=key;s6=f; break;
- case 7: g=key;s7=g; break;
- case 8: h=key;s8=h; break;
- if(ok) //½«²É¼¯µ½µÄµ¥¸öÊý¾Ýת»¯ÎªÒ»¸öÕûÊý¡£
- { ok=0;
- switch(wei)
- case 1: shu=s1; break;
- case 2: shu=s2+s1*10; break;
- case 3: shu=s3+s2*10+s1*100; break;
- case 4: shu=s4+s3*10+s2*100+s1*1000; break;
- case 5: shu=s5+s4*10+s3*100+s2*1000+s1*10000; break;
- case 6: shu=s6+s5*10+s4*100+s3*1000+s2*10000+s1*100000; break;
- case 7: shu=s7+s6*10+s5*100+s4*1000+s3*10000+s2*100000+s1*1000000; break;
- case 8: shu=s8+s7*10+s6*100+s5*1000+s4*10000+s3*100000+s2*1000000+s1*10000000; break;
- wei=0;
- // f=16;e=16;d=16;c=16;b=16;a=16;
- s1=0;s2=0;s3=0;s4=0;s5=0;s6=0,s7=0,s8=0;
- display(a,b,c,d,e,f,g,h);
复制代码
5个回答
