扫一扫,分享给好友
clc1~clc5外部脉冲输入,cs和LED为数码管显示输出,
-- Quartus II VHDL Template -- 计数统计 library ieee; use ieee.std_logic_1164.all; entity exp6 is port ( clc1,clc2,clc3,clc4,clc5 : in std_logic; cs,LED :out std_logic_vector(7 downto 0) ); end exp6; -- 统计模块 architecture tongji of exp6 is begin cs<="11111110"; process(clc1,clc2,clc3,clc4,clc5) variable c1,c2,c3,c4,c5,sum:integer:=0; begin if clc1'event and clc1='1' then c1:=c1+1; end if; if clc2'event and clc2='1' then c2:=c2+1; end if; if clc3'event and clc3='1' then c3:=c3+1; end if; if clc4'event and clc4='1' then c4:=c4+1; end if; if clc5'event and clc5='1' then c5:=c5+1; end if; sum:=c1+c2+c3+c4+c5; if sum>=15 then c1:=0; c2:=0; c3:=0; c4:=0; c5:=0; end if; case sum is when 0 => LED<="11000000"; when 1 => LED<="11111001"; when 2 => LED<="10100100"; when 3 => LED<="10110000"; when 4 => LED<="10011001"; when 5 => LED<="10010010"; when 6 => LED<="10000010"; when 7 => LED<="11111000"; when 8 => LED<="10000000"; when 9 => LED<="10010000"; when 10 => LED<="10001000"; when 11 => LED<="10000011"; when 12 => LED<="11000110"; when 13 => LED<="10100001"; when 14 => LED<="10000110"; when 15 => LED<="10001110"; when others => LED<="11000000"; end case; end process; end tongji; |
2个回答
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
707 浏览 0 评论
420 浏览 0 评论
求FPGA 驱动控制ltc2271 或者 ltc2180 或者 ltc2190或者 ltc2202 的代码
1795 浏览 0 评论
485 浏览 0 评论
求助:遇见诡异问题,FPGA模块A输出端口连接模块B输入后,模块A不能正常工作的
1912 浏览 1 评论
4647 浏览 104 评论
GMT+8, 2024-8-31 14:18 , Processed in 0.590515 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
