把ucos一直到Stmcu2上,验证一个多任务的流水灯程序,但是指示灯就是不亮
UCOS的内核是在官网下载对应的
求解释
- int main(void)
- #if (OS_TASK_NAME_EN > 0)
- CPU_INT08U err;
- #endif
- BSP_IntDisAll(); /* Disable all interrupts. */
- OSInit(); /* Initialize "uC/OS-II, The Real-Time Kernel" */
- OSTaskCreateExt((void (*)(void *)) AppTaskStart, /* Create the start task */
- (void *) 0,
- (OS_STK *)&AppTaskStartStk[APP_CFG_TASK_START_STK_SIZE - 1],
- (INT8U ) APP_CFG_TASK_START_PRIO,
- (INT16U ) APP_CFG_TASK_START_PRIO,
- (OS_STK *)&AppTaskStartStk[0],
- (INT32U ) APP_CFG_TASK_START_STK_SIZE,
- (void *) 0,
- (INT16U )(OS_TASK_OPT_STK_CHK | OS_TASK_OPT_STK_CLR));
- OSTaskNameSet(APP_CFG_TASK_START_PRIO, "Start", &err);
- #endif
- OSStart(); /* Start multitasking (i.e. give control to uC/OS-II) */
- return (1);
- static void AppTaskStart (void *p_arg)
- CPU_INT32U cpu_clk_freq;
- CPU_INT32U cnts;
- (void)p_arg;
- BSP_Init(); /* Initialize BSP functions */
- CPU_Init(); /* Initialize the uC/CPU services */
- cpu_clk_freq = BSP_CPU_ClkFreq(); /* Determine SysTick reference freq. */
- cnts = cpu_clk_freq /* Determine nbr SysTick increments */
- / (CPU_INT32U)OS_TICKS_PER_SEC;
- OS_CPU_SysTickInit(cnts); /* Init uC/OS periodic time src (SysTick). */
- Mem_Init(); /* Initialize memory managment module */
- Math_Init(); /* Initialize mathematical module */
- #if (OS_TASK_STAT_EN > 0)
- OSStatInit(); /* Determine CPU capacity */
- #endif
- APP_TRACE_DBG(("nnr"));
- APP_TRACE_INFO(("Creating Application Events...nr"));
- AppEventCreate(); /* Create Application Events */
- APP_TRACE_INFO(("Creating Application Tasks...nr"));
- AppTaskCreate(); /* Create application tasks */
- OSTaskCreate( Task0, //任务1
- (void * ) 0, //不带参数
- (OS_STK * )&Task0Stk[128 - 1], //堆栈指针
- (INT8U ) 5 //优先级
- OSTaskCreate( Task1, //任务2
- (OS_STK * )&Task1Stk[128 - 1],
- (INT8U ) 6 //优先级
- for(;;)
- BSP_LED_On(2);
- OSTimeDlyHMSM(0, 0, 0, 500); /* Delay for 100 milliseconds */
- BSP_LED_Off(2);
- void Task0(void *p_arg)
- for(;;)
- BSP_LED_On(3);
- OSTimeDlyHMSM(0, 0, 0, 100); /* Delay for 100 milliseconds */
- BSP_LED_Off(3);
- void Task1(void *p_arg)
- for(;;)
- BSP_LED_On(4);
- OSTimeDlyHMSM(0, 0, 0, 200); /* Delay for 100 milliseconds */
- BSP_LED_Off(4);
复制代码
请大侠指点哈,看看是什么问题
2个回答
