在 导入.ASC文件时提示(我封装库里面有J13的封装,为什么还提示找不到呢):Reading file -- C:Documents and SettingsAdministrator桌面V1.0SCHRD_JZ4775_MENSA_V1.0.asc*Unspecified or unsupported version of ASCII file
*pads2000* Loading Cannot create attribute with name Warning: Attribute of type Value not allowed for specified object J13 TFCARD *Part name not found J13 U1.T19 J13.8 R168.2 J12.8 *Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal MSC0_D1 *Part name not found J13 U1.K3 J12.10 J13.9 R172.1 *Part name not found J13 U1.R20 J13.3 R167.2 J12.2 *Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal MSC0_CMD *Part name not found J13 U1.U19 J13.7 J12.7 R166.2 *Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal MSC0_D0 *Part name not found J13 U1.T20 R169.2 J12.9 J13.1 *Part name not found J13 U1.T21 J13.2 R170.2 J12.1 *Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal MSC0_D3 *Part name not found J13 J12.5 R173.1 J13.5 *Part name not found J13 C172.1 J13.4 J12.4 *Part name not found J13 C169.2 J11.5 FB14.1 J13.13 J13.10 C172.2 C170.2 C171.2 *Part name not found J13 C174.2 H8.1 J13.12 J13.11 H7.4 H6.2 H7.3 H7.2 *Part name not found J13 H1.1 Q9.2 J12.6 J13.6 J26.25 J26.27 J26.43 J26.44 Warning: deleting signal MSC0_D1 Warning: deleting signal MSC0_CMD Warning: deleting signal MSC0_D0 Warning: deleting signal MSC0_D3 **INPUT WARNINGS FOUND** |
3个回答
有没有LQFP-44的集成库?
请问是怎么解决的
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
求助大佬们,装了补丁的pads9.5,页面还是有这种问题怎么办?
27543 浏览 1 评论
25087 浏览 1 评论
PADS Layout 在Bottom层添加测试点,被盖了绿油(同样的操作TOP层没有被绿油覆盖),怎么设置才能去掉绿油?
25410 浏览 1 评论
28626 浏览 0 评论
PADS DRC报焊盘之间距离过小,焊盘间距为7,但是规则的安全间距为5
30470 浏览 2 评论
/9
GMT+8, 2025-12-3 07:02 , Processed in 0.467272 second(s), Total 48, Slave 41 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2706
