[文章]《仿盒马》app开发技术分享-- 地址管理页(24)
阅读量0
技术栈
Appgallery connect
开发准备
上一节我们实现了个人信息页面的信息展示和页面修改,并且实现了数据的同步修改,这一节我们来实现电商应用里比较重要的模块,地址模块。首先我们来实现地址的展示。
功能分析
地址列表的展示相对来说是比较简单的,首先我们要新增对应的表,然后在云端先添加几条测试数据,然后在页面中实现当前用户对应的地址查询,在列表组件中进行展示
代码实现
首先我们创建对应的表
"objectTypeName": "address_list",
"fields": [
{"fieldName": "id", "fieldType": "Integer", "notNull": true, "belongPrimaryKey": true},
{"fieldName": "user_id", "fieldType": "Integer", "notNull": true, "defaultValue": 0},
{"fieldName": "administrativeArea", "fieldType": "String"},
{"fieldName": "locality", "fieldType": "String"},
{"fieldName": "subLocality", "fieldType": "String"},
{"fieldName": "placeName", "fieldType": "String"},
{"fieldName": "latitude", "fieldType": "String"},
{"fieldName": "longitude", "fieldType": "String"},
{"fieldName": "nikeName", "fieldType": "String"},
{"fieldName": "phone", "fieldType": "String"},
{"fieldName": "address", "fieldType": "String"}
"indexes": [
{"indexName": "field1IndexId", "indexList": [{"fieldName":"id","sortType":"ASC"}]}
"permissions": [
{"role": "World", "rights": ["Read", "Upsert", "Delete"]},
{"role": "Authenticated", "rights": ["Read", "Upsert", "Delete"]},
{"role": "Creator", "rights": ["Read", "Upsert", "Delete"]},
{"role": "Administrator", "rights": ["Read", "Upsert", "Delete"]}
然后我们生成对应的实体类,和db类
db
import { cloudDatabase } from '@kit.CloudFoundationKit';
class address_list extends cloudDatabase.DatabaseObject {
public id: number;
public user_id = 0;
public administrativeArea: string;
public locality: string;
public subLocality: string;
public placeName: string;
public latitude: string;
public longitude: string;
public nikeName: string;
public phone: string;
public address: string;
public naturalbase_ClassName(): string {
return 'address_list';
export { address_list };
实体类
class AddressList {
user_id: number = 0;
locality: string;
placeName: string;
latitude: string;
longitude: string;
nikeName: string;
phone: string;
address: string;
constructor() {
setId(id: number): void {
    this.id = id;
getId(): number  {
    return this.id;
setUser_id(user_id: number): void {
    this.user_id = user_id;
getUser_id(): number  {
    return this.user_id;
setAdministrativeArea(administrativeArea: string): void {
    this.administrativeArea = administrativeArea;
getAdministrativeArea(): string  {
    return this.administrativeArea;
setLocality(locality: string): void {
    this.locality = locality;
getLocality(): string  {
    return this.locality;
setSubLocality(subLocality: string): void {
    this.subLocality = subLocality;
getSubLocality(): string  {
    return this.subLocality;
setPlaceName(placeName: string): void {
    this.placeName = placeName;
getPlaceName(): string  {
    return this.placeName;
setLatitude(latitude: string): void {
    this.latitude = latitude;
getLatitude(): string  {
    return this.latitude;
setLongitude(longitude: string): void {
    this.longitude = longitude;
getLongitude(): string  {
    return this.longitude;
setNikeName(nikeName: string): void {
    this.nikeName = nikeName;
getNikeName(): string  {
    return this.nikeName;
setPhone(phone: string): void {
    this.phone = phone;
getPhone(): string  {
    return this.phone;
setAddress(address: string): void {
    this.address = address;
getAddress(): string  {
    return this.address;
static parseFrom(inputObject: any): AddressList {
    let result = new AddressList();
    if (!inputObject) {
        return result;
    if (inputObject.id) {
        result.id = inputObject.id;
    if (inputObject.user_id) {
        result.user_id = inputObject.user_id;
    if (inputObject.administrativeArea) {
        result.administrativeArea = inputObject.administrativeArea;
    if (inputObject.locality) {
        result.locality = inputObject.locality;
    if (inputObject.subLocality) {
        result.subLocality = inputObject.subLocality;
    if (inputObject.placeName) {
        result.placeName = inputObject.placeName;
    if (inputObject.latitude) {
        result.latitude = inputObject.latitude;
    if (inputObject.longitude) {
        result.longitude = inputObject.longitude;
    if (inputObject.nikeName) {
        result.nikeName = inputObject.nikeName;
    if (inputObject.phone) {
        result.phone = inputObject.phone;
    if (inputObject.address) {
        result.address = inputObject.address;
    return result;
export { AddressList };
都创建完成之后,接下来我们就可以创建对应的页面开始查询我们云数据库的数据了
@Entry
@Component
struct AddressListPage {
@State user: User|null=null;
@State addressList:AddressList[]=[]
async aboutToAppear(): Promise {
const value = await StorageUtils.getAll('user');
this.user=JSON.parse(value)
let databaseZone = cloudDatabase.zone('default');
let condition = new cloudDatabase.DatabaseQuery(address_list);
condition.equalTo("user_id",this.user!.user_id)
let listData = await databaseZone.query(condition);
let json = JSON.stringify(listData)
let data1:AddressList[]= JSON.parse(json)
this.addressList=data1
hilog.info(0x0000, 'testTag', Succeeded in querying data, result: ${data1});
我们先添加对应的用户信息参数和对应的列表数据接收参数,然后在生命周期内进行数据查询
然后把数据展示到列表中
build() {
Column() {
CommonTopBar({ title: "地址列表", alpha: 0, titleAlignment: TextAlign.Center ,backButton:true})
Stack({alignContent:Alignment.Bottom}){
Column(){
List(){
ForEach(this.addressList,(item:AddressList,index:number)=>{
ListItem(){
Column(){
Row(){
Column({space:10}){
Row(){
Text(item.nikeName)
.fontColor(Color.Black)
.fontSize(16)
.fontWeight(FontWeight.Bold)
Text(item.phone)
.fontSize(16)
.margin({left:20})
Text(item.address)
.fontSize(16)
.alignItems(HorizontalAlign.Start)
.justifyContent(FlexAlign.Center)
Image($r('app.media.address_edit'))
                  .width(20)
                  .height(20)
                  .onClick(()=>{
                    showToast("编辑")
              .justifyContent(FlexAlign.SpaceBetween)
              .width('100%')
              .padding(10)
              Divider().width('90%').height(0.8)
                .color("#ffb1b0b0")
      .layoutWeight(1)
    .height('90%')
    Text("新增地址")
      .width('70%')
      .height(45)
      .fontColor(Color.White)
      .backgroundColor(0xff0000)
      .borderRadius(10)
      .textAlign(TextAlign.Center)
  .backgroundColor(Color.White)
.height('100%')
.width('100%')
到这里我们的地址展示就实现了
回帖
声明:本文内容及配图由入驻作者撰写或者入驻合作网站授权转载。文章观点仅代表作者本人,不代表电子发烧友网立场。文章及其配图仅供工程师学习之用,如有内容图片侵权或者其他问题,请联系本站作侵删。 侵权投诉
链接复制成功,分享给好友
