Appgallery connect
上一节我们实现了购物车商品列表的大部分功能,实现了商品的添加、删除、增减、价格计算等业务,并且都跟云端进行通信。现在我们继续对项目进行改造,这一节我们要改造的内容是分类页,这个页面我们在之前的非端云一体化项目中实现过。现在要改造成端云一体的模式,并且我们的金刚区也要实现分类页的点击联动
1.分类列表
分类列表我们要注意首页跳入切换到对应item的情况,点击时item对应的字体、背景色等状态的变化,以及list的切换
首先我们要对金刚区的数据进行一个改造
"objectTypeName": "split_layout",
"fields": [
{"fieldName": "split_id", "fieldType": "Integer", "notNull": true, "belongPrimaryKey": true},
{"fieldName": "txt", "fieldType": "String"},
{"fieldName": "url", "fieldType": "String"},
{"fieldName": "router", "fieldType": "String"},
{"fieldName": "is_login", "fieldType": "Boolean"},
{"fieldName": "child_id", "fieldType": "Integer"},
{"fieldName": "bt_state", "fieldType": "Integer"}
"indexes": [
{"indexName": "splitId_Index", "indexList": [{"fieldName":"split_id","sortType":"ASC"}]}
"permissions": [
{"role": "World", "rights": ["Read"]},
{"role": "Authenticated", "rights": ["Read", "Upsert"]},
{"role": "Creator", "rights": ["Read", "Upsert", "Delete"]},
{"role": "Administrator", "rights": ["Read", "Upsert", "Delete"]}
我们加上了child_id,有了这个参数能更好的去查询对应的数据
实体类
export class SplitLayoutModel {
split_id: number;
txt: string;
url: string;
router: string;
is_login: boolean;
child_id: number;
bt_state: number;
constructor() {
getFieldTypeMap(): Map<string, string> {
let fieldTypeMap = new Map<string, string>();
fieldTypeMap.set('split_id', 'Integer');
fieldTypeMap.set('txt', 'String');
fieldTypeMap.set('url', 'String');
fieldTypeMap.set('router', 'String');
fieldTypeMap.set('is_login', 'Boolean');
fieldTypeMap.set('child_id', 'Integer');
fieldTypeMap.set('bt_state', 'Integer');
return fieldTypeMap;
getClassName(): string {
return 'split_layout';
getPrimaryKeyList(): string[] {
let primaryKeyList: string[] = [];
primaryKeyList.push('split_id');
return primaryKeyList;
getIndexList(): string[] {
let indexList: string[] = [];
indexList.push('split_id');
return indexList;
getEncryptedFieldList(): string[] {
let encryptedFieldList: string[] = [];
return encryptedFieldList;
setSplit_id(split_id: number): void {
this.split_id = split_id;
getSplit_id(): number {
return this.split_id;
setTxt(txt: string): void {
this.txt = txt;
getTxt(): string {
return this.txt;
setUrl(url: string): void {
this.url = url;
getUrl(): string {
return this.url;
setRouter(router: string): void {
this.router = router;
getRouter(): string {
return this.router;
setIs_login(is_login: boolean): void {
this.is_login = is_login;
getIs_login(): boolean {
return this.is_login;
setChild_id(child_id: number): void {
this.child_id = child_id;
getChild_id(): number {
return this.child_id;
setBt_state(bt_state: number): void {
this.bt_state = bt_state;
getBt_state(): number {
return this.bt_state;
static parseFrom(inputObject: any): SplitLayoutModel {
let result = new SplitLayoutModel();
if (!inputObject) {
return result;
if (inputObject.split_id) {
result.split_id = inputObject.split_id;
if (inputObject.txt) {
result.txt = inputObject.txt;
if (inputObject.url) {
result.url = inputObject.url;
if (inputObject.router) {
result.router = inputObject.router;
if (inputObject.is_login) {
result.is_login = inputObject.is_login;
if (inputObject.child_id) {
result.child_id = inputObject.child_id;
if (inputObject.bt_state) {
result.bt_state = inputObject.bt_state;
return result;
然后我们在金刚区的点击事件里传递当前点击的下标
先定义
@State pos_check:number=0
我们在金刚区组件内定义一个带参数的回调
private onItemClick?: (pos:number) => void
调用
.onClick(()=>{
this.onItemClick!(index)
在index页面拿到下标后控制tabs切换到分类,并且传入下标
SplitLayout({listData:this.splitList,onItemClick:(pos)=>{
this.controller.changeIndex(1);
this.pos_check=pos
分类页顶部导航列表自定义组件
import { CustomImageGridDialog } from "../dialog/CustomImageGridDialog";
import { cloudDatabase } from "@kit.CloudFoundationKit";
import { split_layout } from "../clouddb/split_layout";
import { SplitLayoutModel } from "../entity/SplitLayoutModel";
import { hilog } from "@kit.PerformanceAnalysisKit";
@Preview
@Component
export struct Classification {
private listScroller: Scroller = new Scroller();
@Link selectedIndex: number
@State list: SplitLayoutModel[] = []
@State flag:boolean=false
private onItemClick?: (child_id:number) => void
async aboutToAppear(): Promise {
let databaseZone = cloudDatabase.zone('default');
let condition = new cloudDatabase.DatabaseQuery(split_layout);
let listData = await databaseZone.query(condition);
let json = JSON.stringify(listData)
let data2:SplitLayoutModel[]= JSON.parse(json)
this.list=data2
hilog.error(0x0000, 'testTag', Failed to query data, code: ${this.list});
this.flag=true
private dialogController: CustomDialogController = new CustomDialogController({
builder: CustomImageGridDialog({
select:this.selectedIndex,
dataSource: this.list,
onItemSelected: (item: number) => {
this.listScroller.scrollToIndex(item, true, ScrollAlign.CENTER)
alignment: DialogAlignment.Top,
customStyle:true
build() {
Row() {
List({scroller:this.listScroller,space:10}){
ForEach(this.list, (item:SplitLayoutModel,index:number) => {
ListItem(){
Column(){
Image(item.url)
.width(40)
.height(40)
.borderRadius(20)
.border({width:this.selectedIndex === index?2:0,color:"#409EFF"})
Text(item.txt)
.textAlign(TextAlign.Center)
.fontColor(Color.Black)
.fontSize(10)
.padding(2)
.margin({top:5})
.fontColor(this.selectedIndex === index?"#FFFFFF":"#000000")
.backgroundColor(this.selectedIndex === index ? '#409EFF' : '#FFFFFF')
.borderRadius(this.selectedIndex === index ? 15:0)
.onClick(()=>{
if (this.selectedIndex === index) {
this.selectedIndex = 0
} else {
this.selectedIndex = index
this.listScroller.scrollToIndex(index, true, ScrollAlign.CENTER)
.scrollBar(BarState.Off)
.height(65)
.width('90%')
.listDirection(Axis.Horizontal)
Blank()
Column(){
Text("全")
.fontSize(14)
Text("部")
.fontSize(14)
Image($r('app.media.all'))
.height(20)
.width(20)
.onClick(()=>{
this.dialogController.open()
.padding(5)
.justifyContent(FlexAlign.SpaceBetween)
.height(90)
.width('100%')
.margin({top:20})
index页面引用
Classification({selectedIndex:this.pos_check})
到这里我们的就全部实现了
