开发步骤
在应用工程中新增PROJECT_HOME/entry/src/main/resources/base/profile/insight_intent.json文件注册意图,指定意图名称和所属垂域,并且指定一个意图调用逻辑入口。比如在本示例中将调用逻辑放在了EntryAbility下的InsightIntentExecutorImpl文件中。
"insightIntents": [
"intentName": "PlayMusic",
"domain": "MusicDomain",
"intentVersion": "1.0.1",
"srcEntry": "./ets/entryability/InsightIntentExecutorImpl.ets",
"uiAbility": {
"ability": "EntryAbility",
"executeMode": [
"background",
"foreground"
"intentName": "PlayMusicList",
"uiAbility": {
"executeMode": [
"background",
"foreground"
新增PROJECT_HOME/entry/src/main/resources/rawfile/config/shareIntent.json文件,定义共享数据。数据体除了意图名、版本和标识前三个公共字段外,必选字段还包括动作模式、当前播放百分比、实体名称和ID、音乐名、logo、歌手以及音乐时长等。以下是“音乐播放”的完整数据。具体意图共享字段含义可参考各垂域意图Schema中的音乐垂类。
"intentVersion": "1.0",
"identifier": "52dac3b0-6520-4974-81e5-25f0879449b5",
"intentActionInfo": {
"actionMode": "EXECUTED",
"executedTimeSlots": {
"executedStartTime": 1637393212000,
"executedEndTime": 1637393112000
"currentPercentage": 50
"intentEntityInfo": {
"entityName": "Music",
"entityId": "C10194368",
"entityGroupId": "C10194321312",
"displayName": "红颜如霜",
"description": "NA",
"logoURL": "https://www-file.huawei.com/-/media/corporate/images/home/logo/huawei_logo.png",
"keywords": [
"华为音乐",
"化妆"
"rankingHint": 99,
"expirationTime": 1637393212000,
"metadataModificationTime": 1637393212000,
"activityType": [
"1",
"2",
"3"
"artist": [
"测试歌手1",
"测试歌手2"
"lyricist": [
"测试词作者1",
"测试词作者2"
"composer": [
"测试曲作者1",
"测试曲作者2"
"albumName": "测试专辑",
"duration": 244000,
"playCount": 100000,
"musicalGenre": [
"流行",
"话语",
"抖音",
"00后"
"isPublicData": false
"entityName": "MusicList",
"displayName": "测试歌单",
"description": "这是xxx歌单",
"keyWords": [
"抖音",
"动感"
"rankingHint": 99,
"activityType": [
"1",
"2",
"3"
"isPublicData": false,
"briefDescription": "这是xxx歌单,来自xxx,是xxx风格",
"artist": [
"测试歌手1",
"测试歌手2"
"numberOfSongs": 20,
"type": "1",
"creator": "测试创建者",
"createDate": "2023-10-08T08:00:00+08:00",
"musicNameList": [
"测试歌曲1",
"测试歌曲2"
"playCount": 30,
"musicalGenre": [
"流行",
"话语",
"抖音",
"00后"
调用insightIntent.shareIntent接口将意图对象输入到HarmonyOS,用于学习用户的行为规律。成功共享后“小艺建议”会展示对应应用的音乐模板卡片。展示效果如图所示。
html/xmstatic async shareIntent(context: Context, input: string): Promise<string> {
Logger.debug(TAG, 'shareIntent');
let insightIntents: insightIntent.InsightIntent[];
try {
let insightIntents: insightIntent.InsightIntent[] = JSON.parse(input);
if (!insightIntents || insightIntents.length === 0) {
Logger.error(TAG, 'shareIntent: json invalid.');
return 'shareIntent: json invalid.';
return await insightIntent.shareIntent(context, insightIntents).then(() => {
Logger.info(TAG, 'shareIntent success');
return 'share intent success';
}, (err: BusinessError) => {
Logger.error(TAG, `shareIntent error message: ${JSON.stringify(err)}`);
return `shareIntent error message: ${JSON.stringify(err)}`;
}catch (err) {
Logger.error(TAG, 'shareIntent fail', err);
return Promise.reject('shareIntent fail');
InsightIntentSharer.etsl
配置PROJECT_HOME/entry/src/main/ets/entryability/InsightIntentExecutorImpl.ets文件,定义onExecuteInUIAbilityForegroundMode()方法。点击卡片,会拉起对应的应用并触发onCreate和onExecuteInUIAbilityForegroundMode等方法。意图调用如果会拉起应用界面,采取前台模式,如果不需要拉起采取后台模式。应用在foreground模式和background模式下会触发不同的生命周期与方法:
本示例中采取foreground模式,可以在onCreate()或者onNewWant()解析want和launchParam。通过launchReason区分是否是意图调用拉起的Ability,如果是则解析want中的参数,并且将参数result存储在AppStorage中。如果是在真实开发中意图调用传参字段可以在开发前和接口方协商。
onCreate(want: Want, launchParam: AbilityConstant.LaunchParam): void {
Logger.info(TAG, 'onCreate');
if (want.parameters?.['result']) {
this.result = want.parameters?.['result'] as string;
EntryAbility.ets
want解析完毕后,会触发onExecuteInUIAbilityForegroundMode()方法进行真正逻辑处理,根据意图名称去分发处理方法并且返回一个Promise,成功调用code返回0,失败时返回-1。
* Override the method to execute the intent in the foreground UIAbility.
* [url=home.php?mod=space&uid=3142012]@param[/url] name Intent name.
* @param param Intent parameters.
* @param pageLoader Window.
* @returns Intent call result.
onExecuteInUIAbilityForegroundMode(name: string, param: Record<string, Object>, pageLoader: window.WindowStage):
Promise<insightIntent.ExecuteResult> {
Logger.info(TAG, `onExecuteInUIAbilityForegroundMode name: ${name}, param: ${JSON.stringify(param)}`);
// Distribute the processing logic based on the intent name.
switch (name) {
case InsightIntentExecutorImpl.PLAY_MUSIC:
return this.playMusic(param, pageLoader);
case InsightIntentExecutorImpl.PLAY_MUSIC_LIST:
return this.playMusicList(param, pageLoader);
default:
break;
return Promise.resolve({
code: -1,
result: {
message: 'unknown intent'
} as insightIntent.ExecuteResult)
最后完成playMusic的功能逻辑,小艺建议基于共享数据生成推荐卡片,点击卡片后将上述shareIntent.json定义的实体ID值传递到应用中。
* Implement the music playback function.
private playMusic(param: Record<string, Object>, pageLoader: window.WindowStage): Promise<insightIntent.ExecuteResult> {
return new Promise((resolve, reject) => {
let para: Record<string, string> = {
'result': `intent execute success, entityId: ${param.entityId}`
let localStorage: LocalStorage = new LocalStorage(para);
// TODO Implement an intent call.
pageLoader.loadContent('pages/Index', localStorage)
.then(() => {
// TODO The intent is called successfully.
Logger.info(TAG, "Intent execute success");
resolve({
code: 0,
result: {
message: 'Intent execute success'
.catch((err: BusinessError) => {
// TODO Handle the failure if the intent fails to be called.
Logger.error(TAG, `Intent execute failed: ${JSON.stringify(err)}`);
resolve({
code: -1,
result: {
message: 'Intent execute failed'
如果想删除掉意图,可以调用insightIntent.deleteIntent(),在注册文件只有一个意图的情况下卡片入口会消失。运行效果如下图所示。
说明
在真机设备上,小艺建议卡片不会实时刷新。可以通过点击卡片中的服务,重新返回到桌面后,进行卡片刷新。
本文主要引用整理于鸿蒙官方文档
