本案例是在小凌派-RK2206开发板上使用IoT库PWM接口,进行PWM编程开发。
例程将创建一个任务,每隔5秒将PWM0~10依次启用,输出1000Hz。
PWM在日常设备中非常常见,以下我们将演示IoT库的PWM接口如何进行PWM控制。
base/iot_hardware/peripheral/interfaces/kits/iot_pwm.h
unsigned int IoTPwmInit(unsigned int port);
描述:
初始化PWM设备。
参数:
| 参数 | 类型 | 描述 |
| port | unsigned int | PWM端口号 |
其中,port对应于如下表所示:
| port | GPIO |
| 0 | GPIO_PB4 |
| 1 | GPIO_PB5 |
| 2 | GPIO_PB6 |
| 3 | GPIO_PC0 |
| 4 | GPIO_PC1 |
| 5 | GPIO_PC2 |
| 6 | GPIO_PC3 |
| 7 | GPIO_PC4 |
| 8 | GPIO_PC5 |
| 9 | GPIO_PC6 |
| 10 | GPIO_PC7 |
返回值:
| 返回值 | 描述 |
| IOT_SUCCESS | 成功 |
| IOT_FAILURE | 失败 |
实现:
hal_iot_pwm.c文件在device/rockchip/rk2206/adapter/hals/iot_hardware/wifiiot_lite目录下。
unsigned int ret = 0;
if (port >= EPWMDEV_MAX) {
PRINT_ERR("port(%d) >= EPWMDEV_MAX(%d)\\n", port, EPWMDEV_MAX);
return IOT_FAILURE;
PinctrlSet(m_pwm_bus_info[port].pwm_bus.pwm.gpio,
m_pwm_bus_info[port].pwm_bus.pwm.func,
m_pwm_bus_info[port].pwm_bus.pwm.type,
m_pwm_bus_info[port].pwm_bus.pwm.drv);
PwmIoInit(m_pwm_bus_info[port].pwm_bus);
LzPwmInit(m_pwm_bus_info[port].port);
return IOT_SUCCESS;
unsigned int IoTPwmDeinit(unsigned int port);
描述:
取消初始化PWM设备。
参数:
| 参数 | 类型 | 描述 |
其中,port对应于如下表所示:
| port | GPIO |
| 0 | GPIO_PB4 |
| 1 | GPIO_PB5 |
| 2 | GPIO_PB6 |
| 3 | GPIO_PC0 |
| 4 | GPIO_PC1 |
| 5 | GPIO_PC2 |
| 6 | GPIO_PC3 |
| 7 | GPIO_PC4 |
| 8 | GPIO_PC5 |
| 9 | GPIO_PC6 |
| 10 | GPIO_PC7 |
返回值:
| 返回值 | 描述 |
| IOT_SUCCESS | 成功 |
| IOT_FAILURE | 失败 |
实现:
return IOT_FAILURE;
LzGpioDeinit(m_pwm_bus_info[port].pwm_bus.pwm.gpio);
LzPwmDeinit(m_pwm_bus_info[port].port);
return IOT_SUCCESS;
unsigned int IoTPwmStart(unsigned int port, unsigned short duty, unsigned int freq);
描述:
开始PWM信号输出。
参数:
| 参数 | 类型 | 描述 |
| duty | unsigned short | 高电平的占空比,范围为1~99 |
| freq | unsigned int | 频率 |
其中,port对应于如下表所示:
| port | GPIO |
| 0 | GPIO_PB4 |
| 1 | GPIO_PB5 |
| 2 | GPIO_PB6 |
| 3 | GPIO_PC0 |
| 4 | GPIO_PC1 |
| 5 | GPIO_PC2 |
| 6 | GPIO_PC3 |
| 7 | GPIO_PC4 |
| 8 | GPIO_PC5 |
| 9 | GPIO_PC6 |
| 10 | GPIO_PC7 |
返回值:
| 返回值 | 描述 |
| IOT_SUCCESS | 成功 |
| IOT_FAILURE | 失败 |
实现:
#define DUTY_MIN 1
#define DUTY_MAX 99
#define SEC_TO_NSEC (1000000000UL)
unsigned int duty_ns;
unsigned int cycle_ns;
return IOT_FAILURE;
if ((duty < DUTY_MIN) || (DUTY_MAX < duty)) {
PRINT_ERR("duty(%d) out of the range(%d ~ %d)\\n", duty, DUTY_MIN, DUTY_MAX);
return IOT_FAILURE;
if (freq == 0) {
PRINT_ERR("freq(%d) is invalid!\\n", freq);
return IOT_FAILURE;
if (freq > SEC_TO_NSEC) {
PRINT_ERR("freq(%d) > SEC_TO_NSEC(%d)\\n", freq, SEC_TO_NSEC);
return IOT_FAILURE;
cycle_ns = SEC_TO_NSEC / freq;
duty_ns = cycle_ns * duty / 100;
LzPwmStart(m_pwm_bus_info[port].port, duty_ns, cycle_ns);
return IOT_SUCCESS;
unsigned int IoTPwmStop(unsigned int port);
描述:
停止PWM信号输出。
参数:
| 参数 | 类型 | 描述 |
其中,port对应于如下表所示:
| port | GPIO |
| 0 | GPIO_PB4 |
| 1 | GPIO_PB5 |
| 2 | GPIO_PB6 |
| 3 | GPIO_PC0 |
| 4 | GPIO_PC1 |
| 5 | GPIO_PC2 |
| 6 | GPIO_PC3 |
| 7 | GPIO_PC4 |
| 8 | GPIO_PC5 |
| 9 | GPIO_PC6 |
| 10 | GPIO_PC7 |
返回值:
| 返回值 | 描述 |
| IOT_SUCCESS | 成功 |
| IOT_FAILURE | 失败 |
实现:
return IOT_FAILURE;
LzPwmStart(m_pwm_bus_info[port].port, 0, 0);
return IOT_SUCCESS;
在pwm_example函数中,创建一个任务。
void pwm_example()
unsigned int thread_id;
TSK_INIT_PARAM_S task = {0};
unsigned int ret = LOS_OK;
task.pfnTaskEntry = (TSK_ENTRY_FUNC)pwm_thread;
task.uwStackSize = 2048;
task.pcName = "pwm_thread";
task.usTaskPrio = 20;
ret = LOS_TaskCreate(&thread_id, &task);
if (ret != LOS_OK) {
printf("Falied to create pwm_thread ret:0x%x\\n", ret);
return;
pwm_thread任务中调用IOT库的PWM接口控制PWM。
void pwm_thread()
unsigned int ret;
/* PWM端口号对应于参考文件:
* device/rockchip/rk2206/adapter/hals/iot_hardware/wifiiot_lite/hal_iot_pwm.c
unsigned int port = 0;
while (1) {
printf("===========================\\n");
printf("PWM(%d) Init\\n", port);
ret = IoTPwmInit(port);
if (ret != 0) {
printf("IoTPwmInit failed(%d)\\n");
continue;
printf("PWM(%d) Start\\n", port);
ret = IoTPwmStart(port, 50, 1000);
if (ret != 0) {
printf("IoTPwmStart failed(%d)\\n");
continue;
LOS_Msleep(5000);
printf("PWM(%d) end\\n", port);
ret = IoTPwmStop(port);
if (ret != 0) {
printf("IoTPwmStop failed(%d)\\n");
continue;
ret = IoTPwmDeinit(port);
if (ret != 0) {
continue;
printf("\\n");
port++;
if (port >= 11) {
port = 0;
**修改 **vendor/lockzhiner/rk2206/sample 路径下 BUILD.gn 文件,指定 iot_pwm_example 参与编译。
"./b16_iot_pwm:iot_pwm_example",
**修改 **device/lockzhiner/rk2206/sdk_liteos 路径下 Makefile 文件,添加 -liot_pwm_example 参与编译。
hardware_LIBS = -lhal_iothardware -lhardware -lshellcmd -liot_pwm_example
示例代码编译烧录代码后,按下开发板的RESET按键,通过串口助手查看日志,任务每隔5s控制不同PWM输出。
entering kernel init...
hilog will init.
[MAIN:D]Main: LOS_Start ...
Entering scheduler
OHOS # hiview init success.===========================
PWM(0) Init
[GPIO:D]LzGpioInit: id 12 is initialized successfully
PWM(0) Start
PWM(0) end
[GPIO:D]LzGpioDeinit: id 12 is released successfully
PWM(1) Init
[GPIO:D]LzGpioInit: id 13 is initialized successfully
PWM(1) Start
PWM(1) end
[GPIO:D]LzGpioDeinit: id 13 is released successfully
