电子发烧友论坛|
ESP8266当作TCP服务器,手机应用去连接,手机应用会重复连接,连接前会把之前的连接给断开,但是ESP8266的连接数一直在增加,当达到5个连接后,就再也不能连接通信了,现在的做法是,在ESP8266中把上一个连接断开,代码如下,但是不生效,帮忙看看哪有问题
static struct espconn led_wifi_conn; static struct espconn *laster_wifi_conn; static struct espconn *current_wifi_conn; static esp_tcp led_wifi_tcp; static uint8 led_tcp_dis; // 此函数一直没有调用 static void led_wifi_disconnect_callback(void *arg) { os_printf("led_wifi_disconnect_callbackn"); } // 此函数一直没有调用 static void led_wifi_reconnect_callback(void *arg,sint8 err) { os_printf("led_wifi_reconnect_callback err = %dn",err); } static void led_wifi_rev_callback(void *arg, char *pdata, unsigned short len) { // os_printf("led_wifi_rev_callback led = %dn",len); UART1GetData(pdata,len); } static void led_wifi_send_callback(void *arg) { // os_printf("led_wifi_send_callbackn"); } static void led_wifi_connect_callback(void *arg) { struct espconn *conn; conn = (struct espconn *)arg; if ((unsigned int)arg == (unsigned int)&led_wifi_conn) os_printf("IS the samen"); else os_printf("NOT the samen"); os_printf("led_wifi_connect_callbackn"); os_printf("conn->link_cnt = %dn",conn->link_cnt); os_printf("conn->state = %dn",conn->state); os_printf("current_wifi_conn = 0x%xn",(unsigned int)conn); current_wifi_conn = conn; led_tcp_dis = 1; conn->proto.tcp = &led_wifi_tcp; espconn_regist_disconcb(conn,led_wifi_disconnect_callback); espconn_regist_reconcb(conn,led_wifi_reconnect_callback); espconn_regist_recvcb(conn, led_wifi_rev_callback); espconn_regist_sentcb(conn, led_wifi_send_callback); } static void led_wifi_build_tcp(void) { // Build TCP server led_wifi_conn.type = ESPCONN_TCP; led_wifi_conn.state = ESPCONN_NONE; led_wifi_conn.proto.tcp = &led_wifi_tcp; led_wifi_conn.proto.tcp->local_port = WIFI_SERVER_PORT; espconn_regist_connectcb(&led_wifi_conn,led_wifi_connect_callback); espconn_accept(&led_wifi_conn); // Set TCP alive 1800s espconn_regist_time(&led_wifi_conn,WIFI_TCP_TIME,1); } // // Check if need disconnect TCP connect // 此函数在一个任务中周期性调用,用来断开上一个连接 void LEDWifiProc(void) { sint8 ret; if (0) { os_printf("LEDWifiProc = 0x%xn",(unsigned int)laster_wifi_conn); ret = espconn_disconnect(laster_wifi_conn); os_printf("disconnect ret = %dn",ret); ret = espconn_delete(laster_wifi_conn); os_printf("delete ret = %dn",ret); laster_wifi_conn = current_wifi_conn; led_tcp_dis = 0; } } sint8 led_wifi_send_data(uint8 *data,unsigned short len) { if (data == NULL || len == 0) return -1; return espconn_send(&led_wifi_conn,data,len); } void IRAM_ATTR led_wifi_event_handle(System_Event_t *event) { os_printf("led_wifi_event_handle evt = %dn",event->event_id); } void led_wifi_init(void) { unsigned int ret; struct softap_config cfg; led_tcp_dis = 0; // WIFI mode init wifi_set_opmode(STATIONAP_MODE); // Set WIFI default name and password wifi_softap_get_config(&cfg); // Load device name save in flash // When new device,the softAP authmode will OPEN ? if (cfg.authmode != AUTH_WPA_WPA2_PSK || cfg.max_connection != 1) { sprintf(cfg.ssid,"%s",WIFI_DEFAULT_SSID); sprintf(cfg.password,"%s",WIFI_DEFAULT_PASSWD); } cfg.authmode = AUTH_WPA_WPA2_PSK; cfg.ssid_len = 0; cfg.max_connection = 1; wifi_softap_set_config(&cfg); // wifi_set_event_handler_cb(led_wifi_event_handle); led_wifi_build_tcp(); laster_wifi_conn = &led_wifi_conn; current_wifi_conn = &led_wifi_conn; os_printf("led_wifi_conn = 0x%xn",(unsigned int)&led_wifi_conn); } 串口打印LOG如下: SDK version:1.3.0(68c9e7b) led_wifi_conn = 0x3fff044c mode : sta(5c:cf:7f:12:65:42) + softAP(5e:cf:7f:12:65:42) add if0 dhcp server start:(ip:192.168.4.1,mask:255.255.255.0,gw:192.168.4.1) add if1 bcn 100 add 1 aid 1 station: 68:3e:34:61:d5:61 join, AID = 1 NOT the same led_wifi_connect_callback conn->link_cnt = 0 conn->state = 3 current_wifi_conn = 0x3fffde20 espconn_server_close, close NOT the same led_wifi_connect_callback conn->link_cnt = 1 conn->state = 3 current_wifi_conn = 0x3fffdcb0 espconn_server_close, close NOT the same led_wifi_connect_callback conn->link_cnt = 2 conn->state = 3 current_wifi_conn = 0x3fffdd78 espconn_server_close, close NOT the same led_wifi_connect_callback conn->link_cnt = 3 conn->state = 3 current_wifi_conn = 0x3fffdf58 espconn_server_close, close NOT the same led_wifi_connect_callback conn->link_cnt = 4 conn->state = 3 current_wifi_conn = 0x3fffdf28 espconn_server_close, close 当conn->link_cnt = 4后,再也不能连接,不管LEDWifiProc有没有执行disconnect,都没用 |
1个回答
从您提供的代码片段来看,您正在尝试使用ESP8266作为TCP服务器,并希望在手机应用重复连接时断开之前的连接。然而,您遇到的问题是在达到5个连接后,ESP8266无法再接受新的连接。这里我会提供一些建议和解决方案,以帮助您解决这个问题。
1. 确保ESP8266固件支持多个TCP连接。ESP8266的某些固件版本可能不支持多个TCP连接。请确保您使用的固件版本支持多个TCP连接。 2. 检查TCP连接的监听和接受。在ESP8266上设置TCP服务器时,需要确保正确监听和接受TCP连接。以下是使用ESP8266非OS SDK的示例代码: ```c #include "espconn.h" static espconn server; void ICACHE_FLASH_ATTR esp8266_init_tcp_server(void) { server.type = ESPCONN_TCP; server.state = ESPCONN_NONE; espconn_regist_connectcb(&server, tcp_client_connect_callback); espconn_regist_reconcb(&server, tcp_client_reconnect_callback); espconn_regist_disconcb(&server, tcp_client_disconnect_callback); espconn_accept(&server); } void ICACHE_FLASH_ATTR tcp_client_connect_callback(void *arg) { espconn *pespconn = (espconn *)arg; // 处理新连接 } void ICACHE_FLASH_ATTR tcp_client_reconnect_callback(void *arg, sint8 err) { // 处理重连 } void ICACHE_FLASH_ATTR tcp_client_disconnect_callback(void *arg) { espconn *pespconn = (espconn *)arg; espconn_disconnect(pespconn); } ``` 3. 断开连接时释放资源。在ESP8266上断开TCP连接时,需要确保释放所有相关资源。以下是断开连接的示例代码: ```c void ICACHE_FLASH_ATTR disconnect_client(espconn *pespconn) { espconn_disconnect(pespconn); espconn_delete(pespconn); } ``` 4. 限制最大连接数。您可以设置一个全局变量来限制最大连接数,当达到最大连接数时,拒绝新的连接请求。以下是一个示例: ```c #define MAX_CONNECTIONS 5 static uint8_t connection_count = 0; void ICACHE_FLASH_ATTR tcp_client_connect_callback(void *arg) { if (connection_count >= MAX_CONNECTIONS) { // 拒绝新连接 return; } espconn *pespconn = (espconn *)arg; connection_count++; // 处理新连接 } void ICACHE_FLASH_ATTR tcp_client_disconnect_callback(void *arg) { espconn *pespconn = (espconn *)arg; connection_count--; espconn_disconnect(pespconn); } ``` 5. 检查内存泄漏。确保在断开连接时释放所有分配的内存,以避免内存泄漏。 6. 使用ESP8266的RTOS SDK。如果您使用的是非OS SDK,建议您尝试使用ESP8266的RTOS SDK,它提供了更丰富的API和更好的性能。 希望这些建议能帮助您解决问题。如果问题仍然存在,请提供更多代码和详细信息,以便我们能够更好地帮助您。 |
只有小组成员才能发言,加入小组>>
945 浏览 0 评论
1672 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1330 浏览 1 评论
1233 浏览 1 评论
5021 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1254浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
927浏览 3评论
2338浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2528浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1052浏览 2评论
/9
GMT+8, 2025-12-2 12:00 , Processed in 0.558005 second(s), Total 42, Slave 35 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
682
