Executing action: bulid
Running cmake in directory F:�1_ESP_STM_PRJESP32ESP-BOXesp-box-masterexamplesfactory_demobuild Executing "cmake -G Ninja -DPYTHON_DEPS_CHECKED=1 -DPYTHON=D:Espressifpython_envidf5.1_py3.11_envScriptspython.exe -DESP_PLATFORM=1 -DCCACHE_ENABLE=1 F:�1_ESP_STM_PRJESP32ESP-BOXesp-box-masterexamplesfactory_demo"... -- IDF_TARGET is not set, guessed 'esp32s3' from sdkconfig 'F:/01_ESP_STM_PRJ/ESP32/ESP-BOX/esp-box-master/examples/factory_demo/sdkconfig' -- Found Git: D:/Espressif/tools/idf-git/2.39.2/cmd/git.exe (found version "2.39.2.windows.1") -- ccache will be used for faster recompilation -- The C compiler identification is GNU 12.2.0 -- The CXX compiler identification is GNU 12.2.0 -- The ASM compiler identification is GNU -- Found assembler: D:/Espressif/tools/xtensa-esp32s3-elf/esp-12.2.0_20230208/xtensa-esp32s3-elf/bin/xtensa-esp32s3-elf-gcc.exe -- Detecting C compiler ABI info -- Detecting C compiler ABI info - done -- Check for working C compiler: D:/Espressif/tools/xtensa-esp32s3-elf/esp-12.2.0_20230208/xtensa-esp32s3-elf/bin/xtensa-esp32s3-elf-gcc.exe - skipped -- Detecting C compile features -- Detecting C compile features - done -- Detecting CXX compiler ABI info -- Detecting CXX compiler ABI info - done -- Check for working CXX compiler: D:/Espressif/tools/xtensa-esp32s3-elf/esp-12.2.0_20230208/xtensa-esp32s3-elf/bin/xtensa-esp32s3-elf-g++.exe - skipped -- Detecting CXX compile features -- Detecting CXX compile features - done -- git describe returned 'fatal: bad revision 'HEAD'' -- Could not use 'git describe' to determine PROJECT_VER. -- Building ESP-IDF components for target esp32s3 Processing 27 dependencies: [1/27] chmorgan/esp-audio-player (1.0.5) [2/27] chmorgan/esp-file-iterator (1.0.0) [3/27] chmorgan/esp-libhelix-mp3 (1.0.3) [4/27] espressif/cmake_utilities (0.5.2) [5/27] espressif/esp-box (3.0.3~1) [6/27] espressif/esp-box-3 (1.1.1~1) [7/27] espressif/esp-box-lite (2.0.2~1) [8/27] espressif/esp-dsp (1.4.8) [9/27] espressif/esp-sr (1.4.2) [10/27] espressif/esp_codec_dev (1.0.3) [11/27] espressif/esp_lcd_ili9341 (1.1.0) [12/27] espressif/esp_lcd_touch (1.1.0) [13/27] espressif/esp_lcd_touch_gt911 (1.1.0) [14/27] espressif/esp_lcd_touch_tt21100 (1.1.0) [15/27] espressif/esp_lvgl_port (1.3.0) [16/27] espressif/esp_rainmaker (cc861bffc818c607e799f66c79923fd4e2d00447) [17/27] espressif/esp_schedule (cc861bffc818c607e799f66c79923fd4e2d00447) [18/27] espressif/esp_secure_cert_mgr (2.4.0) [19/27] espressif/icm42670 (1.0.0) [20/27] espressif/json_generator (1.1.1) [21/27] espressif/json_parser (1.0.0) [22/27] espressif/led_strip (2.0.0) [23/27] espressif/mdns (1.2.1) [24/27] espressif/qrcode (0.1.0~1) [25/27] espressif/rmaker_common (1.4.2) [26/27] idf (5.1.1) [27/27] lvgl/lvgl (8.3.10) -- PLATFORM ESP32_S3_BOX_3. -- Project sdkconfig file F:/01_ESP_STM_PRJ/ESP32/ESP-BOX/esp-box-master/examples/factory_demo/sdkconfig Loading defaults file F:/01_ESP_STM_PRJ/ESP32/ESP-BOX/esp-box-master/examples/factory_demo/sdkconfig.defaults... Compiler supported targets: xtensa-esp32s3-elf -- Looking for sys/types.h -- Looking for sys/types.h - found -- Looking for stdint.h -- Looking for stdint.h - found -- Looking for stddef.h -- Looking for stddef.h - found -- Check size of time_t -- Check size of time_t - done -- Found Python3: D:/Espressif/python_env/idf5.1_py3.11_env/Scripts/python.exe (found version "3.11.2") found components: Interpreter -- Performing Test C_COMPILER_SUPPORTS_WFORMAT_SIGNEDNESS -- Performing Test C_COMPILER_SUPPORTS_WFORMAT_SIGNEDNESS - Success -- App "factory_demo" version: 1 -- Adding linker script F:/01_ESP_STM_PRJ/ESP32/ESP-BOX/esp-box-master/examples/factory_demo/build/esp-idf/esp_system/ld/memory.ld -- Adding linker script D:/Espressif/frameworks/esp-idf-v5.1.1/components/esp_system/ld/esp32s3/sections.ld.in -- Adding linker script D:/Espressif/frameworks/esp-idf-v5.1.1/components/esp_rom/esp32s3/ld/esp32s3.rom.ld -- Adding linker script D:/Espressif/frameworks/esp-idf-v5.1.1/components/esp_rom/esp32s3/ld/esp32s3.rom.api.ld -- Adding linker script D:/Espressif/frameworks/esp-idf-v5.1.1/components/esp_rom/esp32s3/ld/esp32s3.rom.libgcc.ld -- Adding linker script D:/Espressif/frameworks/esp-idf-v5.1.1/components/esp_rom/esp32s3/ld/esp32s3.rom.newlib.ld -- Adding linker script D:/Espressif/frameworks/esp-idf-v5.1.1/components/esp_rom/esp32s3/ld/esp32s3.rom.version.ld -- Adding linker script D:/Espressif/frameworks/esp-idf-v5.1.1/components/soc/esp32s3/ld/esp32s3.peripherals.ld CMake Error at build/esp-idf/espressif__esp_rainmaker/CMakeFiles/git-data/grabRef.cmake:48 (file): file failed to open for reading (No such file or directory): F:/01_ESP_STM_PRJ/ESP32/ESP-BOX/esp-box-master/examples/factory_demo/build/esp-idf/espressif__esp_rainmaker/CMakeFiles/git-data/head-ref Call Stack (most recent call first): D:/Espressif/frameworks/esp-idf-v5.1.1/tools/cmake/third_party/GetGitRevisionDescription.cmake:83 (include) D:/Espressif/frameworks/esp-idf-v5.1.1/tools/cmake/third_party/GetGitRevisionDescription.cmake:93 (get_git_head_revision) managed_components/espressif__esp_rainmaker/CMakeLists.txt:70 (git_describe) ESP RainMaker Project commit: HEAD-HASH-NOTFOUND -- BUTTON: 2.5.4 -- ESP_LCD_ILI9341: 1.1.0 -- AHT20: 1.1.0 -- AT581X: 1.1.0 -- PLATFORM ESP32_S3_BOX_3. -- Relinker isn't enabled. -- IR_LEARN: 0.1.0 -- Components: app_trace app_update bootloader bootloader_support bsp bt chmorgan__esp-audio-player chmorgan__esp-file-iterator chmorgan__esp-libhelix-mp3 cmock console cxx driver efuse esp-tls esp_adc esp_app_format esp_coex esp_common esp_eth esp_event esp_gdbstub esp_hid esp_http_client esp_http_server esp_https_ota esp_https_server esp_hw_support esp_lcd esp_local_ctrl esp_mm esp_netif esp_netif_stack esp_partition esp_phy esp_pm esp_psram esp_ringbuf esp_rom esp_system esp_timer esp_wifi espcoredump espressif__aht20 espressif__at581x espressif__button espressif__cmake_utilities espressif__esp-box espressif__esp-box-3 espressif__esp-box-lite espressif__esp-dsp espressif__esp-sr espressif__esp_codec_dev espressif__esp_lcd_ili9341 espressif__esp_lcd_touch espressif__esp_lcd_touch_gt911 espressif__esp_lcd_touch_tt21100 espressif__esp_lvgl_port espressif__esp_rainmaker espressif__esp_schedule espressif__esp_secure_cert_mgr espressif__icm42670 espressif__ir_learn espressif__json_generator espressif__json_parser espressif__led_strip espressif__mdns espressif__qrcode espressif__rmaker_common esptool_py fatfs freertos hal heap http_parser idf_test ieee802154 json log lvgl__lvgl lwip main mbedtls mqtt newlib nvs_flash openthread partition_table perfmon protobuf-c protocomm pthread sdmmc soc spi_flash spiffs tcp_transport touch_element ulp unity usb vfs wear_levelling wifi_provisioning wpa_supplicant xtensa -- Component paths: D:/Espressif/frameworks/esp-idf-v5.1.1/components/app_trace D:/Espressif/frameworks/esp-idf-v5.1.1/components/app_update D:/Espressif/frameworks/esp-idf-v5.1.1/components/bootloader D:/Espressif/frameworks/esp-idf-v5.1.1/components/bootloader_support F:/01_ESP_STM_PRJ/ESP32/ESP-BOX/esp-box-master/components/bsp D:/Espressif/frameworks/esp-idf-v5.1.1/components/bt F:/01_ESP_STM_PRJ/ESP32/ESP-BOX/esp-box-master/examples/factory_demo/managed_components/chmorgan__esp-audio-player F:/01_ESP_STM_PRJ/ESP32/ESP-BOX/esp-box-master/examples/factory_demo/managed_components/chmorgan__esp-file-iterator F:/01_ESP_STM_PRJ/ESP32/ESP-BOX/esp-box-master/examples/factory_demo/managed_components/chmorgan__esp-libhelix-mp3 D:/Espressif/frameworks/esp-idf-v5.1.1/components/cmock D:/Espressif/frameworks/esp-idf-v5.1.1/components/console D:/Espressif/frameworks/esp-idf-v5.1.1/components/cxx D:/Espressif/frameworks/esp-idf-v5.1.1/components/driver D:/Espressif/frameworks/esp-idf-v5.1.1/components/efuse D:/Espressif/frameworks/esp-idf-v5.1.1/components/esp-tls D:/Espressif/frameworks/esp-idf-v5.1.1/components/esp_adc D:/Espressif/frameworks/esp-idf-v5.1.1/components/esp_app_format D:/Espressif/frameworks/esp-idf-v5.1.1/components/esp_coex D:/Espressif/frameworks/esp-idf-v5.1.1/components/esp_common D:/Espressif/frameworks/esp-idf-v5.1.1/components/esp_eth D:/Espressif/frameworks/esp-idf-v5.1.1/components/esp_event D:/Espressif/frameworks/esp-idf-v5.1.1/components/esp_gdbstub D:/Espressif/frameworks/esp-idf-v5.1.1/components/esp_hid D:/Espressif/frameworks/esp-idf-v5.1.1/components/esp_http_client D:/Espressif/frameworks/esp-idf-v5.1.1/components/esp_http_server D:/Espressif/frameworks/esp-idf-v5.1.1/components/esp_https_ota D:/Espressif/frameworks/esp-idf-v5.1.1/components/esp_https_server D:/Espressif/frameworks/esp-idf-v5.1.1/components/esp_hw_support D:/Espressif/frameworks/esp-idf-v5.1.1/components/esp_lcd D:/Espressif/frameworks/esp-idf-v5.1.1/components/esp_local_ctrl D:/Espressif/frameworks/esp-idf-v5.1.1/components/esp_mm D:/Espressif/frameworks/esp-idf-v5.1.1/components/esp_netif D:/Espressif/frameworks/esp-idf-v5.1.1/components/esp_netif_stack D:/Espressif/frameworks/esp-idf-v5.1.1/components/esp_partition D:/Espressif/frameworks/esp-idf-v5.1.1/components/esp_phy D:/Espressif/frameworks/esp-idf-v5.1.1/components/esp_pm D:/Espressif/frameworks/esp-idf-v5.1.1/components/esp_psram D:/Espressif/frameworks/esp-idf-v5.1.1/components/esp_ringbuf D:/Espressif/frameworks/esp-idf-v5.1.1/components/esp_rom D:/Espressif/frameworks/esp-idf-v5.1.1/components/esp_system D:/Espressif/frameworks/esp-idf-v5.1.1/components/esp_timer D:/Espressif/frameworks/esp-idf-v5.1.1/components/esp_wifi D:/Espressif/frameworks/esp-idf-v5.1.1/components/espcoredump F:/01_ESP_STM_PRJ/ESP32/ESP-BOX/esp-box-master/examples/factory_demo/components/espressif__aht20 F:/01_ESP_STM_PRJ/ESP32/ESP-BOX/esp-box-master/examples/factory_demo/components/espressif__at581x F:/01_ESP_STM_PRJ/ESP32/ESP-BOX/esp-box-master/examples/factory_demo/components/espressif__button F:/01_ESP_STM_PRJ/ESP32/ESP-BOX/esp-box-master/examples/factory_demo/managed_components/espressif__cmake_utilities F:/01_ESP_STM_PRJ/ESP32/ESP-BOX/esp-box-master/examples/factory_demo/managed_components/espressif__esp-box F:/01_ESP_STM_PRJ/ESP32/ESP-BOX/esp-box-master/examples/factory_demo/managed_components/espressif__esp-box-3 F:/01_ESP_STM_PRJ/ESP32/ESP-BOX/esp-box-master/examples/factory_demo/managed_components/espressif__esp-box-lite F:/01_ESP_STM_PRJ/ESP32/ESP-BOX/esp-box-master/examples/factory_demo/managed_components/espressif__esp-dsp F:/01_ESP_STM_PRJ/ESP32/ESP-BOX/esp-box-master/examples/factory_demo/managed_components/espressif__esp-sr F:/01_ESP_STM_PRJ/ESP32/ESP-BOX/esp-box-master/examples/factory_demo/managed_components/espressif__esp_codec_dev F:/01_ESP_STM_PRJ/ESP32/ESP-BOX/esp-box-master/examples/factory_demo/managed_components/espressif__esp_lcd_ili9341 F:/01_ESP_STM_PRJ/ESP32/ESP-BOX/esp-box-master/examples/factory_demo/managed_components/espressif__esp_lcd_touch F:/01_ESP_STM_PRJ/ESP32/ESP-BOX/esp-box-master/examples/factory_demo/managed_components/espressif__esp_lcd_touch_gt911 F:/01_ESP_STM_PRJ/ESP32/ESP-BOX/esp-box-master/examples/factory_demo/managed_components/espressif__esp_lcd_touch_tt21100 F:/01_ESP_STM_PRJ/ESP32/ESP-BOX/esp-box-master/examples/factory_demo/managed_components/espressif__esp_lvgl_port F:/01_ESP_STM_PRJ/ESP32/ESP-BOX/esp-box-master/examples/factory_demo/managed_components/espressif__esp_rainmaker F:/01_ESP_STM_PRJ/ESP32/ESP-BOX/esp-box-master/examples/factory_demo/managed_components/espressif__esp_schedule F:/01_ESP_STM_PRJ/ESP32/ESP-BOX/esp-box-master/examples/factory_demo/managed_components/espressif__esp_secure_cert_mgr F:/01_ESP_STM_PRJ/ESP32/ESP-BOX/esp-box-master/examples/factory_demo/managed_components/espressif__icm42670 F:/01_ESP_STM_PRJ/ESP32/ESP-BOX/esp-box-master/examples/factory_demo/components/espressif__ir_learn F:/01_ESP_STM_PRJ/ESP32/ESP-BOX/esp-box-master/examples/factory_demo/managed_components/espressif__json_generator F:/01_ESP_STM_PRJ/ESP32/ESP-BOX/esp-box-master/examples/factory_demo/managed_components/espressif__json_parser F:/01_ESP_STM_PRJ/ESP32/ESP-BOX/esp-box-master/examples/factory_demo/managed_components/espressif__led_strip F:/01_ESP_STM_PRJ/ESP32/ESP-BOX/esp-box-master/examples/factory_demo/managed_components/espressif__mdns F:/01_ESP_STM_PRJ/ESP32/ESP-BOX/esp-box-master/examples/factory_demo/managed_components/espressif__qrcode F:/01_ESP_STM_PRJ/ESP32/ESP-BOX/esp-box-master/examples/factory_demo/managed_components/espressif__rmaker_common D:/Espressif/frameworks/esp-idf-v5.1.1/components/esptool_py D:/Espressif/frameworks/esp-idf-v5.1.1/components/fatfs D:/Espressif/frameworks/esp-idf-v5.1.1/components/freertos D:/Espressif/frameworks/esp-idf-v5.1.1/components/hal D:/Espressif/frameworks/esp-idf-v5.1.1/components/heap D:/Espressif/frameworks/esp-idf-v5.1.1/components/http_parser D:/Espressif/frameworks/esp-idf-v5.1.1/components/idf_test D:/Espressif/frameworks/esp-idf-v5.1.1/components/ieee802154 D:/Espressif/frameworks/esp-idf-v5.1.1/components/json D:/Espressif/frameworks/esp-idf-v5.1.1/components/log F:/01_ESP_STM_PRJ/ESP32/ESP-BOX/esp-box-master/examples/factory_demo/managed_components/lvgl__lvgl D:/Espressif/frameworks/esp-idf-v5.1.1/components/lwip F:/01_ESP_STM_PRJ/ESP32/ESP-BOX/esp-box-master/examples/factory_demo/main D:/Espressif/frameworks/esp-idf-v5.1.1/components/mbedtls D:/Espressif/frameworks/esp-idf-v5.1.1/components/mqtt D:/Espressif/frameworks/esp-idf-v5.1.1/components/newlib D:/Espressif/frameworks/esp-idf-v5.1.1/components/nvs_flash D:/Espressif/frameworks/esp-idf-v5.1.1/components/openthread D:/Espressif/frameworks/esp-idf-v5.1.1/components/partition_table D:/Espressif/frameworks/esp-idf-v5.1.1/components/perfmon D:/Espressif/frameworks/esp-idf-v5.1.1/components/protobuf-c D:/Espressif/frameworks/esp-idf-v5.1.1/components/protocomm D:/Espressif/frameworks/esp-idf-v5.1.1/components/pthread D:/Espressif/frameworks/esp-idf-v5.1.1/components/sdmmc D:/Espressif/frameworks/esp-idf-v5.1.1/components/soc D:/Espressif/frameworks/esp-idf-v5.1.1/components/spi_flash D:/Espressif/frameworks/esp-idf-v5.1.1/components/spiffs D:/Espressif/frameworks/esp-idf-v5.1.1/components/tcp_transport D:/Espressif/frameworks/esp-idf-v5.1.1/components/touch_element D:/Espressif/frameworks/esp-idf-v5.1.1/components/ulp D:/Espressif/frameworks/esp-idf-v5.1.1/components/unity D:/Espressif/frameworks/esp-idf-v5.1.1/components/usb D:/Espressif/frameworks/esp-idf-v5.1.1/components/vfs D:/Espressif/frameworks/esp-idf-v5.1.1/components/wear_levelling D:/Espressif/frameworks/esp-idf-v5.1.1/components/wifi_provisioning D:/Espressif/frameworks/esp-idf-v5.1.1/components/wpa_supplicant D:/Espressif/frameworks/esp-idf-v5.1.1/components/xtensa -- Configuring incomplete, errors occurred! See also "F:/01_ESP_STM_PRJ/ESP32/ESP-BOX/esp-box-master/examples/factory_demo/build/CMakeFiles/CMakeOutput.log". cmake failed with exit code 1, output of the command is in the F:�1_ESP_STM_PRJESP32ESP-BOXesp-box-masterexamplesfactory_demobuildlogidf_py_stderr_output_18504 and F:�1_ESP_STM_PRJESP32ESP-BOXesp-box-masterexamplesfactory_demobuildlogidf_py_stdout_output_18504 |
1个回答
从您提供的错误信息来看,这个问题可能是由于以下几个原因导致的:
1. **IDF_TARGET未设置**:错误信息中提到 "IDF_TARGET is not set",这意味着ESP-IDF编译环境没有正确识别您的目标硬件平台。您可以通过设置环境变量`IDF_TARGET`来解决这个问题。例如,如果您使用的是ESP32,您可以在命令行中运行以下命令: ```bash export IDF_TARGET=esp32 ``` 或者在CMake命令中直接指定: ```bash cmake -G Ninja -DPYTHON_DEPS_CHECKED=1 -DPYTHON=D:Espressifpython_envidf5.1_py3.11_envScriptspython.exe -DESP_PLATFORM=1 -DCCACHE_ENABLE=1 -DIDF_TARGET=esp32 F:/1_ESP_STM_PRJ/ESP32/ESP-BOX/esp-box-master/examples/factory_demo ``` 2. **路径问题**:您的路径中包含了一些特殊字符,如``,这可能会导致编译器无法正确解析路径。请检查您的路径是否正确,并确保没有包含非法字符。 3. **Python环境问题**:错误信息中提到了Python的路径,确保您的Python环境已经正确设置,并且与ESP-IDF兼容。您可能需要检查您的Python环境变量是否正确设置。 4. **CMake配置问题**:CMake命令中的参数可能需要调整以适应您的项目需求。请确保所有必要的参数都已经正确设置。 5. **ESP-IDF版本问题**:确保您使用的ESP-IDF版本与您的硬件和项目需求兼容。如果您使用的是ESP32,但ESP-IDF版本是为ESP32-S3设计的,那么可能会出现兼容性问题。 6. **项目依赖问题**:检查项目是否缺少必要的依赖,或者依赖是否正确安装。 解决这个问题,您需要逐步检查上述可能的原因,并进行相应的调整。如果问题仍然存在,您可能需要查看更详细的错误信息或日志,以便找到更具体的问题所在。 |
只有小组成员才能发言,加入小组>>
429浏览 6评论
362浏览 5评论
有没有办法在不使用混杂模式的情况下实现Wifi驱动程序接收缓冲区访问中断呢?
343浏览 5评论
349浏览 4评论
327浏览 4评论
GMT+8, 2024-9-1 06:38 , Processed in 0.778039 second(s), Total 81, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
