ESP32-WROOM-32D 和电脑连接到同一个Wifi路由器上,ping命令测试
发送1683,最短2ms,最长2119ms,平均222ms, 测试结果是不是有问题? 有人测试过么? 程序代码如下: main.c /* WiFi sta+ap */ #include #include "freertos/FreeRTOS.h" #include "freertos/task.h" #include "freertos/event_groups.h" #include "esp_system.h" #include "esp_wifi.h" #include "esp_event.h" #include "esp_log.h" #include "nvs_flash.h" #include "lwip/err.h" #include "lwip/sys.h" #define SET_REMOTE_WIFI_SSID CONFIG_REMOTE_WIFI_SSID #define SET_REMOTE_WIFI_PASS CONFIG_REMOTE_WIFI_PASSWORD #define SET_ESP_MAXIMUM_RETRY CONFIG_ESP_MAXIMUM_RETRY #define SET_LOCAL_WIFI_SSID CONFIG_LOCAL_WIFI_SSID #define SET_LOCAL_WIFI_PASS CONFIG_LOCAL_WIFI_PASSWORD /* FreeRTOS event group to signal when we are connected*/ EventGroupHandle_t s_wifi_event_group; /* The event group allows multiple bits for each event, but we only care about one event * - are we connected to the AP with an IP? */ const int WIFI_CONNECTED_BIT = BIT0; static const char *TAG = "wifiApStaMain"; static int s_retry_num = 0; static void event_handler(void* arg, esp_event_base_t event_base, int32_t event_id, void* event_data) { if (event_base == WIFI_EVENT && event_id == WIFI_EVENT_STA_START) { esp_wifi_connect(); } else if (event_base == WIFI_EVENT && event_id == WIFI_EVENT_STA_DISCONNECTED) { if (s_retry_num < SET_ESP_MAXIMUM_RETRY) { esp_wifi_connect(); xEventGroupClearBits(s_wifi_event_group, WIFI_CONNECTED_BIT); s_retry_num++; ESP_LOGI(TAG, "retry to connect to the AP"); } ESP_LOGI(TAG,"connect to the AP fail"); } else if (event_base == IP_EVENT && event_id == IP_EVENT_STA_GOT_IP) { ip_event_got_ip_t* event = (ip_event_got_ip_t*) event_data; ESP_LOGI(TAG, "got ip:%s", ip4addr_ntoa(&event->ip_info.ip)); s_retry_num = 0; xEventGroupSetBits(s_wifi_event_group, WIFI_CONNECTED_BIT); } else if (event_id == WIFI_EVENT_AP_STACONNECTED) { wifi_event_ap_staconnected_t* event = (wifi_event_ap_staconnected_t*) event_data; ESP_LOGI(TAG, "station "MACSTR" join, AID=%d", MAC2STR(event->mac), event->aid); } else if (event_id == WIFI_EVENT_AP_STADISCONNECTED) { wifi_event_ap_stadisconnected_t* event = (wifi_event_ap_stadisconnected_t*) event_data; ESP_LOGI(TAG, "station "MACSTR" leave, AID=%d", MAC2STR(event->mac), event->aid); } } void wifi_init(void) { s_wifi_event_group = xEventGroupCreate(); tcpip_adapter_init(); ESP_ERROR_CHECK(esp_event_loop_create_default()); wifi_init_config_t cfg = WIFI_INIT_CONFIG_DEFAULT(); ESP_ERROR_CHECK(esp_wifi_init(&cfg)); ESP_ERROR_CHECK(esp_event_handler_register(WIFI_EVENT, ESP_EVENT_ANY_ID, &event_handler, NULL)); ESP_ERROR_CHECK(esp_event_handler_register(IP_EVENT, IP_EVENT_STA_GOT_IP, &event_handler, NULL)); wifi_config_t wifi_config_sta = { .sta = { .ssid = SET_REMOTE_WIFI_SSID, .password = SET_REMOTE_WIFI_PASS }, }; wifi_config_t wifi_config_ap = { .ap = { .ssid = SET_LOCAL_WIFI_SSID, .ssid_len = strlen(SET_LOCAL_WIFI_SSID), .password = SET_LOCAL_WIFI_PASS, .max_connection = SET_ESP_MAXIMUM_RETRY, .authmode = WIFI_AUTH_WPA_WPA2_PSK }, }; if (strlen(SET_LOCAL_WIFI_PASS) == 0) { wifi_config_ap.ap.authmode = WIFI_AUTH_OPEN; } ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_APSTA) ); //ap+ata模式 ESP_ERROR_CHECK(esp_wifi_set_config(ESP_IF_WIFI_STA, &wifi_config_sta) ); ESP_ERROR_CHECK(esp_wifi_set_config(ESP_IF_WIFI_AP, &wifi_config_ap) ); //esp_err_t tcpip_adapter_set_ip_info(tcpip_adapter_if_t tcpip_if, const tcpip_adapter_ip_info_t *ip_info); tcpip_adapter_ip_info_t ipInfo; ipInfo.ip.addr=ipaddr_addr("192.168.5.2"); ipInfo.netmask.addr=ipaddr_addr("255.255.255.0"); ipInfo.gw.addr=ipaddr_addr("192.168.5.1"); ESP_ERROR_CHECK(tcpip_adapter_dhcps_stop(TCPIP_ADAPTER_IF_AP) ); ESP_ERROR_CHECK(tcpip_adapter_set_ip_info(TCPIP_ADAPTER_IF_AP,&ipInfo) ); ESP_ERROR_CHECK(esp_wifi_start() ); ESP_LOGI(TAG, "sta connect to remote ap SSID:%s password:%s",SET_REMOTE_WIFI_SSID, SET_REMOTE_WIFI_SSID); ESP_LOGI(TAG, "wifi_init_softap finished. SSID:%s password:%s",SET_LOCAL_WIFI_SSID, SET_LOCAL_WIFI_PASS); } extern void tcp_server_init(void); extern void tcp_client_init(void); void app_main(void) { //Initialize NVS esp_err_t ret = nvs_flash_init(); if (ret == ESP_ERR_NVS_NO_FREE_PAGES || ret == ESP_ERR_NVS_NEW_VERSION_FOUND) { ESP_ERROR_CHECK(nvs_flash_erase()); ret = nvs_flash_init(); } ESP_ERROR_CHECK(ret); ESP_LOGI(TAG, "ESP_WIFI_MODE_APSTA 000"); wifi_init(); tcp_server_init(); tcp_client_init(); } //tcpClinet.c #include #include #include "freertos/FreeRTOS.h" #include "freertos/task.h" #include "freertos/event_groups.h" #include "esp_system.h" #include "esp_wifi.h" #include "esp_event.h" #include "esp_log.h" #include "nvs_flash.h" #include "tcpip_adapter.h" //#include "protocol_examples_common.h" #include "lwip/err.h" #include "lwip/sockets.h" #include "lwip/sys.h" #include #define HOST_IP_ADDR "192.168.212.168" #define PORT 60000 static const char *TAG = "tcpClinet"; static const char *payload = "Message from ESP32 "; static void tcp_client_task(void *pvParameters) { char rx_buffer[128]; char addr_str[128]; int addr_family; int ip_protocol; while (1) { struct sockaddr_in dest_addr; dest_addr.sin_addr.s_addr = inet_addr(HOST_IP_ADDR); dest_addr.sin_family = AF_INET; dest_addr.sin_port = htons(PORT); addr_family = AF_INET; ip_protocol = IPPROTO_IP; inet_ntoa_r(dest_addr.sin_addr, addr_str, sizeof(addr_str) - 1); int sock = socket(addr_family, SOCK_STREAM, ip_protocol); if (sock < 0) { ESP_LOGE(TAG, "Unable to create socket: errno %d", errno); break; } ESP_LOGI(TAG, "Socket created, connecting to %s:%d", HOST_IP_ADDR, PORT); int err = connect(sock, (struct sockaddr *)&dest_addr, sizeof(dest_addr)); if (err != 0) { ESP_LOGE(TAG, "Socket unable to connect: errno %d", errno); break; } ESP_LOGI(TAG, "Successfully connected"); while (1) { int err = send(sock, payload, strlen(payload), 0); if (err < 0) { ESP_LOGE(TAG, "Error occurred during sending: errno %d", errno); break; } int len = recv(sock, rx_buffer, sizeof(rx_buffer) - 1, 0); // Error occurred during receiving if (len < 0) { ESP_LOGE(TAG, "recv failed: errno %d", errno); break; } // Data received else { rx_buffer[len] = 0; // Null-terminate whatever we received and treat like a string ESP_LOGI(TAG, "Received %d bytes from %s:", len, addr_str); ESP_LOGI(TAG, "%s", rx_buffer); } vTaskDelay(2000 / portTICK_PERIOD_MS); } if (sock != -1) { ESP_LOGE(TAG, "Shutting down client socket and restarting..."); shutdown(sock, 0); close(sock); } } vTaskDelete(NULL); } extern EventGroupHandle_t s_wifi_event_group; extern const int WIFI_CONNECTED_BIT ; void tcp_client_init(void) { const TickType_t xTicksToWait = 100 / portTICK_PERIOD_MS; EventBits_t Bits; while (1) { Bits=xEventGroupWaitBits(s_wifi_event_group, WIFI_CONNECTED_BIT,pdFALSE,pdTRUE,xTicksToWait ); if( (Bits&WIFI_CONNECTED_BIT)==WIFI_CONNECTED_BIT){ break; } } xTaskCreate(tcp_client_task, "tcp_client", 4096, NULL, 5, NULL); } ///////tcpServer.c #include #include #include "freertos/FreeRTOS.h" #include "freertos/task.h" #include "esp_system.h" #include "esp_wifi.h" #include "esp_event.h" #include "esp_log.h" #include "nvs_flash.h" #include "tcpip_adapter.h" //#include "protocol_examples_common.h" #include "lwip/err.h" #include "lwip/sockets.h" #include "lwip/sys.h" #include #define PORT 60000 static const char *TAG = "tcpServer"; static void tcp_server_task(void *pvParameters) { char rx_buffer[128]; char addr_str[128]; int addr_family; int ip_protocol; while (1) { #ifdef CONFIG_EXAMPLE_IPV4 struct sockaddr_in dest_addr; dest_addr.sin_addr.s_addr = htonl(INADDR_ANY); dest_addr.sin_family = AF_INET; dest_addr.sin_port = htons(PORT); addr_family = AF_INET; ip_protocol = IPPROTO_IP; inet_ntoa_r(dest_addr.sin_addr, addr_str, sizeof(addr_str) - 1); #else // IPV6 struct sockaddr_in6 dest_addr; bzero(&dest_addr.sin6_addr.un, sizeof(dest_addr.sin6_addr.un)); dest_addr.sin6_family = AF_INET6; dest_addr.sin6_port = htons(PORT); addr_family = AF_INET6; ip_protocol = IPPROTO_IPV6; inet6_ntoa_r(dest_addr.sin6_addr, addr_str, sizeof(addr_str) - 1); #endif int listen_sock = socket(addr_family, SOCK_STREAM, ip_protocol); if (listen_sock < 0) { ESP_LOGE(TAG, "Unable to create socket: errno %d", errno); break; } ESP_LOGI(TAG, "Socket created"); int err = bind(listen_sock, (struct sockaddr *)&dest_addr, sizeof(dest_addr)); if (err != 0) { ESP_LOGE(TAG, "Socket unable to bind: errno %d", errno); break; } ESP_LOGI(TAG, "Socket bound, port %d", PORT); err = listen(listen_sock, 1); if (err != 0) { ESP_LOGE(TAG, "Error occurred during listen: errno %d", errno); break; } ESP_LOGI(TAG, "Socket listening"); struct sockaddr_in6 source_addr; // Large enough for both IPv4 or IPv6 uint addr_len = sizeof(source_addr); int sock = accept(listen_sock, (struct sockaddr *)&source_addr, &addr_len); if (sock < 0) { ESP_LOGE(TAG, "Unable to accept connection: errno %d", errno); break; } ESP_LOGI(TAG, "Socket accepted"); while (1) { int len = recv(sock, rx_buffer, sizeof(rx_buffer) - 1, 0); // Error occurred during receiving if (len < 0) { ESP_LOGE(TAG, "recv failed: errno %d", errno); break; } // Connection closed else if (len == 0) { ESP_LOGI(TAG, "Connection closed"); break; } // Data received else { // Get the sender's ip address as string if (source_addr.sin6_family == PF_INET) { inet_ntoa_r(((struct sockaddr_in *)&source_addr)->sin_addr.s_addr, addr_str, sizeof(addr_str) - 1); } else if (source_addr.sin6_family == PF_INET6) { inet6_ntoa_r(source_addr.sin6_addr, addr_str, sizeof(addr_str) - 1); } rx_buffer[len] = 0; // Null-terminate whatever we received and treat like a string ESP_LOGI(TAG, "Received %d bytes from %s:", len, addr_str); ESP_LOGI(TAG, "%s", rx_buffer); int err = send(sock, rx_buffer, len, 0); if (err < 0) { ESP_LOGE(TAG, "Error occurred during sending: errno %d", errno); break; } } } if (sock != -1) { ESP_LOGE(TAG, "Shutting down Server socket and restarting..."); shutdown(sock, 0); close(sock); } } vTaskDelete(NULL); } void tcp_server_init(void) { xTaskCreate(tcp_server_task, "tcp_server", 4096, NULL, 5, NULL); } 串口返回日志如下: rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT) configsip: 0, SPIWP:0xee clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 mode:DIO, clock div:2 load:0x3fff0018,len:4 load:0x3fff001c,len:6440 load:0x40078000,len:11368 load:0x40080400,len:6636 entry 0x40080768 I (28) boot: ESP-IDF v4.1-dev-58-g02c7c3885 2nd stage bootloader I (28) boot: compile time 17:18:57 I (28) boot: Enabling RNG early entropy source... I (34) boot: SPI Speed : 40MHz I (38) boot: SPI Mode : DIO I (42) boot: SPI Flash Size : 2MB I (46) boot: Partition Table: I (50) boot: ## Label Usage Type ST Offset Length I (57) boot: 0 nvs WiFi data 01 02 00009000 00006000 I (65) boot: 1 phy_init RF data 01 01 0000f000 00001000 I (72) boot: 2 factory factory app 00 00 00010000 00100000 I (80) boot: End of partition table I (84) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x156d0 ( 87760) map I (124) esp_image: segment 1: paddr=0x000256f8 vaddr=0x3ffb0000 size=0x031f8 ( 12792) load I (129) esp_image: segment 2: paddr=0x000288f8 vaddr=0x40080000 size=0x00400 ( 1024) load 0x40080000: _WindowOverflow4 at /home/work/esp/esp-idf/components/freertos/xtensa_vectors.S:1778 I (131) esp_image: segment 3: paddr=0x00028d00 vaddr=0x40080400 size=0x07310 ( 29456) load I (152) esp_image: segment 4: paddr=0x00030018 vaddr=0x400d0018 size=0x6d088 (446600) map 0x400d0018: _stext at ??:? I (312) esp_image: segment 5: paddr=0x0009d0a8 vaddr=0x40087710 size=0x08ffc ( 36860) load 0x40087710: ppCalTxAMPDULength at ??:? I (338) boot: Loaded app from partition at offset 0x10000 I (338) boot: Disabling RNG early entropy source... I (339) cpu_start: Pro cpu up. I (342) cpu_start: Application information: I (347) cpu_start: Project name: wifi_station_softAP I (353) cpu_start: App version: 1 I (358) cpu_start: Compile time: Sep 16 2019 15:55:13 I (364) cpu_start: ELF file SHA256: 2031555a16607440... I (370) cpu_start: ESP-IDF: v4.1-dev-58-g02c7c3885-dirty I (376) cpu_start: Starting app cpu, entry point is 0x4008128c 0x4008128c: call_start_cpu1 at /home/work/esp/esp-idf/components/esp32/cpu_start.c:281 I (0) cpu_start: App cpu up. I (387) heap_init: Initializing. RAM available for dynamic allocation: I (394) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM I (400) heap_init: At 3FFB90E0 len 00026F20 (155 KiB): DRAM I (406) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM I (412) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM I (419) heap_init: At 4009070C len 0000F8F4 (62 KiB): IRAM I (425) cpu_start: Pro cpu start user code I (443) spi_flash: detected chip: generic I (444) spi_flash: flash io: dio W (444) spi_flash: Detected size(4096k) larger than the size in the binary image header(2048k). Using the size in the binary image header. I (454) cpu_start: Chip Revision: 1 W (459) cpu_start: Chip revision is higher than the one configured in menuconfig. Suggest to upgrade it. I (469) cpu_start: Starting scheduler on PRO CPU. I (0) cpu_start: Starting scheduler on APP CPU. I (538) wifiApStaMain: ESP_WIFI_MODE_APSTA 000 I (548) wifi: wifi driver task: 3ffc0b68, prio:23, stack:3584, core=0 I (548) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE I (548) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE I (578) wifi: wifi firmware version: 6236ba1 I (578) wifi: config NVS flash: enabled I (578) wifi: config nano formating: disabled I (578) wifi: Init dynamic tx buffer num: 32 I (578) wifi: Init data frame dynamic rx buffer num: 32 I (588) wifi: Init management frame dynamic rx buffer num: 32 I (588) wifi: Init management short buffer num: 32 I (598) wifi: Init static rx buffer size: 1600 I (598) wifi: Init static rx buffer num: 10 I (608) wifi: Init dynamic rx buffer num: 32 I (698) phy: phy_version: 4102, 2fa7a43, Jul 15 2019, 13:06:06, 0, 0 I (698) wifi: mode : sta (4c:11:ae:71:16:dc) + softAP (4c:11:ae:71:16:dd) I (708) wifi: Total power save buffer number: 16 I (708) wifi: Init max length of beacon: 752/752 I (708) wifi: Init max length of beacon: 752/752 I (718) wifiApStaMain: sta connect to remote ap SSID:HLXX-yfzx password:HLXX-yfzx I (728) wifiApStaMain: wifi_init_softap finished. SSID:ESP32-AP password:0000aaaa I (728) tcpServer: Socket created I (738) tcpServer: Socket bound, port 60000 I (738) tcpServer: Socket listening I (838) wifi: ap channel adjust o:1,1 n:6,2 I (838) wifi: new:<6,0>, old:<1,0>, ap:<6,2>, sta:<6,0>, prof:1 I (838) wifi: state: init -> auth (b0) I (848) wifi: state: auth -> assoc (0) I (848) wifi: state: assoc -> run (10) I (1058) wifi: connected with HLXX-yfzx, channel 6, BW20, bssid = f4:ec:38:66:61:c8 I (1058) wifi: pm start, type: 1 I (3038) tcpip_adapter: sta ip: 192.168.212.107, mask: 255.255.255.0, gw: 192.168.212.1 I (3038) wifiApStaMain: got ip:192.168.212.107 I (3038) tcpClinet: Socket created, connecting to 192.168.212.168:60000 I (4578) tcpClinet: Successfully connected I (10108) tcpClinet: Received 0 bytes from 192.168.212.168: |
1个回答
首先,我们来分析一下您的问题。您提到ESP32-WROOM-32D和电脑连接到同一个WiFi路由器上,使用ping命令测试,平均返回时间为222ms。接下来,我们将逐步分析可能的原因和解决方案。
1. 网络环境:网络环境对ping命令的响应时间有很大影响。如果您的网络环境不稳定或者存在干扰,可能导致ping命令的响应时间较长。建议您检查网络环境,确保网络稳定。 2. 路由器性能:路由器的性能也会影响ping命令的响应时间。如果您的路由器性能较低或者负载较高,可能导致ping命令的响应时间较长。建议您检查路由器的性能和负载情况。 3. ESP32-WROOM-32D性能:ESP32-WROOM-32D的性能也可能影响ping命令的响应时间。建议您检查ESP32-WROOM-32D的性能,确保其正常工作。 4. 程序代码:您提供的代码片段不完整,无法判断是否存在问题。建议您检查程序代码,确保没有错误或者性能瓶颈。 5. ping命令参数:您提到发送了1683个ping请求,最短2ms,最长2119ms。这个数据范围较大,可能是由于某些请求受到了网络延迟或者丢包的影响。建议您尝试减少ping请求的数量,观察是否仍然存在类似问题。 6. 测试方法:您可以尝试使用其他设备和网络环境进行测试,以排除设备或网络环境对测试结果的影响。 综上所述,要判断测试结果是否存在问题,需要从多个方面进行分析。建议您按照上述建议进行检查和优化,以获得更准确的测试结果。 |
只有小组成员才能发言,加入小组>>
598 浏览 1 评论
552浏览 6评论
461浏览 5评论
有没有办法在不使用混杂模式的情况下实现Wifi驱动程序接收缓冲区访问中断呢?
443浏览 5评论
445浏览 4评论
415浏览 4评论
GMT+8, 2024-11-24 05:38 , Processed in 0.649877 second(s), Total 77, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
