电子发烧友论坛|
新买的esp32-s2-wrover模块下载smart-panel下载程序之后系统跑不起来
SP-ROM:esp32s2-rc4-20191025 Build:Oct 25 2019 rst:0x1 (POWERON),boot:0x8 (SPI_FAST_FLASH_BOOT) SPIWP:0xee mode:DIO, clock div:1 load:0x3ffe6100,len:0x1a18 load:0x4004c000,len:0xd5c load:0x40050000,len:0x2ce0 entry 0x4004c244 用UART 115200 只打印了以上几行,后面是乱码,UART调成 2000000 也是乱码。 使用ESP32-S2-HMI-DevKit-1开发板,下载smart-panel应用(idf.py -p COMX flash)可以正常启动 SP-ROM:esp32s2-rc4-20191025 Build:Oct 25 2019 rst:0x1 (POWERON),boot:0x8 (SPI_FAST_FLASH_BOOT) SPIWP:0xee mode:DIO, clock div:1 load:0x3ffe6100,len:0x1a18 load:0x4004c000,len:0xd5c load:0x40050000,len:0x2ce0 entry 0x4004c244 boot: ESP-IDF v4.3.1-dirty 2nd stage bootloader[0m [0;32mI (21) boot: compile time 21:00:24[0m [0;32mI (21) boot: chip revision: 0[0m [0;32mI (22) qio_mode: Enabling default flash chip QIO[0m [0;32mI (22) boot.esp32s2: SPI Speed : 80MHz[0m [0;32mI (22) boot.esp32s2: SPI Mode : QIO[0m [0;32mI (22) boot.esp32s2: SPI Flash Size : 4MB[0m [0;32mI (23) boot: Enabling RNG early entropy source...[0m [0;32mI (23) boot: Partition Table:[0m [0;32mI (23) boot: ## Label Usage Type ST Offset Length[0m [0;32mI (23) boot: 0 nvs WiFi data 01 02 00009000 00006000[0m [0;32mI (24) boot: 1 phy_init RF data 01 01 0000f000 00001000[0m [0;32mI (24) boot: 2 factory factory app 00 00 00010000 00226000[0m [0;32mI (25) boot: 3 storage Unknown data 01 82 00236000 001a9000[0m [0;32mI (25) boot: End of partition table[0m [0;32mI (25) esp_image: segment 0: paddr=00010020 vaddr=3f000020 size=10592ch (1071404) map[0m [0;32mI (210) esp_image: segment 1: paddr=00115954 vaddr=3ffcb830 size=04508h ( 17672) load[0m [0;32mI (214) esp_image: segment 2: paddr=00119e64 vaddr=40024000 size=061b4h ( 25012) load[0m [0;32mI (219) esp_image: segment 3: paddr=00120020 vaddr=40080020 size=e8770h (952176) map[0m [0;32mI (383) esp_image: segment 4: paddr=00208798 vaddr=4002a1b4 size=11678h ( 71288) load[0m [0;32mI (399) esp_image: segment 5: paddr=00219e18 vaddr=50000000 size=00010h ( 16) load[0m [0;32mI (411) boot: Loaded app from partition at offset 0x10000[0m [0;32mI (411) boot: Disabling RNG early entropy source...[0m [0;32mI (412) cache: Instruction cache : size 8KB, 4Ways, cache line size 32Byte[0m [0;32mI (412) cache: Data cache : size 8KB, 4Ways, cache line size 32Byte[0m [0;32mI (412) spiram: Found 16MBit SPI RAM device[0m [0;32mI (412) spiram: SPI RAM mode: sram 80m[0m [0;32mI (412) spiram: PSRAM initialized, cache is in normal (1-core) mode.[0m [0;32mI (413) cpu_start: Pro cpu up.[0m [0;32mI (632) spiram: SPI SRAM memory test OK[0m [0;32mI (641) cpu_start: Pro cpu start user code[0m [0;32mI (641) cpu_start: cpu freq: 240000000[0m [0;32mI (641) cpu_start: Application information:[0m [0;32mI (641) cpu_start: Project name: smart-panel[0m [0;32mI (641) cpu_start: App version: v4.3.1-dirty[0m [0;32mI (642) cpu_start: Compile time: Oct 14 2021 17:16:25[0m [0;32mI (642) cpu_start: ELF file SHA256: 287b57eb9674271c...[0m [0;32mI (642) cpu_start: ESP-IDF: v4.3.1-dirty[0m [0;32mI (643) heap_init: Initializing. RAM available for dynamic allocation:[0m [0;32mI (643) heap_init: At 3FF9E000 len 00002000 (8 KiB): RTCRAM[0m [0;32mI (643) heap_init: At 3FFD5D70 len 00026290 (152 KiB): DRAM[0m [0;32mI (644) heap_init: At 3FFFC000 len 00003A10 (14 KiB): DRAM[0m [0;32mI (644) spiram: Adding pool of 2048K of external SPI memory to heap allocator[0m [0;32mI (645) spi_flash: detected chip: generic[0m [0;32mI (645) spi_flash: flash io: qio[0m [0;32mI (649) cpu_start: Starting scheduler on PRO CPU.[0m [0;32mI (660) i2c_bus: i2c0 bus inited[0m [0;32mI (714) ESP32S2_I2S_LCD: lcd_buffer_size: 32000, lcd_dma_size: 4000, lcd_dma_node_cnt: 8[0m [0;32mI (714) ESP32S2_I2S_LCD: lcd init ok[0m [0;32mI (934) lcd rm68120: MADCTL=0x60[0m [0;32mI (934) bsp_lcd: Screen name : [RM68120] | width : [800] | height : [480][0m [0;32mI (941) lv_fs: Initializing SPIFFS as demo assets storage.[0m [0;32mI (995) lv_fs: Partition size: total: 1592846, used: 1433963[0m [0;32mI (996) sys_check: Check for PSRAM avaliable size[0m [0;32mI (1053) sys_check: Check for PCM audio file in "Music" folder[0m [0;32mI (3522) app_music: File[0] : Audio.pcm, Size : 133000, time : 3.016[0m [0;32mI (3533) app_music: Find 1 muisc files on storage[0m [0;32mI (3533) app_music: File name : [Audio.pcm], File size : [133000][0m [0;32mI (3579) fs_hal: Open file : [/spiffs/Music/Audio.pcm][0m [0;32mI (3580) app_music: Open file 0[0m V (3624) esp_qcloud_mem: Alloc ptr: 0x3fe18f80, size: 20, heap free: 1465331[0m V (3625) esp_qcloud_mem: Alloc ptr: 0x3fe18fa8, size: 20, heap free: 1462779[0m I (3628) wifi:wifi driver task: 3fff4640, prio:23, stack:6656, core=0 [0;32mI (3628) system_api: Base MAC address is not set[0m [0;32mI (3628) system_api: read default base MAC address from EFUSE[0m I (3631) wifi:wifi firmware version: 88c8747 I (3631) wifi:wifi certification version: v7.0 I (3632) wifi:config NVS flash: enabled I (3632) wifi:config nano formating: disabled I (3632) wifi:Init data frame dynamic rx buffer num: 4 I (3632) wifi:Init management frame dynamic rx buffer num: 4 I (3632) wifi:Init management short buffer num: 32 I (3633) wifi:Init static tx buffer num: 4 I (3633) wifi:Init tx cache buffer num: 16 I (3633) wifi:Init static rx buffer size: 1600 I (3633) wifi:Init static rx buffer num: 4 I (3634) wifi:Init dynamic rx buffer num: 4 [0;32mI (3634) wifi_init: rx ba win: 4[0m [0;32mI (3634) wifi_init: tcpip mbox: 32[0m [0;32mI (3634) wifi_init: udp mbox: 6[0m [0;32mI (3634) wifi_init: tcp mbox: 6[0m [0;32mI (3635) wifi_init: tcp tx win: 5744[0m [0;32mI (3635) wifi_init: tcp rx win: 5744[0m [0;32mI (3635) wifi_init: tcp mss: 1440[0m [0;32mI (3635) wifi_init: WiFi/LWIP prefer SPIRAM[0m [0;32mI (3635) wifi_init: WiFi IRAM OP enabled[0m [0;32mI (3636) wifi_init: WiFi RX IRAM OP enabled[0m [0;32mI (3637) phy_init: phy_version 1800,e7ef680,Apr 13 2021,11:45:08[0m 也使用过 idf.py -p COM4 erase_flash 对模块内部FLASH进行清除的,买回来的模块打印是正常的(UART 115200) 不清楚问题出在哪里?请大伙帮忙分析一下 |
1个回答
根据您提供的信息,您的ESP32-S2-WROVER模块在下载程序后无法正常运行。这里有几个可能的原因和解决方案:
1. **固件版本不兼容**:您提到使用的是2019年的固件版本(esp32s2-rc4-20191025)。可能存在与当前硬件或软件环境的兼容性问题。建议您尝试更新到最新的ESP-IDF版本。 2. **下载速度问题**:您尝试了115200和2000000的波特率,但都出现了乱码。这可能是由于下载速度过快导致的数据错误。尝试使用较低的波特率,例如9600或19200,重新下载程序。 3. **电源问题**:如果模块的电源不稳定或电压不足,可能导致系统无法正常启动。请确保您的电源供应稳定且符合模块的电源要求。 4. **硬件故障**:如果以上方法都无法解决问题,可能是模块本身存在硬件故障。您可以尝试更换另一个模块进行测试。 5. **程序问题**:确保您下载的程序是为ESP32-S2-WROVER模块编写的,并且没有错误。检查程序的配置和初始化代码,确保它们与您的硬件兼容。 6. **串口连接问题**:检查您的串口连接是否正确,确保TX和RX引脚正确连接,且没有接触不良或损坏。 7. **环境干扰**:电磁干扰可能导致通信不稳定。尝试在不同的环境下测试您的模块,以排除环境干扰的可能性。 8. **ESP-IDF配置**:检查您的ESP-IDF配置是否正确,特别是与您的硬件和程序相关的设置。 如果以上方法都无法解决问题,您可能需要联系模块的供应商或寻求专业的技术支持。 |
只有小组成员才能发言,加入小组>>
945 浏览 0 评论
1672 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1330 浏览 1 评论
1233 浏览 1 评论
5021 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1254浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
927浏览 3评论
2338浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2528浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1052浏览 2评论
/9
GMT+8, 2025-12-2 15:45 , Processed in 0.821942 second(s), Total 44, Slave 37 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
579
