电子发烧友论坛|
uint32_t i = 0 ;ESP_LOGI(TAG,"free size (psram):%d",heap_caps_get_free_size(MALLOC_CAP_SPIRAM));uint8_t * tbuf = (uint8_t*)heap_caps_malloc( 32*1024 , MALLOC_CAP_SPIRAM | MALLOC_CAP_32BIT );ESP_LOGI(TAG,"addr[%x]",(uint32_t)tbuf);ESP_LOGI(TAG,"free size (psram):%d",heap_caps_get_free_size(MALLOC_CAP_SPIRAM));for(i=0 ; i < 32*1024 ; i++){ tbuf[i] = 0 ;}show_hex(tbuf,256); PS D:202203ESP32ESP32-S3blink> C:Usershyj.espressifpython_envidf4.4_py3.8_envScriptspython.exe C:Usershyjespesp-idftoolsidf.py -p COM98 monitor Executing action: monitor Running idf_monitor in directory d:202203esp32esp32-s3blink Executing "C:Usershyj.espressifpython_envidf4.4_py3.8_envScriptspython.exe C:Usershyjespesp-idftools/idf_monitor.py -p COM98 -b 115200 --toolchain-prefix xtensa-esp32s3-elf- --target esp32s3 d:202203esp32esp32-s3blinkbuildblink.elf -m 'C:Usershyj.espressifpython_envidf4.4_py3.8_envScriptspython.exe' 'C:Usershyjespesp-idftoolsidf.py' '-p' 'COM98'"... --- WARNING: GDB cannot open serial ports accessed as COMx --- Using \.COM98 instead... --- idf_monitor on \.COM98 115200 --- --- Quit: Ctrl+] | Menu: Ctrl+T | Help: Ctrl+T followed by Ctrl+H --- ESP-ROM:esp32s2-rc4-20191025 Build:Oct 25 2019 rst:0x1 (POWERON),boot:0x8 (SPI_FAST_FLASH_BOOT) SPIWP:0xee mode:DIO, clock div:1 load:0x3ffe6100,len:0x176c load:0x4004c000,len:0xa48 load:0x40050000,len:0x2e48 SHA-256 comparison failed: Calculated: 67ba66aac9d3b0847048c39f9d2dce93a10a30f43a9fce62292c438cecd9d47e Expected: c47b10cf00b4932fac9990c607467c8b94c15be45c18b3dd1fc8b512a5c4126b Attempting to boot anyway... entry 0x4004c204 I (40) boot: ESP-IDF v4.4-dirty 2nd stage bootloader I (40) boot: compile time 10:55:31 I (40) boot: chip revision: 0 I (43) boot.esp32s2: SPI Speed : 80MHz I (47) boot.esp32s2: SPI Mode : DIO I (52) boot.esp32s2: SPI Flash Size : 4MB I (57) boot: Enabling RNG early entropy source... I (62) boot: Partition Table: I (66) boot: ## Label Usage Type ST Offset Length I (73) boot: 0 nvs WiFi data 01 02 00009000 00006000 I (81) boot: 1 phy_init RF data 01 01 0000f000 00001000 I (88) boot: 2 factory factory app 00 00 00010000 00100000 I (95) boot: End of partition table I (100) esp_image: segment 0: paddr=00010020 vaddr=3f000020 size=a0fach (659372) map I (240) esp_image: segment 1: paddr=000b0fd4 vaddr=3ffc4ac0 size=01c98h ( 7320) load I (242) esp_image: segment 2: paddr=000b2c74 vaddr=40028000 size=0cab4h ( 51892) load I (258) esp_image: segment 3: paddr=000bf730 vaddr=50000000 size=00010h ( 16) load I (259) esp_image: segment 4: paddr=000bf748 vaddr=00000000 size=008d0h ( 2256) I (265) esp_image: segment 5: paddr=000c0020 vaddr=40080020 size=19764h (104292) map I (300) boot: Loaded app from partition at offset 0x10000 I (300) boot: Disabling RNG early entropy source... I (311) cache: Instruction cache : size 16KB, 4Ways, cache line size 32Byte I (311) cache: Data cache : size 16KB, 4Ways, cache line size 32Byte I (315) spiram: Found 64MBit SPI RAM device I (320) spiram: SPI RAM mode: sram 40m I (324) spiram: PSRAM initialized, cache is in normal (1-core) mode. I (331) cpu_start: Pro cpu up. I (1977) s�f�ff�����%�SRAM memory test OK I (1986) cpu_start: Pro cpu start user code I (1986) cpu_start: cpu freq: 240000000 I (1986) cpu_start: Application information: I (1989) cpu_start: Project name: sd_card I (1994) cpu_start: App version: 4268a2d-dirty I (2000) cpu_start: Compile time: Mar 17 2022 10:55:19 I (2006) cpu_start: ELF file SHA256: 0c865a360af9db45... I (2012) cpu_start: ESP-IDF: v4.4-dirty I (2018) heap_init: Initializing. RAM available for dynamic allocation: I (2025) heap_init: At 3FF9E000 len 00002000 (8 KiB): RTCRAM I (2031) heap_init: At 3FFC8280 len 00033D80 (207 KiB): DRAM I (2037) heap_init: At 3FFFC000 len 00003A10 (14 KiB): DRAM I (2044) spiram: Adding pool of 8192K of external SPI memory to heap allocator I (2052) spi_flash: detected chip: generic I (2057) spi_flash: flash io: dio I (2061) cpu_start: Starting scheduler on PRO CPU. I (2066) spiram: Reserving pool of 32K of internal memory for DMA/internal allocations I (5219) player: free size (psram):8386191 I (5219) player: addr[3f780974] I (5219) player: free size (psram):8353423 I (5224) led_mem_test: show hex at 3f780974 , len 256 I (5227) led_mem_test: 0000 ff ff ff ff ff ff ff ff ff ff ff ff 00 00 8f ff I (5234) led_mem_test: 0016 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff I (5242) led_mem_test: 0032 ff ff ff ff ff ff ff ff ff ff ff ff 00 00 8f ff I (5250) led_mem_test: 0048 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff I (5258) led_mem_test: 0064 ff ff ff ff ff ff ff ff ff ff ff ff 00 00 8f ff I (5265) led_mem_test: 0080 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff I (5273) led_mem_test: 0096 ff ff ff ff ff ff ff ff ff ff ff ff 00 00 8f ff I (5281) led_mem_test: 0112 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff I (5288) led_mem_test: 0128 ff ff ff ff ff ff ff ff ff ff ff ff 00 00 0f ff I (5296) led_mem_test: 0144 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff I (5304) led_mem_test: 0160 ff ff ff ff ff ff ff ff ff ff ff ff 00 00 8f ff I (5312) led_mem_test: 0176 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff I (5319) led_mem_test: 0192 ff ff ff ff ff ff ff ff ff ff ff ff 00 00 0f ff I (5327) led_mem_test: 0208 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff I (5335) led_mem_test: 0224 ff ff ff ff ff ff ff ff ff ff ff ff 00 00 0f ff I (5343) led_mem_test: 0240 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff |
1个回答
在使用ESP32-S2的外部PSRAM时,如果写入数据后读出的数据与预期不符,可能是由以下原因导致的:
1. **内存分配问题**:确保你使用的内存分配函数正确地分配了PSRAM。你已经使用了`heap_caps_malloc`,这是正确的方法。 2. **内存写入问题**:确保在写入数据时没有越界。你的代码中`tbuf[i] = 0;`是正确的,但请确保在整个过程中没有其他地方写入错误。 3. **内存读取问题**:在读取数据时,请确保你读取的是正确的地址和范围。 4. **PSRAM初始化问题**:确保PSRAM已经被正确初始化。如果PSRAM没有被正确初始化,可能会导致读写错误。 5. **电源问题**:PSRAM的电源不稳定可能导致数据损坏。确保PSRAM的电源稳定。 6. **硬件问题**:如果以上都确认无误,可能存在硬件问题,如PSRAM模块损坏或接触不良。 7. **代码逻辑问题**:检查代码逻辑是否有错误,例如循环条件、数组索引等。 8. **调试和日志**:增加更多的日志输出,以便更好地跟踪问题。例如,在写入和读取数据后立即输出数据,以检查是否有立即的错误。 9. **固件和驱动问题**:确保ESP32-S2的固件和PSRAM驱动是最新的,以避免已知的bug。 10. **测试不同的数据模式**:尝试写入不同的数据模式,以检查问题是否与特定的数据模式有关。 如果以上步骤都不能解决问题,你可能需要进一步的硬件诊断,或者寻求专业的技术支持。 |
只有小组成员才能发言,加入小组>>
945 浏览 0 评论
1672 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1330 浏览 1 评论
1233 浏览 1 评论
5021 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1253浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
927浏览 3评论
2338浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2527浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1052浏览 2评论
/9
GMT+8, 2025-12-2 08:02 , Processed in 0.617725 second(s), Total 42, Slave 35 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
361
