电子发烧友论坛|
首先是生成代码时的报错信息,这个工程是直接使用IHM0003套件的默认配置,没有做任何修改:
日志内容: 2023-05-02 11:02:14,822 DEBUG [Main.lambda$run$0] Arguments: [-ioc, D:STMicroelectronicsMC_SDK_5.4.8UtilitiesPC_SoftwareSTMCWBGCSP_ProjectsIHM0003_kit_testIHM0003_kit_test.ioc, -xdm, D:STMicroelectronicsMC_SDK_5.4.8UtilitiesPC_SoftwareSTMCWBGCSP_ProjectsIHM0003_kit_testIHM0003_kit_test.wb_def]2023-05-02 11:02:14,826 DEBUG [ArgsValue.readPropertiesFile] [AppConfig] pack.source = "D:STMicroelectronicsMC_SDK_5.4.8MiddlewaresSTMotorControl" 2023-05-02 11:02:14,826 DEBUG [ArgsValue.readPropertiesFile] [UserConfig] do not exist in "C:UsersBoZhang.st_motor_controlwb2mx.properties" 2023-05-02 11:02:14,827 DEBUG [ArgsValue.getConfigProperties] pack.source = "../../../../Middlewares/ST/MotorControl"2023-05-02 11:02:14,835 DEBUG [ArgsValue.lambda$retrieve$2] CLI_ARG[xdm]: D:STMicroelectronicsMC_SDK_5.4.8UtilitiesPC_SoftwareSTMCWBGCSP_ProjectsIHM0003_kit_testIHM0003_kit_test.wb_def2023-05-02 11:02:14,836 DEBUG [ArgsValue.lambda$retrieve$2] CLI_ARG[ioc]: D:STMicroelectronicsMC_SDK_5.4.8UtilitiesPC_SoftwareSTMCWBGCSP_ProjectsIHM0003_kit_testIHM0003_kit_test.ioc2023-05-02 11:02:14,837 DEBUG [ArgsValue.retrieve] {xdm=D:STMicroelectronicsMC_SDK_5.4.8UtilitiesPC_SoftwareSTMCWBGCSP_ProjectsIHM0003_kit_testIHM0003_kit_test.wb_def, updftl=templates/wb_ioc_mc-middleware.ftl, mx_timeout=-1, exp=templates/wb-defines_where_and_what.txt, ioc=D:STMicroelectronicsMC_SDK_5.4.8UtilitiesPC_SoftwareSTMCWBGCSP_ProjectsIHM0003_kit_testIHM0003_kit_test.ioc, pack=../../../../Middlewares/ST/MotorControl, ftl=templates/wb_ioc_template.ftl}2023-05-02 11:02:14,920 DEBUG [Main.run] Targeted MCU family = G42023-05-02 11:02:14,949 DEBUG [Main.run] Minimum associated CubeMx to the `G4` targeted MCU family is `5.2.0-a0`2023-05-02 11:02:14,967 DEBUG [WindowsCubeMxFinder.lambda$findThem$2] Found 64-bit subkey HKEY_LOCAL_MACHINE~~~UninstallSTM32CubeMX2023-05-02 11:02:14,976 DEBUG [CubeMxCtx.EXE_version] Loaded path: 'D:STMicroelectronicsSTM32CubeMXSTM32CubeMX.exe'2023-05-02 11:02:14,977 DEBUG [CubeMxCtx.EXE_version] Loaded updater jar: 'D:STMicroelectronicsSTM32CubeMXpluginsupdater.jar'2023-05-02 11:02:14,996 DEBUG [CubeMxCtx.EXE_version] Loaded path: 'D:STMicroelectronicsSTM32CubeMXSTM32CubeMX.exe'2023-05-02 11:02:14,996 DEBUG [CubeMxCtx.EXE_version] Loaded updater jar: 'D:STMicroelectronicsSTM32CubeMXpluginsupdater.jar'2023-05-02 11:02:15,010 DEBUG [CubeMxCtx.EXE_version] Loaded path: 'D:STMicroelectronicsSTM32CubeMXSTM32CubeMX.exe'2023-05-02 11:02:15,010 DEBUG [CubeMxCtx.EXE_version] Loaded updater jar: 'D:STMicroelectronicsSTM32CubeMXpluginsupdater.jar'2023-05-02 11:02:18,289 DEBUG [CubeMxCtx.EXE_version] Loaded path: 'D:STMicroelectronicsSTM32CubeMXSTM32CubeMX.exe'2023-05-02 11:02:18,289 DEBUG [CubeMxCtx.EXE_version] Loaded updater jar: 'D:STMicroelectronicsSTM32CubeMXpluginsupdater.jar'2023-05-02 11:02:18,327 DEBUG [EnvironmentChecker.checkPack] STM32CubeMX.Version: 6.8.0-RC42023-05-02 11:02:21,275 ERROR [LineInfo_to_exitCode.manage_MCPackNotFound] MotorControl reference pack not found: "../../../../Middlewares/ST/MotorControl"软件安装路径: 工程路径: 是要在CubeMX里面单独安装MCSDK才能识别吗,这个相对路径的参考路径是.stmcx文件所在路径吗,或者库的路径能不能手动配置成绝对路径,感谢解答! |
1个回答
1. 检查配置文件:确保您的IHM0003kit配置文件(.ioc文件)和工作区定义文件(.wb_def文件)没有损坏或丢失。如果可能,请尝试重新下载或生成这些文件。 2. 检查路径:确保您提供的路径(例如:D:STMicroelectronicsMC_SDK_5.4.8UtilitiesPC_SoftwareSTMCWBGCSP_ProjectsIHM0003_kit_testIHM0003_kit_test.ioc)是正确的,并且文件确实存在于这些路径中。 3. 检查MCworkbench版本:确保您使用的MCworkbench版本与IHM0003kit套件兼容。如果不兼容,请尝试升级或降级MCworkbench。 4. 检查日志文件:仔细检查MCworkbench生成的日志文件,查找与错误相关的详细信息。这可能会帮助您确定问题的根本原因。 5. 检查代码生成设置:确保您在MCworkbench中正确设置了代码生成选项。例如,确保选择了正确的编译器、优化级别等。 6. 检查硬件连接:确保您的IHM0003kit硬件连接正确,并且与MCworkbench正确通信。 |
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
4140 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
3228 浏览 1 评论
2753 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
2181 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
14984 浏览 2 评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
3088浏览 4评论
stm32f4下spi+dma读取数据不对是什么原因导致的?
1897浏览 3评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
2067浏览 3评论
1980浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
2169浏览 3评论
/9
GMT+8, 2025-12-2 15:46 , Processed in 0.737028 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
751
