本示例通过输入电话,进行电话拨打,及电话相关信息的显示。
网络通信
本示例使用call相关接口实现了拨打电话并显示电话相关信息的功能
使用说明
1.输入电话号码后,点击电话按钮,进行拨打电话。
2.拨打电话后文本框会显示拨打是否成功,是否存在通话,通话状态,是否紧急号码,格式化后的电话号码。
entry/src/main/ets/
|---common
| |---CallView.ets // 电话API
|---entryability
| |---EntryAbility.ts
|---model
| |---Logger.ts // 日志工具
|---pages
| |---Index.ets // 首页
* Copyright (c) 2022-2023 Huawei Device Co., Ltd.
* Licensed under the Apache License, Version 2.0 (the "License");
* you may not use this file except in compliance with the License.
* You may obtain a copy of the License at
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software
* distributed under the License is distributed on an "AS IS" BASIS,
* WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
* See the License for the specific language governing permissions and
* limitations under the License.
import Logger from '../model/Logger'
import call from '@ohos.telephony.call'
const TAG: string = `[CallView]`
@Component
export struct CallView {
private on: Resource = $r('app.media.call_on')
private off: Resource = $r('app.media.call_off')
@State src: Resource = this.off
@Link input: string
@Link output: string
build() {
Column() {
Image(this.src)
.id('callImg')
.width(70)
.height(70)
.onClick(() => {
if (this.src == this.on) {
this.src = this.off
} else {
this.output = ''
this.src = this.on
call.dialCall(this.input, (err, data) => {
this.output = this.output + `dial: ${JSON.stringify(data)}` + '\\n'
Logger.info(`${TAG}, callback: dial err->${JSON.stringify(err)} data->${JSON.stringify(data)}`)
call.hasCall((err, data) => {
this.output = this.output + `hasCall: ${JSON.stringify(data)}` + '\\n'
Logger.info(`${TAG}, callback: hasCall err->${JSON.stringify(err)} data->${JSON.stringify(data)}`)
call.getCallState((err, data) => {
this.output = this.output + `getCallState: ${JSON.stringify(data)}` + '\\n'
Logger.info(`${TAG}, callback: getCallState err->${JSON.stringify(err)} data->${JSON.stringify(data)}`)
call.isEmergencyPhoneNumber(this.input, (err, data) => {
this.output = this.output + `isEmergencyPhoneNumber: ${JSON.stringify(data)}` + '\\n'
Logger.info(`${TAG}, callback: isEmergencyPhoneNumber err->${JSON.stringify(err)} data->${JSON.stringify(data)}`)
call.formatPhoneNumber(this.input, (err, data) => {
this.output = this.output + `formatPhoneNumber: ${JSON.stringify(data)}` + '\\n'
Logger.info(`${TAG}, callback: formatPhoneNumber err->${JSON.stringify(err)} data->${JSON.stringify(data)}`)
call.formatPhoneNumberToE164(this.input, "CN", (err, data) => {
this.output = this.output + `formatPhoneNumberToE164: ${JSON.stringify(data)}` + '\\n'
Logger.info(`${TAG}, callback: formatPhoneNumberToE164 err->${JSON.stringify(err)} data->${JSON.stringify(data)}`)
.onFinish(() => {
this.src = this.off
