# include
#pragma config FOSC = INTRCIO // Oscillator Selection bits (INTOSC oscillator: I/O function on RA4/OSC2/CLKOUT pin, I/O function on RA5/OSC1/CLKIN)INTOSC 振荡器, RA4、RA5为IO口 #pragma config WDTE = OFF // Watchdog Timer Enable bit (WDT enabled)看门狗开 #pragma config PWRTE = ON // Power-up Timer Enable bit (PWRT enabled)上电复位开 #pragma config MCLRE = OFF // RA3/MCLR pin function select (RA3/MCLR pin function is digital I/O, MCLR internally tied to VDD)RA3/MCLR引脚功能为MCLR #pragma config BOREN = OFF // Brown-out Detect Enable bit (BOD enabled)欠压检测功能关 #pragma config CP = OFF // Code Protection bit (Program Memory code protection is disabled)程序存储器代码保护被禁用 #pragma config CPD = OFF // Data Code Protection bit (Data memory code protection is disabled)数据代码保护关 //__ CONFIG(0X31A4); __EEPROM_DATA(5,50,67,6,5,0,0,0); //0X00第一位表示定时倍数;0X01第二位表示最低电压-低;0X02第三位表示最高电压-高;0X03第四位表示清虫天数记录;0X04第五位表示清虫天数预设;0X05第五位表示为0铅酸电池(最低不能低于2点几V)、为1锂电池(最高不能超过12.6V);0X06空;0X07空 #define uchar unsigned char #define uint unsigned int /*#define EEPROM_ADDRESS 0x10 // 定义EEPROM地址 // 定义EEPROM中存储的数据 const unsigned char myEEPROMData[] __at(EEPROM_ADDRESS) = { 0x00, 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07 }; __EEPROM_DATA(5,50,67,6,5,0,0,0);*/ uint AN2_val; //存放AN2通道模拟转换的值 uint AN4_val; //存放AN4通道模拟转换的值 uchar i = 0; uchar j = 0; uint yanshi; uchar AN2_num1; uchar AN2_num2; uchar AN2_num3; uchar AN4_num1; uchar AN4_num2; uchar AN4_num3; uchar AN4_num4; uchar yukon_num1; uchar yukon_num2; uint anjian_num1; uchar anjian_num2; uchar n; uint num; uchar daochon_num; uchar h; uchar day; //0为白天,1为晚上 uchar fuzhai=1; //负载开启 uchar chondian; //0为充电完成,1为充电未完成,继续充电 uchar taiyangban; //1为太阳板电压高于电池,0为太阳板电压低于电池 uchar ONOFF=1; //放电到充电一循环,1开启,0关闭 uchar qcts; uchar k; uchar a=6; uchar t; uchar z=0; uchar m; void init1() { TRISA = 0b00110100; //设置RA输入输出端口 RA2,RA4,RA5(AN2、AN3)为输入,其他输出 TRISC = 0b00010011; //设置RC输入输出端口 RC0、RC1、RC4(AN4、AN5)为输入,其他输出 PORTA = 0b00000000; //设置A端口输出为低电平 PORTC = 0b00000000; //设置C端口输出为低电平 ANSEL = 0X14; //ANS4=1,ANS2=1;AN4和AN2为模拟输入 二进制00010100 /* CM2 = 1; //CM2:CM0:111 比较器模式位(关闭) CM1 = 1; CM0 = 1;*/ //ADCON1 = 0X10; //ADCS<2:0>:A/D 转换时钟源选择位 0011 =FOSC/8 4MHz频率 二进制00010000 ADCON1=0b01010000; //AD,RC0(AN4)定义为AD口(A/D 转换时钟选择位) } void ADAN2() //对RA2(AN2)进行A/D模拟转换输入 { ADCON0 = 0X09; //二进制0000 1001 (bit7:0 左对齐,bit6:0 参考电压VDD, bit5:0 未用, bit4-bit2:010 通道02(AN2), bit1:0 A/D转换结束/未进行, bit0:(ADON)1 A/D转换模块正在工作) A/D 控制寄存器 for (i=0; i<16; i++) { asm("NOP"); //稍微延时 asm("NOP"); asm("NOP"); asm("NOP"); GO_DONE = 1; //1 = A/D 转换正在进行。该位置 1 将启动 A/D 转换。 在转换结束后该位将被硬件自动清零。 ADCON0 _ A/D 控制寄存器 while (GO_DONE) //循环检测GO_DONE是否为0,为0转换结束 { continue; } AN2_val + = ADRESH; //将左对齐后的20次结果赋值 } ADON = 0; //A/D转换模块结束 AN2_val = AN2_val/16; //取20次检测电压的平均值 if (AN2_val < eeprom_read(0X01)) //读写寄存器__EEPROM_DATA(5,50,67,6,5,0,0,0)中第二位,电源电压为10.8v时,电路分压后测出AN2电压为:0.98v (5v是参考电压,一个数值代表多少电压:5/1024=0.00448,如果输入电压为0.98v,0.98/0.00448=218.75) { AN2_num1++; if(AN2_num1 > 16) //(超过20次电压低于10.8v) { AN2_num1 = 0; //计数清0 fuzhai = 0; //负载未开启工作 } } else { AN2_num1 = 0; //清0 } if (AN2_val > eeprom_read(0X02)) //读写寄存器__EEPROM_DATA(5,50,67,6,5,0,0,0)中第三位,电源电压为14.4v时,电路分压后测出AN2电压为:1.31v (如果输入电压为1.31v,1.31/0.00448=292.41) { AN2_num2++; if(AN2_num2++ > 16) //(超过20次电压高于14.4v) { AN2_num2 = 0; //计数清0 chondian = 0; //充电完成 } } else { AN2_num3++; //计数自增 if (AN2_num3 > 16) //(超过20次电压低于14.4v) { AN2_num3 = 0; //计数清0 chondian = 1; //充电未完成,继续充电 } } } void ADAN4() //对RC0(AN4)进行A/D模拟转换输入 { ADCON0 = 0X11; //二进制0000 1001 (bit7:0 左对齐,bit6:0 参考电压VDD, bit5:0 未用, bit4-bit2:100 通道04(AN4), bit1:0 A/D转换结束/未进行, bit0:(ADON)1 A/D转换模块正在工作) A/D 控制寄存器 for (j=0; j<16; j++) { asm("NOP"); //稍微延时 asm("NOP"); asm("NOP"); asm("NOP"); GO_DONE = 1; //1 = A/D 转换正在进行。该位置 1 将启动 A/D 转换。 在转换结束后该位将被硬件自动清零。 ADCON0 _ A/D 控制寄存器 while (GO_DONE) //循环检测GO_DONE是否为0,为0转换结束 { continue; } AN4_val + = ADRESH; //将左对齐后的20次结果赋值 } AN4_val = AN4_val/16; //取20次检测电压的平均值 ADON = 0; //A/D转换模块结束 if(AN2_val - AN4_val < 13) //连续检测20次太阳板比铅酸电池或锂电池低于3V (晚上) { AN4_num1++; if (AN4_num1 > 24) //(超过20次太阳板电压比电源电压低于3v) { AN4_num1 = 0; //计数清0 day = 1; //晚上 } } else { AN4_num1 = 0; } if (AN2_val - AN4_val > 23) //连续检测20次太阳板高于5.5V的铅酸电池或锂电池 (白天) { AN4_num2++; if (AN4_num2 > 24) //(超过20次太阳板电压比电源电压高于5.5v) { AN4_num2 = 0; day = 0; //白天 } } else { AN4_num2 = 0; } if (AN4_val < 0b00000011) //连续检测20次太阳板电压高于电池电压,开始充电,连续检测20次太阳板电压低于电池电压,不充电 { AN4_num3++; if (AN4_num3 > 16) //连续检测20次太阳板电压高于电池电压 { AN4_num3 = 0; //计数清零 taiyangban = 1; //1为太阳板电压高于电池 fuzhai = 1; //负载工作开启 ONOFF=1; //放电到充电一循环,开启 } } else { AN4_num4++; if (AN4_num4 > 16) //连续检测20次太阳板电压低于电池电压 { AN4_num4 = 0; //计数清零 taiyangban = 0; //0为太阳板电压低于电池 } } } void kaijishansuo() //开机闪烁5次 { if (yanshi > 800) //1s溢出(3906) { yanshi = 0; if (z == 0) z = 1; else z = 0; a--; } } void condianshansuo() //充电连续闪烁 { if (yanshi > 1500) //1s溢出 { yanshi = 0; if (z == 0) z = 1; else z = 0; } } void panduan () //转换后的数据判断,定义是否需要开灯、充电、雨控等待 { if (fuzhai == 1) //负载开启 { if (day == 1) //晚上 { if (ONOFF == 1) //放电到充电一循环,开启 { TMR1ON=1; //中断TMR1开启,开始计时 if (RC1 == 0) //雨控控制,0为雨控检测无雨,短接帽断路 { yukon_num1++; if (yukon_num1 > 16) //检测超过20次没有雨 { yukon_num1 = 0; //计数清0 RC2 = 1; //没有雨水,继电器启动 } } else //雨控控制,0为雨控检测有雨,短接帽连通,将5v电压拉到RC1引脚 { yukon_num2++; if (yukon_num2 > 16) //检测超过20次有雨 { yukon_num2 = 0; //计数清0 RC2 = 0; //下雨,继电器关闭 } } } else { RC2 = 0; //未实现放电到充电的循环,继电器关闭,负载未启动 } } else { RC2 = 0; //白天继电器关闭,负载未启动 } } else { RC2 = 0; //继电器关闭,负载未启动 } if (chondian == 1) //1为充电未完成,继续充电 { if (taiyangban == 1) //1为太阳板电压高于电池 { RC1 = 1; //RC3高电平,电源模块充电,太阳板给电池充电 if (num > 0) num = 0; //定时清0 if (h > 0) h = 0; condianshansuo(); ////充电蓝灯闪烁 } else { RC3 = 0; //充电完成,RC3低电平,电源模块不充电 if (a < 1) //蓝灯不闪烁 z = 0; //RA0=0 } } else { RC3 = 0; //充电完成,RC3低电平,电源模块不充电 if (a < 1) //蓝灯不闪烁 z = 0; //RA0=0 } } void anxia() { anjian_num1++; if (anjian_num1 > 4000) { anjian_num1 = 0; anjian_num2++; //增加一小时(定时数据) a = 2; //蓝灯闪烁一次 k = 1; //有未写入数据 } } void sonkai() { if(k == 1) { eeprom_write(0x04,anjian_num2); //把anjian_num2写到地址0x04 qcts = anjian_num2; //清除定时时间 k = 0; //没有未写入数据 anjian_num1 = 0; anjian_num2 = 0; //清除定时数据 } if(t == 1) //开始读定时时间 { if (a < 1) //蓝灯不闪烁的时候 { if (anjian_num2 > 0) //定时时间大于0 { anjian_num1++; if (anjian_num1 > 4000) //延时7200 { if (anjian_num1%2000 == 0) //延时时间/2000=0 { anjian_num2--; //减去一次已显示的 a = 2; //蓝灯闪烁一次 } } } else { t = 0; //读定时时间控制位清除 anjian_num1; //延时清零 } } } else { if ( anjian_num1>200 ) //短按10s-20s之间,可以开始读定时间t=1 { if (anjian_num1<1000) { a = 6; //开始读蓝灯闪烁5次 t = 1; //开始读定时时间 anjian_num2 = eeprom_read(0x04); //从内存读取定时数据 } } anjian_num1 = 0; //延时清零 } } void shezhi() //设置定时时间 { if (RC4 == 0) //按键按下 anxia(); else //按键松开 sonkai(); } void dianchi() //每次开机判断所使用的电池,和读入定时时间 { if (RA4 == 0 ) ////RA4口为低时是用蓄电池 { if (eeprom_read(0x05)==1) //如果RA4口为蓄电池,控制位为1时,就写入蓄电池的数据 { eeprom_write(0x01,50); //最低电压 eeprom_write(0x02,67); //最高电压 eeprom_write(0x05,0); //标记为蓄电池 ???? } } else //RA4口为高时是用锂电池 { if (eeprom_read(0x05)==0) //如果RA4口为锂电池,控制位为0时,就写入锂电池的数据 { eeprom_write(0x01,43); //最低电压(41) eeprom_write(0x02,58); //最高电压 eeprom_write(0x05,1); //标记为锂电池 ??? } } qcts = eeprom_read(0x04); //(预计清·虫天数为5天一次) if(eeprom_read(0x03) <= qcts) //(判断清除天数几天一次) eeprom_write(0x03,6); //(将清虫天数记录设为6天一次) } void init2 () { T0CS = 0; //Timer0使用内部时钟 OPTION_REG _ 选择寄存器 PSA=1; //将预分频器给看门狗WDT OPTION_REG _ 选择寄存器 TMR0=0x00; //定时器 T0IF=1; //Timer0 启动控制位使能(0关闭)(标志位) INTCON _ 中断控制寄存器 T0IE=1; //Timer0中断开启(使能位) INTCON _ 中断控制寄存器 TMR1CS = 0; //Timer1使用内部时钟 Timer1 控制寄存器 T1CKPS0=1; //1:8倍预分频比 Timer1 控制寄存器 T1CKPS1:T1CKPS0:11=1:8倍预分频比 T1CKPS1=1; //1:8倍预分频比 Timer1 控制寄存器 //TMR1H=(65536-(500000/8))/256; //初始化TMR1的高八位初始值 0.5s中断溢出一次 //TMR1L=(65536-(500000/8))%256; //初始化TMR1的低八位初始值 TMR1H=0x0B; //高八位置初始值 TMR1L=0xE9; //低八位置初始值 TMR1ON=0; //Timer1 启动控制位使能(0关闭) Timer1 控制寄存器 TMR1IF=0; //中断标志位清零 外设中断标志寄存器 1 TMR1IE=1; //Timer1中断开启 外设中断使能寄存器 1 PEIE=1; //外部中断开启 INTCON ? 中断控制寄存器 GIE=1; //全局中断开启 INTCON ? 中断控制寄存器 } void dc() //倒虫 { if (RC5 == 0) RC5 = 1; if (RC5 == 1 && RA5 == 0) m = 1; //(步骤控制) if (RC5 == 1 && RA5 == 1 && m == 1) { daochon_num++; //倒虫天数增加 m = 0; } if (daochon_num >= 2) //超过两天清一次虫 { daochon_num = 0; //清0 RC5 = 0; eeprom_write(0x03,0); } } void interrupt time0() { if (TMR1IF == 1) { TMR1IF=0; //中断标志溢出清0 //TMR1H=(65536-(500000/8))/256; //初始化TMR1的高八位初始值 //TMR1L=(65536-(500000/8))%256; //初始化TMR1的低八位初始值 TMR1H=0x0B; //高八位置初始值 TMR1L=0xE9; //低八位置初始值 num++; if (num == 139) //定时计时1一个小时溢出 { h++; //每小时自增 num = 0; //溢出清0 if (h == 1) { eeprom_write(0x03,eeprom_read(0x03)+1); //清虫天数计数+1天 } if (h == 5) //等于设定的小时 { h = 0; //小时清零 RC2 = 0; //继电器/负载关闭 ONOFF=0; //放电到充电一循环,时间到置0,关闭 TMR1ON=0; //Timer1 启动控制位使能(0关闭) } } } if (T0IF == 1) //1 = TMR0 寄存器溢出 (必须在软件中清除) 0 = TMR0 寄存器没有溢出 { T0IF = 0; //tmr0溢出清零 yanshi++; TMR0=0x00; n++; if (n > 250) //1s/256us=3906.25,1秒溢出 { n = 0; //溢出清0 ADAN2(); //读AD转化口RA2/AN2 ADAN4(); //读AD转化口RC0/AN4 panduan (); //转换后的数据判断,定义是否需要开灯、充电、雨控等待 if (eeprom_read(0x03)>=qcts && TMR1ON==1) //读清虫设定天数2天的时候 ????? dc(); //倒虫 } if (a > 0) kaijishansuo(); //开机蓝灯闪烁5次 if (z == 1) RA0 = 1; //蓝灯闪烁 else RA0 = 0; shezhi(); //设置定时时间 } } void main () { init1(); //通道初始化 init2 (); //定时器初始化 dianchi(); //电池选择 dc(); //倒虫 while (1) //死循环 { } } ----------------------------------------------------------- 报错显示::: warning: (1273) Omniscient Code Generation not available in Free mode miewendeng.c:479: warning: (752) conversion to shorter data type D:\XC8\sources\pic\eeread.c:12: error: (1360) no space for auto/param eeprom_write@addr (908) exit status = 1 nbproject/Makefile-default.mk:131: recipe for target 'dist/default/production/miewendeng.X.production.hex' failed make[2]: Leaving directory 'D:/MPLAB X IDE v4.05��Ŀ/miewendeng.X' nbproject/Makefile-default.mk:90: recipe for target '.build-conf' failed make[1]: Leaving directory 'D:/MPLAB X IDE v4.05��Ŀ/miewendeng.X' nbproject/Makefile-impl.mk:39: recipe for target '.build-impl' failed make[2]: *** [dist/default/production/miewendeng.X.production.hex] Error 1 make[1]: *** [.build-conf] Error 2 make: *** [.build-impl] Error 2 编译已失败 (退出值2, 总时间: 1s) ---------------------------------------- 警告:adcshili.c:418: warning: (752) conversion to shorter data type这个警告表示在第418行进行了将数据类型转换为较短的数据类型的操作。 错误:D:\XC8\sources\common\lwdiv.c:31: error: (1358) no space for _eeprom_read temps (1)这个错误表示编译器无法为_eeprom_read temps分配足够的空间。 eeprom_write(0x03,eeprom_read(0x03)+1); //清虫天数计数+1天 418行 请问大佬这个代码该怎么改啊,刚刚入行的小白琢磨了好几天还是一头雾水。 |
相关推荐 |
你正在撰写讨论
如果你是对讨论或其他讨论精选点评或询问,请使用“评论”功能。
【瑞萨RA6E2】瑞萨E2S软件安装过程,等待过程玩下97_e2 studio_ZGZZ
140 浏览 0 评论
483 浏览 0 评论
【原创】【RA4M2-SENSOR开发板评测】低功耗+USB综合测试
815 浏览 0 评论
1346 浏览 2 评论
804 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
16903 浏览 31 评论
/9
GMT+8, 2025-12-2 16:05 , Processed in 0.750731 second(s), Total 34, Slave 26 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
429
