@ohos.app.ability.UIAbility (UIAbility)
Caller
通用组件Caller通信客户端调用接口, 用来向通用组件服务端发送约定数据。
Caller.call
call(method: string, data: rpc.Parcelable): Promise;
向通用组件服务端发送约定序列化数据。
系统能力:SystemCapability.Ability.AbilityRuntime.AbilityCore
示例:
class MyMessageAble{ // 自定义的Parcelable数据结构
str:''
num: 1
constructor(name, str) {
this.name = name;
this.str = str;
marshalling(messageSequence) {
messageSequence.writeInt(this.num);
messageSequence.writeString(this.str);
console.log('MyMessageAble marshalling num[' + this.num + '] str[' + this.str + ']');
return true;
unmarshalling(messageSequence) {
this.num = messageSequence.readInt();
this.str = messageSequence.readString();
console.log('MyMessageAble unmarshalling num[' + this.num + '] str[' + this.str + ']');
return true;
let method = 'call_Function'; // 约定的通知消息字符串
let caller;
export default class MainAbility extends Ability {
onWindowStageCreate(windowStage) {
this.context.startAbilityByCall({
bundleName: 'com.example.myservice',
abilityName: 'MainAbility',
deviceId: ''
}).then((obj) => {
caller = obj;
let msg = new MyMessageAble('msg', 'world'); // 参考Parcelable数据定义
caller.call(method, msg)
.then(() => {
console.log('Caller call() called');
.catch((callErr) => {
console.log('Caller.call catch error, error.code: ' + JSON.stringify(callErr.code) +
' error.message: ' + JSON.stringify(callErr.message));
}).catch((err) => {
console.log('Caller GetCaller error, error.code: ' + JSON.stringify(err.code) +
' error.message: ' + JSON.stringify(err.message));
Caller.callWithResult
callWithResult(method: string, data: rpc.Parcelable): Promise<rpc.MessageSequence>;
向通用组件服务端发送约定序列化数据, 并将服务端返回的约定序列化数据带回。
示例:
str:''
num: 1
this.name = name;
this.str = str;
return true;
return true;
let caller;
deviceId: ''
}).then((obj) => {
caller = obj;
let msg = new MyMessageAble(1, 'world');
caller.callWithResult(method, msg)
.then((data) => {
console.log('Caller callWithResult() called');
let retmsg = new MyMessageAble(0, '');
data.readParcelable(retmsg);
console.log('Caller.callWithResult catch error, error.code: ' + JSON.stringify(callErr.code) +
}).catch((err) => {
Caller.release
release(): void;
主动释放通用组件服务端的通信接口。
系统能力:SystemCapability.UIAbility.UIAbilityRuntime.UIAbilityCore
错误码:
示例
let caller;
deviceId: ''
}).then((obj) => {
caller = obj;
try {
caller.release();
} catch (releaseErr) {
console.log('Caller.release catch error, error.code: ' + JSON.stringify(releaseErr.code) +
' error.message: ' + JSON.stringify(releaseErr.message));
}).catch((err) => {
复制
Caller.onRelease
onRelease(callback: OnReleaseCallback): void;
注册通用组件服务端Stub(桩)断开监听通知。
示例;
let caller;
deviceId: ''
}).then((obj) => {
caller = obj;
try {
caller.onRelease((str) => {
console.log(' Caller OnRelease CallBack is called ' + str);
} catch (error) {
console.log('Caller.onRelease catch error, error.code: ' + JSON.stringify(error.code) +
' error.message: ' + JSON.stringify(error.message));
}).catch((err) => {
Caller.on
on(type: ‘release’, callback: OnReleaseCallback): void;
示例:
let caller;
deviceId: ''
}).then((obj) => {
caller = obj;
try {
caller.on('release', (str) => {
} catch (error) {
console.log('Caller.on catch error, error.code: ' + JSON.stringify(error.code) +
}).catch((err) => {
复制
Caller.off
off(type: ‘release’, callback: OnReleaseCallback): void;
取消注册通用组件服务端Stub(桩)断开监听通知。预留能力,当前暂未支持。
示例:
let caller;
export default class MainUIAbility extends Ability {
abilityName: 'MainUIAbility',
deviceId: ''
}).then((obj) => {
caller = obj;
try {
let onReleaseCallBack = (str) => {
caller.on('release', onReleaseCallBack);
caller.off('release', onReleaseCallBack);
} catch (error) {
console.log('Caller.on or Caller.off catch error, error.code: ' + JSON.stringify(error.code) +
}).catch((err) => {
复制
Caller.off
off(type: ‘release’): void;
示例:
let caller;
deviceId: ''
}).then((obj) => {
caller = obj;
try {
caller.off('release');
} catch (error) {
console.error('Caller.on or Caller.off catch error, error.code: ' + JSON.stringify(error.code) +
}).catch((err) => {
console.error('Caller GetCaller error, error.code: ' + JSON.stringify(err.code) +
复制
Callee
通用组件服务端注册和解除客户端caller通知送信的callback接口。
Callee.on
on(method: string, callback: CalleeCallback): void;
通用组件服务端注册消息通知callback。
示例:
str:''
num: 1
this.name = name;
this.str = str;
return true;
return true;
function funcCallBack(pdata) {
console.log('Callee funcCallBack is called ' + pdata);
let msg = new MyMessageAble('test', '');
pdata.readParcelable(msg);
return new MyMessageAble('test1', 'Callee test');
onCreate(want, launchParam) {
console.log('Callee onCreate is called');
try {
this.callee.on(method, funcCallBack);
} catch (error) {
console.log('Callee.on catch error, error.code: ' + JSON.stringify(error.code) +
复制
Callee.off
off(method: string): void;
解除通用组件服务端注册消息通知callback。
示例:
try {
this.callee.off(method);
} catch (error) {
console.log('Callee.off catch error, error.code: ' + JSON.stringify(error.code) +
OnReleaseCallback
(msg: string): void;
本文根据HarmonyOS官方开发文档整理
