1、程序介绍本程序是基于OpenHarmony标准系统编写的平台驱动案例:UART
详细资料请参考官网:
2、基础知识2.1、UART简介UART指异步收发传输器(Universal Asynchronous Receiver/Transmitter),是通用串行数据总线,用于异步通信。该总线双向通信,可以实现全双工传输。
两个UART设备的连接示意图如下,UART与其他模块一般用2线(图1)或4线(图2)相连,它们分别是:
图1 UART的2线相连
图2 UART的4线相连
UART通信之前,收发双方需要约定好一些参数:波特率、数据格式(起始位、数据位、校验位、停止位)等。通信过程中,UART通过TX发送给对端数据,通过RX接收对端发送的数据。当UART接收缓存达到预定的门限值时,RTS变为不可发送数据,对端的CTS检测到不可发送数据,则停止发送数据。
2.2、UART驱动开发2.2.1、UART驱动开发接口为了保证上层在调用UART接口时能够正确的操作UART控制器,核心层在//drivers/hdf_core/framework/support/platform/include/uart/uart_core.h中定义了以下钩子函数,驱动适配者需要在适配层实现这些函数的具体功能,并与钩子函数挂接,从而完成适配层与核心层的交互。
UartHostMethod定义:
- <span><span class="cm-keyword">struct</span> <span class="cm-def">UartHostMethod</span> {</span>
- <span> <span class="cm-variable-3">int32_t</span> (<span class="cm-operator">*</span><span class="cm-variable">Init</span>)(<span class="cm-keyword">struct</span> <span class="cm-def">UartHost</span> <span class="cm-operator">*</span><span class="cm-variable">host</span>);</span>
- <span> <span class="cm-variable-3">int32_t</span> (<span class="cm-operator">*</span><span class="cm-variable">Deinit</span>)(<span class="cm-keyword">struct</span> <span class="cm-def">UartHost</span> <span class="cm-operator">*</span><span class="cm-variable">host</span>);</span>
- <span> <span class="cm-variable-3">int32_t</span> (<span class="cm-operator">*</span><span class="cm-variable">Read</span>)(<span class="cm-keyword">struct</span> <span class="cm-def">UartHost</span> <span class="cm-operator">*</span><span class="cm-variable">host</span>, <span class="cm-variable-3">uint8_t</span> <span class="cm-variable-3">*</span><span class="cm-variable">data</span>, <span class="cm-variable-3">uint32_t</span> <span class="cm-variable">size</span>);</span>
- <span> <span class="cm-variable-3">int32_t</span> (<span class="cm-operator">*</span><span class="cm-variable">Write</span>)(<span class="cm-keyword">struct</span> <span class="cm-def">UartHost</span> <span class="cm-operator">*</span><span class="cm-variable">host</span>, <span class="cm-variable-3">uint8_t</span> <span class="cm-variable-3">*</span><span class="cm-variable">data</span>, <span class="cm-variable-3">uint32_t</span> <span class="cm-variable">size</span>);</span>
- <span> <span class="cm-variable-3">int32_t</span> (<span class="cm-operator">*</span><span class="cm-variable">GetBaud</span>)(<span class="cm-keyword">struct</span> <span class="cm-def">UartHost</span> <span class="cm-operator">*</span><span class="cm-variable">host</span>, <span class="cm-variable-3">uint32_t</span> <span class="cm-variable-3">*</span><span class="cm-variable">baudRate</span>);</span>
- <span> <span class="cm-variable-3">int32_t</span> (<span class="cm-operator">*</span><span class="cm-variable">SetBaud</span>)(<span class="cm-keyword">struct</span> <span class="cm-def">UartHost</span> <span class="cm-operator">*</span><span class="cm-variable">host</span>, <span class="cm-variable-3">uint32_t</span> <span class="cm-variable">baudRate</span>);</span>
- <span> <span class="cm-variable-3">int32_t</span> (<span class="cm-operator">*</span><span class="cm-variable">GetAttribute</span>)(<span class="cm-keyword">struct</span> <span class="cm-def">UartHost</span> <span class="cm-operator">*</span><span class="cm-variable">host</span>, <span class="cm-keyword">struct</span> <span class="cm-def">UartAttribute</span> <span class="cm-operator">*</span><span class="cm-variable">attribute</span>);</span>
- <span> <span class="cm-variable-3">int32_t</span> (<span class="cm-operator">*</span><span class="cm-variable">SetAttribute</span>)(<span class="cm-keyword">struct</span> <span class="cm-def">UartHost</span> <span class="cm-operator">*</span><span class="cm-variable">host</span>, <span class="cm-keyword">struct</span> <span class="cm-def">UartAttribute</span> <span class="cm-operator">*</span><span class="cm-variable">attribute</span>);</span>
- <span> <span class="cm-variable-3">int32_t</span> (<span class="cm-operator">*</span><span class="cm-variable">SetTransMode</span>)(<span class="cm-keyword">struct</span> <span class="cm-def">UartHost</span> <span class="cm-operator">*</span><span class="cm-variable">host</span>, <span class="cm-keyword">enum</span> <span class="cm-variable">UartTransMode</span> <span class="cm-variable">mode</span>);</span>
- <span> <span class="cm-variable-3">int32_t</span> (<span class="cm-operator">*</span><span class="cm-variable">pollEvent</span>)(<span class="cm-keyword">struct</span> <span class="cm-def">UartHost</span> <span class="cm-operator">*</span><span class="cm-variable">host</span>, <span class="cm-variable-3">void</span> <span class="cm-variable-3">*</span><span class="cm-variable">filep</span>, <span class="cm-variable-3">void</span> <span class="cm-variable-3">*</span><span class="cm-variable">table</span>);</span>
- <span>};</span>
复制代码UartHostMethod结构体成员的回调函数功能说明:
2.2.2、UART驱动开发步骤UART模块适配HDF框架包含以下四个步骤:
实例化驱动入口。
配置属性文件。
实例化UART控制器对象。
驱动调试。
我们以///drivers/hdf_core/adapter/khdf/linux/platform/uart/uart_adapter.c为例(该UART驱动是建立于Linux UART子系统基础上创建)。
2.2.2.1、驱动实例化驱动入口驱动入口必须为HdfDriverEntry(在hdf_device_desc.h中定义)类型的全局变量,且moduleName要和device_info.hcs中保持一致。HDF框架会将所有加载的驱动的HdfDriverEntry对象首地址汇总,形成一个类似数组的段地址空间,方便上层调用。 一般在加载驱动时HDF会先调用Bind函数,再调用Init函数加载该驱动。当Init调用异常时,HDF框架会调用Release释放驱动资源并退出。
UART驱动入口开发参考:
- <span><span class="cm-keyword">struct</span> <span class="cm-def">HdfDriverEntry</span> <span class="cm-def">g_hdfUartchdog</span> <span class="cm-operator">=</span> {</span>
- <span> .<span class="cm-variable">moduleVersion</span> <span class="cm-operator">=</span> <span class="cm-number">1</span>,</span>
- <span> .<span class="cm-variable">moduleName</span> <span class="cm-operator">=</span> <span class="cm-string">"HDF_PLATFORM_UART"</span>,</span>
- <span> .<span class="cm-variable">Bind</span> <span class="cm-operator">=</span> <span class="cm-variable">HdfUartBind</span>,</span>
- <span> .<span class="cm-variable">Init</span> <span class="cm-operator">=</span> <span class="cm-variable">HdfUartInit</span>,</span>
- <span> .<span class="cm-variable">Release</span> <span class="cm-operator">=</span> <span class="cm-variable">HdfUartRelease</span>,</span>
- <span>};</span>
- <span><span></span></span>
- <span><span class="cm-variable">HDF_INIT</span>(<span class="cm-variable">g_hdfUartchdog</span>);</span>
复制代码 2.2.2.2、配置属性文件完成驱动入口注册之后,需要在device_info.hcs文件中添加deviceNode信息,deviceNode信息与驱动入口注册相关。本例以两个UART控制器为例,如有多个器件信息,则需要在device_info.hcs文件增加对应的deviceNode信息。器件属性值与核心层UartDev成员的默认值或限制范围有密切关系,比如Uart设备号,需要在uart_config.hcs文件中增加对应的器件属性。
本次案例以rk3568为案例(即文件//vendor/lockzhiner/rk3568/hdf_config/khdf/device_info/device_info.hcs),添加deviceNode描述,具体修改如下:
- <span>device_uart :: device {</span>
- <span> device0 :: deviceNode {</span>
- <span> policy = 1;<span class="cm-tab"> </span><span class="cm-tab"> </span><span class="cm-tab"> </span><span class="cm-tab"> </span><span class="cm-tab"> </span><span class="cm-tab"> </span><span class="cm-tab"> </span><span class="cm-tab"> </span><span class="cm-tab"> </span>// 驱动服务发布的策略,policy大于等于1(用户态可见为2,仅内核态可见为1)</span>
- <span> priority = 40;<span class="cm-tab"> </span><span class="cm-tab"> </span><span class="cm-tab"> </span><span class="cm-tab"> </span><span class="cm-tab"> </span><span class="cm-tab"> </span><span class="cm-tab"> </span><span class="cm-tab"> </span>// 驱动启动优先级</span>
- <span> permission = 0644;<span class="cm-tab"> </span><span class="cm-tab"> </span><span class="cm-tab"> </span><span class="cm-tab"> </span><span class="cm-tab"> </span><span class="cm-tab"> </span><span class="cm-tab"> </span>// 驱动创建设备节点权限</span>
- <span> moduleName = "HDF_PLATFORM_UART";<span class="cm-tab"> </span><span class="cm-tab"> </span><span class="cm-tab"> </span>// 驱动名称,该字段的值必须和驱动入口结构的moduleName值一致</span>
- <span> serviceName = "HDF_PLATFORM_UART_0";<span class="cm-tab"> </span><span class="cm-tab"> </span>// 驱动对外发布服务的名称,必须唯一,必须要按照HDF_PLATFORM_UART_X的格式,X为UART控制器编号</span>
- <span> deviceMatchAttr = "rockchip_rk3568_uart_0"; // 驱动私有数据匹配的关键字,必须和驱动私有数据配置表中的match_attr值一致</span>
- <span> }</span>
- <span> device1 :: deviceNode {</span>
- <span> policy = 2;</span>
- <span> permission = 0644;</span>
- <span> priority = 40;</span>
- <span> moduleName = "HDF_PLATFORM_UART";</span>
- <span> serviceName = "HDF_PLATFORM_UART_1";</span>
- <span> deviceMatchAttr = "rockchip_rk3568_uart_1";</span>
- <span> }</span>
- <span>}</span>
复制代码uart_config.hcs 配置参考//vendor/lockzhiner/rk3568/hdf_config/khdf/platform/rk3568_uart_config.hcs,具体修改如下:
- <span>root {</span>
- <span> platform {</span>
- <span> uart_config {</span>
- <span> template uart_device {</span>
- <span> serviceName = "";</span>
- <span> match_attr = "";</span>
- <span> driver_name = "ttyS";</span>
- <span> num = 0;</span>
- <span> }</span>
- <span> device_uart_0x0000 :: uart_device {</span>
- <span> match_attr = "rockchip_rk3568_uart_0";</span>
- <span> }</span>
- <span> device_uart_0x0001 :: uart_device {</span>
- <span> num = 1;<span class="cm-tab"> </span><span class="cm-tab"> </span><span class="cm-tab"> </span><span class="cm-tab"> </span><span class="cm-tab"> </span><span class="cm-tab"> </span><span class="cm-tab"> </span><span class="cm-tab"> </span>// 序号,是Linux的/dev/ttySXXX,XXX即是num</span>
- <span> match_attr = "rockchip_rk3568_uart_1";<span class="cm-tab"> </span>// 必须和device_info.hcs中对应的设备的deviceMatchAttr值一致</span>
- <span> <span class="cm-tab"> </span><span class="cm-tab"> </span><span class="cm-tab"> </span><span class="cm-tab"> </span><span class="cm-tab"> </span><span class="cm-tab"> </span><span class="cm-tab"> </span><span class="cm-tab"> </span><span class="cm-tab"> </span><span class="cm-tab"> </span>// 注意rockchip_rk3568_uart_XX,XX表示的OH的UART序号,必须从0开始,顺序递增</span>
- <span> }</span>
- <span> }</span>
- <span> }</span>
- <span>}</span>
复制代码 2.2.2.3、实例化UART控制器对象完成驱动入口注册之后,下一步就是以核心层UartDev对象的初始化为核心,包括驱动适配者自定义结构体(传递参数和数据),实例化UartDev成员UartHostMethod(让用户可以通过接口来调用驱动底层函数),实现HdfDriverEntry成员函数(Bind、Init、Release)。
- <span><span class="cm-comment">// 定义UartHostMethod成员g_uartHostMethod,实现uart相应接口</span></span>
- <span><span class="cm-keyword">static</span> <span class="cm-keyword">struct</span> <span class="cm-def">UartHostMethod</span> <span class="cm-def">g_uartHostMethod</span> <span class="cm-operator">=</span> {</span>
- <span> .<span class="cm-variable">Init</span> <span class="cm-operator">=</span> <span class="cm-variable">UartAdapterInit</span>,</span>
- <span> .<span class="cm-variable">Deinit</span> <span class="cm-operator">=</span> <span class="cm-variable">UartAdapterDeInit</span>,</span>
- <span> .<span class="cm-variable">Read</span> <span class="cm-operator">=</span> <span class="cm-variable">UartAdapterRead</span>,</span>
- <span> .<span class="cm-variable">Write</span> <span class="cm-operator">=</span> <span class="cm-variable">UartAdapterWrite</span>,</span>
- <span> .<span class="cm-variable">SetBaud</span> <span class="cm-operator">=</span> <span class="cm-variable">UartAdapterSetBaud</span>,</span>
- <span> .<span class="cm-variable">GetBaud</span> <span class="cm-operator">=</span> <span class="cm-variable">UartAdapterGetBaud</span>,</span>
- <span> .<span class="cm-variable">SetAttribute</span> <span class="cm-operator">=</span> <span class="cm-variable">UartAdapterSetAttribute</span>,</span>
- <span> .<span class="cm-variable">GetAttribute</span> <span class="cm-operator">=</span> <span class="cm-variable">UartAdapterGetAttribute</span>,</span>
- <span> .<span class="cm-variable">SetTransMode</span> <span class="cm-operator">=</span> <span class="cm-variable">UartAdapterSetTransMode</span>,</span>
- <span>};</span>
- <span><span class="cm-keyword">static</span> <span class="cm-variable-3">int32_t</span> <span class="cm-def">HdfUartBind</span>(<span class="cm-keyword">struct</span> <span class="cm-def">HdfDeviceObject</span> <span class="cm-operator">*</span><span class="cm-variable">obj</span>);</span>
- <span><span class="cm-keyword">static</span> <span class="cm-variable-3">int32_t</span> <span class="cm-def">HdfUartInit</span>(<span class="cm-keyword">struct</span> <span class="cm-def">HdfDeviceObject</span> <span class="cm-operator">*</span><span class="cm-variable">obj</span>);</span>
- <span><span class="cm-keyword">static</span> <span class="cm-variable-3">void</span> <span class="cm-def">HdfUartRelease</span>(<span class="cm-keyword">struct</span> <span class="cm-def">HdfDeviceObject</span> <span class="cm-operator">*</span><span class="cm-variable">obj</span>);</span>
- <span>};</span>
复制代码 2.2.2.4、驱动调试建议先在Linux下修改确认,再移植到OpenHarmony。
2.3、UART应用开发UART模块应用比较广泛,主要用于实现设备之间的低速串行通信,例如输出打印信息,当然也可以外接各种模块,如GPS、蓝牙等。
2.3.1、接口说明UART模块提供的主要接口如表1所示,具体API详见//drivers/hdf_core/framework/include/platform/uart_if.h。
UART驱动API接口功能介绍如下所示:
(1)UartOpen
在使用UART进行通信时,首先要调用UartOpen获取UART设备句柄,该函数会返回指定端口号的UART设备句柄。
- DevHandle UartOpen(uint32_t port);
复制代码UartOpen参数定义如下:
UartOpen返回值定义如下:
假设系统中的UART端口号为1,获取该UART设备句柄的示例如下:
- <span><span class="cm-variable">DevHandle</span> <span class="cm-variable">handle</span> <span class="cm-operator">=</span> <span class="cm-variable">NULL</span>; <span class="cm-comment">// UART设备句柄</span></span>
- <span><span class="cm-variable-3">uint32_t</span> <span class="cm-variable">port</span> <span class="cm-operator">=</span> <span class="cm-number">1</span>; <span class="cm-comment">// UART设备端口号</span></span>
- <span><span class="cm-variable">handle</span> <span class="cm-operator">=</span> <span class="cm-variable">UartOpen</span>(<span class="cm-variable">port</span>);</span>
- <span><span class="cm-keyword">if</span> (<span class="cm-variable">handle</span> <span class="cm-operator">==</span> <span class="cm-variable">NULL</span>) {</span>
- <span> <span class="cm-variable">HDF_LOGE</span>(<span class="cm-string">"UartOpen: open uart_%u failed!\n"</span>, <span class="cm-variable">port</span>);</span>
- <span> <span class="cm-keyword">return</span>;</span>
- <span>}</span>
复制代码(2)UartSetBaud
在通信之前,需要设置UART的波特率。
- int32_t UartSetBaud(DevHandle handle, uint32_t baudRate);
复制代码UartSetBaud参数定义如下:
UartSetBaud返回值定义如下:
(3)UartGetBaud
设置UART的波特率后,可以通过获取波特率接口来查看UART当前的波特率。
- int32_t UartGetBaud(DevHandle handle, uint32_t *baudRate);
复制代码UartGetBaud参数定义如下:
UartGetBaud返回值定义如下:
(4)UartSetAttribute
在通信之前,需要设置UART的设备属性。
- int32_t UartSetAttribute(DevHandle handle, struct UartAttribute *attribute);
复制代码UartSetAttribute参数定义如下:
UartSetAttribute返回值定义如下:
(5)UartGetAttribute
设置UART的设备属性后,可以通过获取设备属性接口来查看UART当前的设备属性。
- int32_t UartGetAttribute(DevHandle handle, struct UartAttribute *attribute);
复制代码UartGetAttribute参数定义如下:
UartGetAttribute返回值定义如下:
(6)UartSetTransMode
在通信之前,需要设置UART的传输模式。
- int32_t UartSetTransMode(DevHandle handle, enum UartTransMode mode);
复制代码UartSetTransMode参数定义如下:
UartSetTransMode返回值定义如下:
(7)UartWrite
向UART设备写入指定长度的数据。
- int32_t UartWrite(DevHandle handle, uint8_t *data, uint32_t size);
复制代码UartWrite参数定义如下:
UartWrite返回值定义如下:
(8)UartRead
从UART设备中读取指定长度的数据。
- int32_t UartRead(DevHandle handle, uint8_t *data, uint32_t size);
复制代码UartRead参数定义如下:
UartRead返回值定义如下:
(9)UartClose
UART通信完成之后,需要销毁UART设备句柄。
- void UartClose(DevHandle handle);
复制代码UartClose参数定义如下:
2.2.2、开发流程
使用UART的一般流程如下图所示:
3、程序解析3.1、准备工作查看《凌蒙派-RK3568开发板排针说明表》(即Git仓库的//docs/board/凌蒙派-RK3568开发板排针说明表v1.0.xlsx),具体如下:
3.2、Linux内核解析3.2.1、创建Linux内核Git请参考《OpenHarmony如何为内核打patch》(即Git仓库的//docs/OpenHarmony如何为内核打patch.docx)。
3.2.2、修改设备树PWM7配置修改//arch/arm64/boot/dts/rockchip/rk3568-lockzhiner-x0.dtsi(即该目录是指已打Patch后的Linux内核,不是OpenHarmony主目录),具体如下所示:
- <span>&uart5 {</span>
- <span><span class="cm-tab"> </span>status = "okay";</span>
- <span><span class="cm-tab"> </span>pinctrl-names = "default";</span>
- <span><span class="cm-tab"> </span>pinctrl-0 = <&uart5m1_xfer>;</span>
- <span>};</span>
复制代码 3.2.3、创建内核patch请参考《OpenHarmony如何为内核打patch》(即Git仓库的//docs/OpenHarmony如何为内核打patch.docx)。
3.2.4、替换OpenHarmony的内核patch将制作出的kernel.patch替换到//kernel/linux/patches/linux-5.10/rk3568_patch/kernel.patch即可。
3.3、OpenHarmony配置树配置 3.3.1、device_info.hcs//vendor/lockzhiner/rk3568/hdf_config/khdf/device_info/device_info.hcs已定义好,具体如下:
- <span> policy = 1;</span>
- <span> serviceName = "HDF_PLATFORM_UART_0";</span>
- <span> deviceMatchAttr = "rockchip_rk3568_uart_0";</span>
- <span> }</span>
- <span> }</span>
- <span> device2 :: deviceNode {</span>
- <span> serviceName = "HDF_PLATFORM_UART_2";</span>
- <span> deviceMatchAttr = "rockchip_rk3568_uart_2";</span>
- <span> }</span>
- <span>}</span>
复制代码注意:
device2是我们新增的设备节点,给uart5使用。
policy必须为2,表示对内核态和用户态提供服务。否则,应用程序无法调用。
HDF_PLATFORM_UART_2,后面跟着的数据“2”,是UartOpen()的端口号。
HDF_PLATFORM_UART_2,后面跟着的数据“2”,必须是递增的。
3.3.2、rk3568_uart_config.hcs//vendor/lockzhiner/rk3568/hdf_config/khdf/platform/rk3568_uart_config.hcs,具体内容如下:
- <span> }</span>
- <span> }</span>
- <span> num = 1;</span>
- <span> match_attr = "rockchip_rk3568_uart_1";</span>
- <span> }</span>
- <span> device_uart_0x0002 :: uart_device {</span>
- <span> num = 5;</span>
- <span> match_attr = "rockchip_rk3568_uart_2";</span>
- <span> }</span>
- <span> }</span>
- <span> }</span>
- <span>}</span>
复制代码注意:
3.4、OpenHarmony UART平台驱动在//drivers/hdf_core/adapter/khdf/linux/platform/uart/uart_adapter.c已编写对接Linux PWM驱动的相关代码,具体内容如下:
- <span>};</span>
复制代码该部分代码不细述,感兴趣的读者可以去详读。
3.5、应用程序 3.5.1、uart_test.cuart相关头文件如下所示:
- #include "uart_if.h" // UART标准接口头文件
复制代码主函数定义UART接口调用,具体如下:
- <span><span class="cm-variable-3">int</span> <span class="cm-def">main</span>(<span class="cm-variable-3">int</span> <span class="cm-variable">argc</span>, <span class="cm-variable-3">char*</span> <span class="cm-variable">argv</span>[])</span>
- <span>{</span>
- <span> <span class="cm-variable">DevHandle</span> <span class="cm-variable">handle</span> <span class="cm-operator">=</span> <span class="cm-variable">NULL</span>;</span>
- <span> <span class="cm-keyword">struct</span> <span class="cm-def">UartAttribute</span> <span class="cm-def">attribute</span>;</span>
- <span> <span class="cm-variable-3">int32_t</span> <span class="cm-variable">ret</span> <span class="cm-operator">=</span> <span class="cm-number">0</span>;</span>
- <span> <span class="cm-variable-3">uint8_t</span> <span class="cm-variable">wbuff</span>[<span class="cm-variable">STRING_MAXSIZE</span>] <span class="cm-operator">=</span> <span class="cm-string">"HelloWorld"</span>;</span>
- <span> <span class="cm-variable-3">uint8_t</span> <span class="cm-variable">rbuff</span>[<span class="cm-variable">STRING_MAXSIZE</span>] <span class="cm-operator">=</span> { <span class="cm-number">0</span> };</span>
- <span> ......</span>
- <span> <span class="cm-variable">attribute</span>.<span class="cm-variable">dataBits</span> <span class="cm-operator">=</span> <span class="cm-variable">UART_ATTR_DATABIT_8</span>; <span class="cm-comment">// UART传输数据位宽,一次传输7个bit</span></span>
- <span> <span class="cm-variable">attribute</span>.<span class="cm-variable">parity</span> <span class="cm-operator">=</span> <span class="cm-variable">UART_ATTR_PARITY_NONE</span>; <span class="cm-comment">// UART传输数据无校检</span></span>
- <span> <span class="cm-variable">attribute</span>.<span class="cm-variable">stopBits</span> <span class="cm-operator">=</span> <span class="cm-variable">UART_ATTR_STOPBIT_1</span>; <span class="cm-comment">// UART传输数据停止位为1位</span></span>
- <span> <span class="cm-variable">attribute</span>.<span class="cm-variable">rts</span> <span class="cm-operator">=</span> <span class="cm-variable">UART_ATTR_RTS_DIS</span>; <span class="cm-comment">// UART禁用RTS</span></span>
- <span> <span class="cm-variable">attribute</span>.<span class="cm-variable">cts</span> <span class="cm-operator">=</span> <span class="cm-variable">UART_ATTR_CTS_DIS</span>; <span class="cm-comment">// UART禁用CTS</span></span>
- <span> <span class="cm-variable">attribute</span>.<span class="cm-variable">fifoRxEn</span> <span class="cm-operator">=</span> <span class="cm-variable">UART_ATTR_RX_FIFO_EN</span>; <span class="cm-comment">// UART使能RX FIFO</span></span>
- <span> <span class="cm-variable">attribute</span>.<span class="cm-variable">fifoTxEn</span> <span class="cm-operator">=</span> <span class="cm-variable">UART_ATTR_TX_FIFO_EN</span>; <span class="cm-comment">// UART使能TX FIFO</span></span>
- <span> <span class="cm-variable">handle</span> <span class="cm-operator">=</span> <span class="cm-variable">UartOpen</span>(<span class="cm-variable">m_uart_port</span>);</span>
- <span> <span class="cm-keyword">if</span> (<span class="cm-variable">handle</span> <span class="cm-operator">==</span> <span class="cm-variable">NULL</span>) {</span>
- <span> <span class="cm-variable">PRINT_ERROR</span>(<span class="cm-string">"UartOpen: open uart port %u failed!\n"</span>, <span class="cm-variable">m_uart_port</span>);</span>
- <span> <span class="cm-keyword">return</span> <span class="cm-operator">-</span><span class="cm-number">1</span>;</span>
- <span> }</span>
- <span> <span class="cm-variable">PRINT_INFO</span>(<span class="cm-string">"UartOpen successful and uart port = %d\n"</span>, <span class="cm-variable">m_uart_port</span>);</span>
- <span> <span class="cm-comment">// 设置UART波特率</span></span>
- <span> <span class="cm-variable">ret</span> <span class="cm-operator">=</span> <span class="cm-variable">UartSetBaud</span>(<span class="cm-variable">handle</span>, <span class="cm-variable">m_uart_baudrate</span>);</span>
- <span> <span class="cm-keyword">if</span> (<span class="cm-variable">ret</span> <span class="cm-operator">!=</span> <span class="cm-variable">HDF_SUCCESS</span>) {</span>
- <span> <span class="cm-variable">PRINT_ERROR</span>(<span class="cm-string">"UartSetBaud: set baud failed, ret %d\n"</span>, <span class="cm-variable">ret</span>);</span>
- <span> <span class="cm-keyword">goto</span> <span class="cm-variable">ERR</span>;</span>
- <span> }</span>
- <span> <span class="cm-variable">PRINT_INFO</span>(<span class="cm-string">"UartSetBaud successful and uart baudrate = %d\n"</span>, <span class="cm-variable">m_uart_baudrate</span>);</span>
- <span> <span class="cm-comment">// 设置UART设备属性</span></span>
- <span> <span class="cm-variable">ret</span> <span class="cm-operator">=</span> <span class="cm-variable">UartSetAttribute</span>(<span class="cm-variable">handle</span>, <span class="cm-operator">&</span><span class="cm-variable">attribute</span>);</span>
- <span> <span class="cm-variable">PRINT_ERROR</span>(<span class="cm-string">"UartSetAttribute: set attribute failed, ret %d\n"</span>, <span class="cm-variable">ret</span>);</span>
- <span> }</span>
- <span> <span class="cm-variable">PRINT_INFO</span>(<span class="cm-string">"UartSetAttribute successful\n"</span>);</span>
- <span> <span class="cm-comment">// 获取UART设备属性</span></span>
- <span> <span class="cm-variable">ret</span> <span class="cm-operator">=</span> <span class="cm-variable">UartGetAttribute</span>(<span class="cm-variable">handle</span>, <span class="cm-operator">&</span><span class="cm-variable">attribute</span>);</span>
- <span> <span class="cm-variable">PRINT_ERROR</span>(<span class="cm-string">"UartGetAttribute: get attribute failed, ret %d\n"</span>, <span class="cm-variable">ret</span>);</span>
- <span> }</span>
- <span> <span class="cm-variable">PRINT_INFO</span>(<span class="cm-string">"UartGetAttribute successful\n"</span>);</span>
- <span> <span class="cm-comment">// 设置UART传输模式为非阻塞模式</span></span>
- <span> <span class="cm-variable">ret</span> <span class="cm-operator">=</span> <span class="cm-variable">UartSetTransMode</span>(<span class="cm-variable">handle</span>, <span class="cm-variable">UART_MODE_RD_NONBLOCK</span>);</span>
- <span> <span class="cm-variable">PRINT_ERROR</span>(<span class="cm-string">"UartSetTransMode: set trans mode failed, ret %d\n"</span>, <span class="cm-variable">ret</span>);</span>
- <span> }</span>
- <span> <span class="cm-variable">PRINT_INFO</span>(<span class="cm-string">"UartSetTransMode successful\n"</span>);</span>
- <span> <span class="cm-comment">// 向UART设备写入数据</span></span>
- <span> <span class="cm-variable">ret</span> <span class="cm-operator">=</span> <span class="cm-variable">UartWrite</span>(<span class="cm-variable">handle</span>, <span class="cm-variable">wbuff</span>, (<span class="cm-variable-3">uint32_t</span>)<span class="cm-variable">strlen</span>((<span class="cm-variable-3">char</span> <span class="cm-variable-3">*</span>)<span class="cm-variable">wbuff</span>));</span>
- <span> <span class="cm-variable">PRINT_ERROR</span>(<span class="cm-string">"UartWrite: write data failed, ret %d\n"</span>, <span class="cm-variable">ret</span>);</span>
- <span> }</span>
- <span> <span class="cm-variable">PRINT_INFO</span>(<span class="cm-string">"UartWrite successful and wbuff = %s\n"</span>, <span class="cm-variable">wbuff</span>);</span>
- <span> <span class="cm-comment">// 从UART设备读取5字节的数据</span></span>
- <span> <span class="cm-variable">ret</span> <span class="cm-operator">=</span> <span class="cm-variable">UartRead</span>(<span class="cm-variable">handle</span>, <span class="cm-variable">rbuff</span>, <span class="cm-variable">STRING_MAXSIZE</span>);</span>
- <span> <span class="cm-keyword">if</span> (<span class="cm-variable">ret</span> <span class="cm-operator"><</span> <span class="cm-number">0</span>) {</span>
- <span> <span class="cm-variable">PRINT_ERROR</span>(<span class="cm-string">"UartRead: read data failed, ret %d\n"</span>, <span class="cm-variable">ret</span>);</span>
- <span> }</span>
- <span> <span class="cm-variable">PRINT_INFO</span>(<span class="cm-string">"UartRead successful and rbuff = %s\n"</span>, <span class="cm-variable">rbuff</span>);</span>
- <span><span class="cm-variable">ERR</span>:</span>
- <span> <span class="cm-comment">// 销毁UART设备句柄</span></span>
- <span> <span class="cm-variable">UartClose</span>(<span class="cm-variable">handle</span>);</span>
- <span> <span class="cm-keyword">return</span> <span class="cm-variable">ret</span>;</span>
- <span>}</span>
复制代码 3.5.2、BUILD.gn编写应用程序的BUILD.gn,具体内容如下:
- <span>import("//build/ohos.gni")</span>
- <span>import("//drivers/hdf_core/adapter/uhdf2/uhdf.gni")</span>
- <span>print("samples: compile rk3568_uart_test")</span>
- <span>ohos_executable("rk3568_uart_test") {</span>
- <span> sources = [ "uart_test.c" ]</span>
- <span> include_dirs = [</span>
- <span> "$hdf_framework_path/include",</span>
- <span> "$hdf_framework_path/include/core",</span>
- <span> "$hdf_framework_path/include/osal",</span>
- <span> "$hdf_framework_path/include/platform",</span>
- <span> "$hdf_framework_path/include/utils",</span>
- <span> "$hdf_uhdf_path/osal/include",</span>
- <span> "$hdf_uhdf_path/ipc/include",</span>
- <span> "//base/hiviewdfx/hilog/interfaces/native/kits/include",</span>
- <span> "//third_party/bounds_checking_function/include",</span>
- <span> ]</span>
- <span> deps = [</span>
- <span> "$hdf_uhdf_path/platform:libhdf_platform",</span>
- <span> "$hdf_uhdf_path/utils:libhdf_utils",</span>
- <span> "//base/hiviewdfx/hilog/interfaces/native/innerkits:libhilog",</span>
- <span> ]</span>
- <span> cflags = [</span>
- <span> "-Wall",</span>
- <span> "-Wextra",</span>
- <span> "-Werror",</span>
- <span> "-Wno-format",</span>
- <span> "-Wno-format-extra-args",</span>
- <span> ]</span>
- <span> part_name = "product_rk3568"</span>
- <span> install_enable = true</span>
- <span>}</span>
复制代码 3.5.3、参与应用程序编译编辑//vendor/lockzhiner/rk3568/samples/BUILD.gn,开启编译选项。具体如下:
- "b08_platform_device_uart/app:rk3568_uart_test",
复制代码 4、程序编译建议使用docker编译方法,运行如下:
- <span>hb <span class="cm-keyword">set</span> <span class="cm-attribute">-root</span> .</span>
- <span>hb <span class="cm-keyword">set</span></span>
- <span><span class="cm-comment"># 选择lockzhiner下的rk3568编译分支。</span></span>
- <span>hb build <span class="cm-attribute">-f</span></span>
复制代码 5、运行结果运行如下:
- <span><span class="cm-comment"># rk3568_uart_test -b 115200 -p 2</span></span>
- <span>uart port: <span class="cm-tab"> </span><span class="cm-number">2</span></span>
- <span>uart baud rate: <span class="cm-number">115200</span></span>
- <span>../../vendor/lockzhiner/rk3568/samples/b08_platform_device_uart/app/uart_test.c, main, <span class="cm-number">127</span>, info: UartOpen successful and uart port <span class="cm-operator">=</span> <span class="cm-number">2</span></span>
- <span>../../vendor/lockzhiner/rk3568/samples/b08_platform_device_uart/app/uart_test.c, main, <span class="cm-number">135</span>, info: UartSetBaud successful and uart baudrate <span class="cm-operator">=</span> <span class="cm-number">115200</span></span>
- <span>../../vendor/lockzhiner/rk3568/samples/b08_platform_device_uart/app/uart_test.c, main, <span class="cm-number">143</span>, info: UartSetAttribute successful</span>
- <span>../../vendor/lockzhiner/rk3568/samples/b08_platform_device_uart/app/uart_test.c, main, <span class="cm-number">151</span>, info: UartGetAttribute successful</span>
- <span>../../vendor/lockzhiner/rk3568/samples/b08_platform_device_uart/app/uart_test.c, main, <span class="cm-number">159</span>, info: UartSetTransMode successful</span>
- <span>../../vendor/lockzhiner/rk3568/samples/b08_platform_device_uart/app/uart_test.c, main, <span class="cm-number">167</span>, info: UartWrite successful and wbuff <span class="cm-operator">=</span> HelloWorld</span>
- <span>../../vendor/lockzhiner/rk3568/samples/b08_platform_device_uart/app/uart_test.c, main, <span class="cm-number">175</span>, info: UartRead successful and rbuff <span class="cm-operator">=</span></span>
- <span><span class="cm-comment">#</span></span>
复制代码注意:
建议:
