三、示例
代码:
import prompt from '@ohos.prompt';
@Extend(Text) function textStyle () {
.width('25%')
.height(35)
.fontSize(16)
.textAlign(TextAlign.Center)
.backgroundColor(0xAFEEEE)
@Entry
@Component
struct Drag {
@State numbers: string[] = ['one', 'two', 'three', 'four', 'five', 'six']
@State text: string = ''
@State bool: boolean = true
@State eventType: string = ''
@State appleVisible: Visibility = Visibility.Visible
@State orangeVisible: Visibility = Visibility.Visible
@State bananaVisible: Visibility = Visibility.Visible
private dragList: string[] = ['apple', 'orange', 'banana']
@State fruitVisible: Visibility[] = [Visibility.Visible, Visibility.Visible, Visibility.Visible]
@State index: number = 0
// 自定义拖拽过程中显示的内容
[url=home.php?mod=space&uid=2743618]@builder[/url] pixelMapBuilder() {
Column() {
Text(this.text)
.width('50%')
.height(60)
.fontSize(16)
.borderRadius(10)
.backgroundColor(Color.Yellow)
build() {
Column() {
Text('There are three Text elements here')
.fontSize(20)
.fontColor(0xCCCCCC)
.width('90%')
.textAlign(TextAlign.Start)
.margin(5)
Row({ space: 15 }) {
ForEach(this.dragList, (item, index) => {
Text(item)
.textStyle()
.visibility(this.fruitVisible[index])
.onDragStart(() => {
this.bool = true
this.text = item
this.fruitVisible[index] = Visibility.None
return this.pixelMapBuilder
.onTouch((event: TouchEvent) => {
if (event.type === TouchType.Down) {
this.eventType = 'Down'
this.index = index
if (event.type === TouchType.Up) {
this.eventType = 'Up'
if (this.bool) {
this.fruitVisible[index] = Visibility.Visible
}.padding({ top: 10, bottom: 10 }).margin(10)
Text('This is a List element')
.fontSize(20)
.width('90%')
.margin(15)
List({ space: 20 }) {
ForEach(this.numbers, (item) => {
ListItem() {
Text(item)
.width('100%')
.height(80)
.fontSize(16)
.borderRadius(10)
}, item => item)
.editMode(true)
.height('50%')
.width('90%')
.border({ width: 1 })
.padding(15)
.divider({ strokeWidth: 2, color: 0xFFFFFF, startMargin: 20, endMargin: 20 })
.onDragEnter((event: DragEvent, extraParams: string) => {
console.log('List onDragEnter, ' + extraParams + 'X:' + event.getX() + 'Y:' + event.getY())
.onDragMove((event: DragEvent, extraParams: string) => {
console.log('List onDragMove, ' + extraParams + 'X:' + event.getX() + 'Y:' + event.getY())
.onDragLeave((event: DragEvent, extraParams: string) => {
console.log('List onDragLeave, ' + extraParams + 'X:' + event.getX() + 'Y:' + event.getY())
.onDrop((event: DragEvent, extraParams: string) => {
let jsonString = JSON.parse(extraParams);
if (this.bool) {
// 通过splice方法插入元素
this.numbers.splice(jsonString.insertIndex, 0, this.text)
this.bool = false
prompt.showToast({ message:"移入成功" })
this.fruitVisible[this.index] = Visibility.None
}.width('100%').height('100%').padding({ top: 20 }).margin({ top: 20 })
.width('25%')
.height(35)
.fontSize(16)
@Component
export default struct Drag {
// 自定义拖拽过程中显示的内容
@Builder pixelMapBuilder() {
Column() {
Text(this.text)
.width('50%')
.height(60)
.fontSize(16)
.borderRadius(10)
build() {
Column() {
.fontSize(20)
.width('90%')
.margin(5)
Text(item)
.textStyle()
this.bool = true
this.text = item
this.index = index
if (this.bool) {
.fontSize(20)
.width('90%')
.margin(15)
ListItem() {
Text(item)
.width('100%')
.height(80)
.fontSize(16)
.borderRadius(10)
}, item => item)
.editMode(true)
.height('50%')
.width('90%')
.padding(15)
if (this.bool) {
// 通过splice方法插入元素
this.bool = false
完整代码地址:
https://gitee.com/jltfcloudcn/jump_to/tree/master/Drag
