Rebooting...
ets Jun 8 2016 00:22:57 rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT) configsip: 0, SPIWP:0xee clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 mode:DIO, clock div:2 load:0x3fff0018,len:4 load:0x3fff001c,len:6316 load:0x40078000,len:11624 load:0x40080400,len:6648 entry 0x40080764 I (29) boot: ESP-IDF v3.3 2nd stage bootloader I (29) boot: compile time 14:06:08 I (29) boot: Enabling RNG early entropy source... I (33) boot: SPI Speed : 40MHz I (38) boot: SPI Mode : DIO I (42) boot: SPI Flash Size : 4MB I (46) boot: Partition Table: I (49) boot: ## Label Usage Type ST Offset Length I (56) boot: 0 nvs WiFi data 01 02 00009000 00006000 I (64) boot: 1 phy_init RF data 01 01 0000f000 00001000 I (71) boot: 2 coredump Unknown data 01 03 00010000 00010000 I (79) boot: 3 factory factory app 00 00 00020000 00140000 I (86) boot: 4 ota_0 OTA app 00 10 00160000 00140000 I (94) boot: 5 ota_1 OTA app 00 11 002a0000 00140000 I (101) boot: 6 otadata OTA data 01 00 003e0000 00002000 I (109) boot: End of partition table I (113) boot: Defaulting to factory image I (118) esp_image: segment 0: paddr=0x00020020 vaddr=0x3f400020 size=0x39b5c (236380) map I (210) esp_image: segment 1: paddr=0x00059b84 vaddr=0x3ffbdb60 size=0x03718 ( 14104) load I (216) esp_image: segment 2: paddr=0x0005d2a4 vaddr=0x40080000 size=0x00400 ( 1024) load 0x40080000: _WindowOverflow4 at D:/espressif/esp-idf-v3.3/components/freertos/xtensa_vectors.S:1779 I (217) esp_image: segment 3: paddr=0x0005d6ac vaddr=0x40080400 size=0x02964 ( 10596) load I (230) esp_image: segment 4: paddr=0x00060018 vaddr=0x400d0018 size=0xe60b4 (942260) map 0x400d0018: _flash_cache_start at ??:? I (565) esp_image: segment 5: paddr=0x001460d4 vaddr=0x40082d64 size=0x13830 ( 79920) load 0x40082d64: _xt_coproc_exc at D:/espressif/esp-idf-v3.3/components/freertos/xtensa_vectors.S:1064 I (612) boot: Loaded app from partition at offset 0x20000 I (612) boot: Disabling RNG early entropy source... I (612) cpu_start: Pro cpu up. I (616) cpu_start: Application information: I (621) cpu_start: Project name: esp-idf I (625) cpu_start: App version: v3.3 I (630) cpu_start: Compile time: Jun 3 2020 14:06:04 I (636) cpu_start: ELF file SHA256: d40f1425bd822b7e... I (642) cpu_start: ESP-IDF: v3.3 I (647) cpu_start: Starting app cpu, entry point is 0x40081108 0x40081108: call_start_cpu1 at D:/espressif/esp-idf-v3.3/components/esp32/cpu_start.c:270 I (639) cpu_start: App cpu up. I (658) heap_init: Initializing. RAM available for dynamic allocation: I (664) heap_init: At 3FFAFF10 len 000000F0 (0 KiB): DRAM I (670) heap_init: At 3FFB6388 len 00001C78 (7 KiB): DRAM I (677) heap_init: At 3FFB9A20 len 00004108 (16 KiB): DRAM I (683) heap_init: At 3FFBDB5C len 00000004 (0 KiB): DRAM I (689) heap_init: At 3FFCE6E0 len 00011920 (70 KiB): DRAM I (695) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM I (701) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM I (708) heap_init: At 40096594 len 00009A6C (38 KiB): IRAM I (714) cpu_start: Pro cpu start user code I (61) cpu_start: Chip Revision: 1 W (62) cpu_start: Chip revision is higher than the one configured in menuconfig. Suggest to upgrade it. I (65) cpu_start: Starting scheduler on PRO CPU. I (0) cpu_start: Starting scheduler on APP CPU. SDK version:v3.3 I (77) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE I (87) app_main: mac:246F289D0A8C I (127) sc: led_show I (127) sc: RAM bytes left 188248 I (127) BTDM_INIT: BT controller compile version [e736f10] I (127) sc: The current date/time in china is:5 I (137) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE Done I (137) sc: The current date/time in china is:101080005 Restart counter = 0 W (147) phy_init: failed to load RF calibration data (0x1102), falling back to full calibration ADC channel 7 @ GPIO 35, DAC channel 1 @ GPIO 25. I (167) wifi: wifi driver task: 3ffd56dc, prio:23, stack:3584, core=0 I (167) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE I (177) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE I (217) wifi: wifi firmware version: aeed694 I (217) wifi: config NVS flash: enabled I (217) wifi: config nano formating: disabled I (217) wifi: Init dynamic tx buffer num: 32 I (217) wifi: Init data frame dynamic rx buffer num: 32 I (227) wifi: Init management frame dynamic rx buffer num: 32 I (227) wifi: Init management short buffer num: 32 I (237) wifi: Init static rx buffer size: 1600 I (237) wifi: Init static rx buffer num: 10 I (237) wifi: Init dynamic rx buffer num: 32 ESP_ERROR_CHECK failed: esp_err_t 0x5 (ERROR) at 0x40091ca0 0x40091ca0: _esp_error_check_failed at D:/espressif/esp-idf-v3.3/components/esp32/panic.c:720 file: "../main/smartconfig_main.c" line 990 func: wifi_init expression: esp_wifi_set_config(ESP_IF_WIFI_STA, &wifi_config) ELF file SHA256: d40f1425bd822b7eec83fd57d51dc27135569621db494dda3f4439ee178e313e Backtrace: 0x40091838:0x3ffd04b0 0x40091ca3:0x3ffd04d0 0x400d4536:0x3ffd04f0 0x400d48f6:0x3ffd0640 0x4008dee9:0x3ffd0670 0x40091838: invoke_abort at D:/espressif/esp-idf-v3.3/components/esp32/panic.c:715 0x40091ca3: _esp_error_check_failed at D:/espressif/esp-idf-v3.3/components/esp32/panic.c:721 0x400d4536: wifi_init at D:espressifesp-idf-v3.3gatt_server_modify_otabuild/../main/smartconfig_main.c:990 (discriminator 1) 0x400d48f6: wifi_main at D:espressifesp-idf-v3.3gatt_server_modify_otabuild/../main/smartconfig_main.c:1279 0x4008dee9: vPortTaskWrapper at D:/espressif/esp-idf-v3.3/components/freertos/port.c:403 |
只有小组成员才能发言,加入小组>>
945 浏览 0 评论
1672 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1330 浏览 1 评论
1233 浏览 1 评论
5021 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1253浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
927浏览 3评论
2338浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2527浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1052浏览 2评论
/9
GMT+8, 2025-12-2 09:53 , Processed in 0.694158 second(s), Total 69, Slave 52 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
627
