电子发烧友论坛|
大家好,我刚刚为 esp8266 芯片制作了自己的 PCB,我从 NodeMcu V1.0 中获取了所有原理图。据我所知,硬件与 NodeMcu 相同......
所以这是我的代码与 NodeMcu 配合良好的问题但是当我把它上传到我的主板上,除了 WiFi 外,一切正常。 当我启动 esp 作为接入点时,它显示在我手机的 wifi 列表中,但我无法连接到它。我认为它无法为我的手机分配 ip, 当我选择站模式并给它正确的 ssid 并再次连接我的手机靠近我的板的热点时,它再次识别板周围的所有站,但它无法连接对他们中的任何一个。我也用路由器测试过这个。 那么我该如何解决呢?我感谢你所有的回答 这是一个不起作用的站模式代码 代码:全选/******************************************************************* * An example of bot that receives commands and turns on and off * * an LED. * * * * written by Giacarlo Bacchio (Gianbacchio on Github) * * adapted by Brian Lough * *******************************************************************/ #include #include #include // Initialize Wifi connection to the router char ssid[] = "XXXXXX"; // your network SSID (name) char password[] = "YYYYYY"; // your network key // Initialize Telegram BOT #define BOTtoken "XXXXXXXXX:XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX" // your Bot Token (Get from Botfather) WiFiClientSecure client; UniversalTelegramBot bot(BOTtoken, client); int Bot_mtbs = 1000; //mean time between scan messages long Bot_lasttime; //last time messages' scan has been done bool Start = false; const int ledPin = 13; int ledStatus = 0; void handleNewMessages(int numNewMessages) { Serial.println("handleNewMessages"); Serial.println(String(numNewMessages)); for (int i=0; i String text = bot.messages.text; String from_name = bot.messages.from_name; if (from_name == "") from_name = "Guest"; if (text == "/ledon") { digitalWrite(ledPin, HIGH); // turn the LED on (HIGH is the voltage level) ledStatus = 1; bot.sendMessage(chat_id, "Led is ON", ""); } if (text == "/ledoff") { ledStatus = 0; digitalWrite(ledPin, LOW); // turn the LED off (LOW is the voltage level) bot.sendMessage(chat_id, "Led is OFF", ""); } if (text == "/status") { if(ledStatus){ bot.sendMessage(chat_id, "Led is ON", ""); } else { bot.sendMessage(chat_id, "Led is OFF", ""); } } if (text == "/start") { String welcome = "Welcome to Universal Arduino Telegram Bot library, " + from_name + ".n"; welcome += "This is Flash Led Bot example.nn"; welcome += "/ledon : to switch the Led ONn"; welcome += "/ledoff : to switch the Led OFFn"; welcome += "/status : Returns current status of LEDn"; bot.sendMessage(chat_id, welcome, "Markdown"); } } } void setup() { Serial.begin(115200); // Set WiFi to station mode and disconnect from an AP if it was Previously // connected WiFi.mode(WIFI_STA); WiFi.disconnect(); delay(100); // attempt to connect to Wifi network: Serial.print("Connecting Wifi: "); Serial.println(ssid); WiFi.begin(ssid, password); while (WiFi.status() != WL_CONNECTED) { Serial.print("."); delay(500); } Serial.println(""); Serial.println("WiFi connected"); Serial.print("IP address: "); Serial.println(WiFi.localIP()); pinMode(ledPin, OUTPUT); // initialize digital ledPin as an output. delay(10); digitalWrite(ledPin, LOW); // initialize pin as off } void loop() { if (millis() > Bot_lasttime + Bot_mtbs) { int numNewMessages = bot.getUpdates(bot.last_message_received + 1); while(numNewMessages) { Serial.println("got response"); handleNewMessages(numNewMessages); numNewMessages = bot.getUpdates(bot.last_message_received + 1); } Bot_lasttime = millis(); } } |
相关推荐 |
只有小组成员才能发言,加入小组>>
945 浏览 0 评论
1672 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1330 浏览 1 评论
1233 浏览 1 评论
5021 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1253浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
927浏览 3评论
2338浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2527浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1052浏览 2评论
/9
GMT+8, 2025-12-2 07:58 , Processed in 0.605664 second(s), Total 72, Slave 54 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
9566
