电子发烧友论坛|
description: BSP Display rotation example
dependencies: espressif/esp_io_expander_aw9523b: "=1.0.1" path: "../../../components/io_expander/esp_io_expander_aw9523b" idf: ">=5" hmi_esp32_b_v11: version: "*" override_path: "../../../hmi_esp32_b_v11" -- Found Git: C:/Espressif/tools/idf-git/2.34.2/cmd/git.exe (found version "2.34.1.windows.1") -- ccache will be used for faster recompilation -- The C compiler identification is GNU 11.2.0 -- The CXX compiler identification is GNU 11.2.0 -- The ASM compiler identification is GNU -- Found assembler: C:/Espressif/tools/xtensa-esp32s3-elf/esp-2022r1-11.2.0/xtensa-esp32s3-elf/bin/xtensa-esp32s3-elf-gcc.exe -- Detecting C compiler ABI info -- Detecting C compiler ABI info - done -- Check for working C compiler: C:/Espressif/tools/xtensa-esp32s3-elf/esp-2022r1-11.2.0/xtensa-esp32s3-elf/bin/xtensa-esp32s3-elf-gcc.exe - skipped -- Detecting C compile features -- Detecting C compile features - done -- Detecting CXX compiler ABI info -- Detecting CXX compiler ABI info - done -- Check for working CXX compiler: C:/Espressif/tools/xtensa-esp32s3-elf/esp-2022r1-11.2.0/xtensa-esp32s3-elf/bin/xtensa-esp32s3-elf-g++.exe - skipped -- Detecting CXX compile features -- Detecting CXX compile features - done -- Project is not inside a git repository, or git repository has no commits; will not use 'git describe' to determine PROJECT_VER. -- Building ESP-IDF components for target esp32s3 CMake Error at C:/Espressif/frameworks/esp-idf-v5.0/tools/cmake/build.cmake:519 (message): ERROR: Cannot parse the manifest file. Please check that D:/esp-bsp/examples/hmi_esp32/mainidf_component.yml is valid YAML file |
1个回答
Call Stack (most recent call first):
C:/Espressif/frameworks/esp-idf-v5.0/tools/cmake/project.cmake:440 (idf_build_process) CMakeLists.txt:8 (project) |
只有小组成员才能发言,加入小组>>
945 浏览 0 评论
1672 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1330 浏览 1 评论
1233 浏览 1 评论
5021 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1254浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
927浏览 3评论
2338浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2528浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1052浏览 2评论
/9
GMT+8, 2025-12-2 13:53 , Processed in 0.630805 second(s), Total 75, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1698
