拉取版本:OHOS beta3.2。
hb set选择bearpi_hm_micro。
执行hb build -t notest --tee -f。
编译到toybox时失败:
generated/flags.h scripts/make.sh: line 197: arm_none_eabi-ccache: command not found
这个工具是不存在的,应该是交叉编译参数和CC传入错误,但是目前不晓得怎么改。
具体log如下:
[OHOS INFO] [2506/3905] clang obj/third_party/musl/porting/liteos_a/kernel/src/math/musl.sinf.o
[OHOS INFO] [2507/3905] clang obj/third_party/musl/porting/liteos_a/kernel/src/math/musl.sinh.o
[OHOS INFO] [2508/3905] clang obj/third_party/musl/porting/liteos_a/kernel/src/math/musl.sinhf.o
[OHOS INFO] [2509/3905] ACTION //kernel/liteos_a/apps/toybox:build_toybox(//build/lite/toolchain:linux_x86_64_ohos_clang)
[OHOS INFO] [2510/3905] clang obj/third_party/musl/porting/liteos_a/kernel/src/math/musl.sincos.o
[OHOS INFO] [2511/3905] clang obj/third_party/musl/porting/liteos_a/kernel/src/math/musl.sinhl.o
[OHOS INFO] [2512/3905] clang obj/third_party/musl/porting/liteos_a/kernel/src/math/musl.sinl.o
[OHOS INFO] [2513/3905] ACTION //kernel/liteos_a/apps/mksh:build_mksh(//build/lite/toolchain:linux_x86_64_ohos_clang)
[OHOS INFO] [2514/3905] ACTION //kernel/liteos_a:make(//build/lite/toolchain:linux_x86_64_ohos_clang)
[OHOS ERROR] [2509/3905] ACTION //kernel/liteos_a/apps/toybox:build_toybox(//build/lite/toolchain:linux_x86_64_ohos_clang)
[OHOS ERROR] FAILED: obj/kernel/liteos_a/apps/toybox/build_toybox_build_ext_components.txt unstripped/bin/toybox bin/toybox
[OHOS ERROR] /home/jamie/work/openharmony/code-v3.2-Beta3/OpenHarmony/prebuilts/python/linux-x86/3.9.2/bin/python3 ../../../build/lite/build_ext_components.py --path=/home/jamie/work/openharmony/code-v3.2-Beta3/OpenHarmony/out/bearpi_hm_micro/bearpi_hm_micro/obj/kernel/liteos_a/apps/toybox/toybox_build --command=rm\ -rf\ .git\ \&\&\ cp\ -rfp\ porting/liteos_a/.\ .\ \&\&\ env\ CC=\"ccache\ /home/jamie/work/openharmony/code-v3.2-Beta3/OpenHarmony/prebuilts/clang/ohos/linux-x86_64/llvm/bin/clang\"\ STRIP=\"ccache\ /home/jamie/work/openharmony/code-v3.2-Beta3/OpenHarmony/prebuilts/clang/ohos/linux-x86_64/llvm/bin/llvm-strip\ --strip-unneeded\"\ OUTNAME=toybox\ CFLAGS=\"-fstack-protector-strong\ -D_FORTIFY_SOURCE=2\ -mfloat-abi=softfp\ -mfpu=neon-vfpv4\ -mcpu=cortex-a7\ --target=arm-liteos-ohos\ --sysroot=/home/jamie/work/openharmony/code-v3.2-Beta3/OpenHarmony/out/bearpi_hm_micro/bearpi_hm_micro/sysroot\"\ make\ toybox\ \&\&\ install\ -D\ toybox\ ../../../../../../bin/toybox\ \&\&\ install\ -D\ generated/unstripped/toybox\ ../../../../../../unstripped/bin/toybox --target_dir=/home/jamie/work/openharmony/code-v3.2-Beta3/OpenHarmony/out/bearpi_hm_micro/bearpi_hm_micro/obj/kernel/liteos_a/apps/toybox/build.log --out_dir=/home/jamie/work/openharmony/code-v3.2-Beta3/OpenHarmony/out/bearpi_hm_micro/bearpi_hm_micro/error.log
[OHOS ERROR] scripts/genconfig.sh
[OHOS ERROR] make[1]: Entering directory '/home/jamie/work/openharmony/code-v3.2-Beta3/OpenHarmony/out/bearpi_hm_micro/bearpi_hm_micro/obj/kernel/liteos_a/apps/toybox/toybox_build'
[OHOS ERROR] cc -o kconfig/conf kconfig/conf.c kconfig/zconf.tab.c -DKBUILD_NO_NLS=1 \
[OHOS ERROR] -DPROJECT_NAME=\"ToyBox\"
[OHOS ERROR] In file included from kconfig/zconf.tab.c:2340:
[OHOS ERROR] kconfig/confdata.c: In function ‘conf_write’:
[OHOS ERROR] kconfig/confdata.c:435:20: warning: ‘.tmpconfig.’ directive writing 11 bytes into a region of size between 1 and 128 [-Wformat-overflow=]
[OHOS ERROR] 435 | sprintf(tmpname, "%s.tmpconfig.%d", dirname, (int)getpid());
[OHOS ERROR] | ^~~~~~~~~~~~~~~~~
[OHOS ERROR] kconfig/confdata.c:435:3: note: ‘sprintf’ output between 13 and 150 bytes into a destination of size 128
[OHOS ERROR] | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
[OHOS ERROR] kconfig/conf -D /home/jamie/work/openharmony/code-v3.2-Beta3/OpenHarmony/out/bearpi_hm_micro/bearpi_hm_micro/obj/kernel/liteos_a/apps/toybox/toybox_build/../liteos_a_custom.config Config.in > /dev/null
[OHOS ERROR] make[1]: Leaving directory '/home/jamie/work/openharmony/code-v3.2-Beta3/OpenHarmony/out/bearpi_hm_micro/bearpi_hm_micro/obj/kernel/liteos_a/apps/toybox/toybox_build'
[OHOS ERROR] scripts/make.sh
[OHOS ERROR] Generate headers from toys/*/*.c...
[OHOS ERROR] Library probe...........
[OHOS ERROR] Make generated/config.h from .config.
[OHOS ERROR] generated/flags.h scripts/make.sh: line 197: arm_none_eabi-ccache: command not found
[OHOS ERROR] scripts/make.sh: line 197: arm_none_eabi-ccache: command not found
[OHOS ERROR] make: *** [Makefile:19: toybox] Error 1
[OHOS ERROR] cmd:rm -rf .git
[OHOS ERROR] cost time:0:00:00
[OHOS ERROR] cmd: cp -rfp porting/liteos_a/. .
[OHOS INFO] ---------------------------------------------
[OHOS INFO] ccache summary:
[OHOS INFO] cache hit (direct) : 4410
[OHOS INFO] cache hit (preprocessed) : 33
[OHOS INFO] cache miss : 9
[OHOS INFO] hit rate: 99.80%
[OHOS INFO] mis rate: 0.20%
[OHOS INFO] c targets overlap rate statistics
[OHOS INFO] subsystem files NO. percentage builds NO. percentage overlap rate
[OHOS INFO] aafwk 67 2.2% 67 2.2% 1.00
[OHOS INFO] ability 67 2.2% 67 2.2% 1.00
[OHOS INFO] ai 39 1.3% 39 1.3% 1.00
[OHOS INFO] arkui 108 3.5% 108 3.5% 1.00
[OHOS INFO] bundlemanager 38 1.2% 38 1.2% 1.00
[OHOS INFO] commonlibrary 8 0.3% 8 0.3% 1.00
[OHOS INFO] communication 125 4.1% 125 4.1% 1.00
[OHOS INFO] distributeddatamgr 2 0.1% 2 0.1% 1.00
[OHOS INFO] global 27 0.9% 27 0.9% 1.00
[OHOS INFO] graphic 288 9.4% 288 9.4% 1.00
[OHOS INFO] hdf 286 9.3% 286 9.3% 1.00
[OHOS INFO] hiviewdfx 13 0.4% 13 0.4% 1.00
[OHOS INFO] kernel 1308 42.5% 1308 42.5% 1.00
[OHOS INFO] multimedia 19 0.6% 19 0.6% 1.00
[OHOS INFO] powermgr 25 0.8% 25 0.8% 1.00
[OHOS INFO] security 233 7.6% 233 7.6% 1.00
[OHOS INFO] startup 73 2.4% 73 2.4% 1.00
[OHOS INFO] systemabilitymgr 25 0.8% 25 0.8% 1.00
[OHOS INFO] third_party 355 11.5% 355 11.5% 1.00
[OHOS INFO] thirdparty 355 11.5% 355 11.5% 1.00
[OHOS INFO]
[OHOS INFO] c overall build overlap rate: 1.00
[OHOS INFO]
[OHOS INFO]
[OHOS ERROR] Please check build log in /home/jamie/work/openharmony/code-v3.2-Beta3/OpenHarmony/out/bearpi_hm_micro/bearpi_hm_micro/build.log
jamie@lzm-vm-linux:~/work/openharmony/code-v3.2-Beta3/OpenHarmony$
小弟刚接触OHOS,请多多指教。
