关闭代理的情况下添加组件发生情况报错
done! C:RT-ThreadStudio>cd /d C:RT-ThreadStudioworkspaceTouchGFX C:RT-ThreadStudioworkspaceTouchGFX>scons --useconfig=.config scons: Reading SConscript files ... please wait... Error message:HTTPSConnectionPool(host='api.rt-thread.org', port=443): Max retries exceeded with url: /packages/queries (Caused by SSLError(SSLEOFError(8, u'EOF occurred in violation of protocol (_ssl.c:661)'),)) The mirror server could not be contacted. Please check your network connection. Start to download package : ezXML-0.8.6.zip error message:HTTPSConnectionPool(host='github.com', port=443): Max retries exceeded with url: /RT-Thread-packages/ezXML/archive/v0.8.6.zip (Caused by SSLError(SSLEOFError(8, u'EOF occurred in violation of protocol (_ssl.c:661)'),)) error message:HTTPSConnectionPool(host='github.com', port=443): Max retries exceeded with url: /RT-Thread-packages/ezXML/archive/v0.8.6.zip (Caused by SSLError(SSLEOFError(8, u'EOF occurred in violation of protocol (_ssl.c:661)'),)) error message:HTTPSConnectionPool(host='github.com', port=443): Max retries exceeded with url: /RT-Thread-packages/ezXML/archive/v0.8.6.zip (Caused by SSLError(SSLEOFError(8, u'EOF occurred in violation of protocol (_ssl.c:661)'),)) error message:HTTPSConnectionPool(host='github.com', port=443): Max retries exceeded with url: /RT-Thread-packages/ezXML/archive/v0.8.6.zip (Caused by SSLError(SSLEOFError(8, u'EOF occurred in violation of protocol (_ssl.c:661)'),)) error message:HTTPSConnectionPool(host='github.com', port=443): Max retries exceeded with url: /RT-Thread-packages/ezXML/archive/v0.8.6.zip (Caused by SSLError(SSLEOFError(8, u'EOF occurred in violation of protocol (_ssl.c:661)'),)) error message:HTTPSConnectionPool(host='github.com', port=443): Max retries exceeded with url: /RT-Thread-packages/ezXML/archive/v0.8.6.zip (Caused by SSLError(SSLEOFError(8, u'EOF occurred in violation of protocol (_ssl.c:661)'),)) ({'path': '/packages/language/XML/ezXML', 'ver': 'v0.8.6', 'name': 'EZXML'}, 'download failed.') Error package : {u'path': u'/packages/iot/ezXML', u'ver': u'v0.8.6', u'name': u'EZXML'} ==============================> Packages list to download : Package name : EZXML, Ver : v0.8.6 The packages in the list above are accidentally deleted or renamed. Traceback (most recent call last): If you manually delete the version suffix of the package folder name, you can use In case of accidental deletion, the ENV tool will automatically re-download these packages. main() args.func(args) package_update() if not handle_download_error_packages(sys_value, force_update): get_flag = error_packages_handle(error_packages_list, package_json, package_filename, force_update) if install_package(env_root, pkgs_root, bsp_root, package, force_update): package.parse(pkg_path) with open(filename, "r") as f: done! 顺便说一句,别人的方法安装了python27并删除了配置文件。 又是重装软件,还是试报同样的错 |
1个回答
是不是你本地网络显示代理造成的,先关了试试呗。
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
1033 浏览 0 评论
2877 浏览 0 评论
图腾柱PFC无法上升至400V,且电感电流为正弦波形,但是幅值极小
9386 浏览 0 评论
飞凌嵌入式ElfBoard-Vim编辑器之静态链接和动态链接
2898 浏览 0 评论
使用 LinkBoy 将程序导出为 C 语言代码并烧录至 Arduino ESP32 开发板
2302 浏览 1 评论
/9
GMT+8, 2025-12-2 15:45 , Processed in 1.449722 second(s), Total 76, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1474
